Question about Toshiba 28N33 28" TV
Very bad problem
Hi, i have one problem.....could you please help me....i'am facing problem on my Toshiba 2939UE...the problem was both of the picture on a left and right side but only from the center to bottom was curving....but after on the TV for a few second it will turn to normal back......i already changed all cap at vertical part, and a few cap at horizontal part....but still remain the same problem....please help!!
  • azhar mohammad Sep 07, 2006
    i've changed 4 small cap ( 2 cap= 1uf,50v and 2 cap= 2.2uf,50v)near to jungle ic and its work.....thanx so much!
    please guru...after i changed 4 small cap, it seems like ok but i try to do monitoring and evaluation....i turn the tv off for 10min, when i turn on the tv back the problem still remain the same! something wrong with my jungle ic?
    President:
  • 3,130 Answers
Bet you didnt change the two small waveshaper caps by the jungle IC or close to it.
Posted on Sep 06, 2006
  • Larry  Dillon
    Larry Dillon Sep 07, 2006
    No probably another capacitor in the sweep power supply, that feeds the b+ to the vertical IC. It will have the same beginning numbers that the caps will in the vertical circuit.
No picture on toshiba 42" flat screen tv
Definitely a blown fuse, you just need to locate it.
Look up the diagram for your make and model.
Dec 22, 2017 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
TV turns on, but the red light blinks off right away and no picture. What could it be?
Hi my name is Roety,
I can help you with your issue ,
Red light blinking on a toshiba usually means bad convergence ICs and blown pico fuse.
A repairman would charge about $350 to fix it.
soldering in these ICs is not for a non technical person.
 best of luck
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 10, 2009 | Toshiba Televison & Video
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Hi, my toshiba sytem is locked. how can i break them. if you know please, help me
Hi
I assume that was boot password. I have face with this before, and possible to hacked it is quite hard.
If possible, locate nearest toshiba service center near you, sent the laptop to them, they will reset the password in no time for a free
if locked under windows, i have other solution
Dec 26, 2008 | Computers & Internet
Toshiba Projection Television Problems
we are facing server problems please reply to me at coolguy4u_008@yahoo.com
don't worry i have found your part..
Apr 11, 2008 | Toshiba 57H81 57" Rear Projection...
Picture gone.
You have bad conv. ic's.On these sets when the ic's go bad it will usually pop a fuse or burn up a few safety resistors,causing ith video to go away.
Mar 03, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba rear projection
No I am sorry It does not, please explain better?!
Jun 27, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 28N33 28" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
