Question about Vizio P42HD Television
No Picture I have a Vizio P42 Plasma, Type SP42A, Serial # DTP AAsA E44027. I have no piicture and when powered on it seems to go thru the seires of booting up but then seems to just tripp off. I unplug, plug in, turn on main power switch (louder click), (light click) as the light turns amber on the front panel. A few seconds later (light click) as the front panel light turns green. Five seconds later (light click) as if it has tripped and the front panel light remains green. No picture. Here is a run down of the series OF EVENTS: 1. Main power switch on, (louder click) comming from small power board?. Its located in the middle back of the unit. Its a delta board stamped (Model: ADP-60CF A) and has a white sticker afixed to one of the moduels stamped (KXT 044 3036 944). There is also a light paper type cardboard wrapped and taped around the sides of board with a bar code sticker afixed with numbers reading (KTX000443036944). 2. Then (light click) comming from main power board?. P/N 3501Q00053A Rev.A, & S/N D604610990. As light turns solid green on bottom of this board and front panel light turns amber. 3. A few seconds later another (light click) comming from the main power board? As front panel light turns green, main power board light remains solid green and green lights come on from an unidentified board at bottom back left, below the Y-Sustain board part# 6871Qyh027B. Lights come on in sequence D2 solid, D13 solid, D17 flashes. 4. Five seconds later another (slighty louder click) comming from the main power board? as if it tripped. Light on front panel remains green. Light on main power board? flashes 5 times then solid, flashes 5 times then solid and repeats this till the main power switch is turned off. Also the green lights on the board below the Y-Sustain board turn off. 5. There is also a slight frequency pitch noise comming from the small power board that makes the first (louder click) when turning on from the main power switch and continues till the last (as if it were tripped Click) then it is silent. I hope this long winded explination will help you in helping me trouble shoot this problem. I'm sure one of the boards are bad and needs to be replaced but which one?? Hope you can give me some advice or help on pin pointing this faulty board. I will be doing the work my self and as I can see from removing the back panel all the boards are screw and plug in. Thanx, David
  • ddingess Oct 29, 2008
    Its been down for several weeks now, Just found the time to try and fix it, Why do you ask?
    Checked all of the obvious before hand.... Was hopeing for a little more than that....
    Genius:
  • 1,550 Answers
Check whether the fuse near Y-sus board is blown/damaged ?
If it is blown replace it .
If the fuse is ok then you need to change Y-sus board but it is very expensive to change it .
Posted on Oct 29, 2008
    President:
  • 1,952 Answers
This problem cause due to rthe voltage are not enter into the videocard in the board check tat ..
  • mohammed marika thambi
    mohammed marika thambi Oct 30, 2008
    it is a power supply short
    this is a power supply problem. the only real way you can do this is if you know how to solder and use a dc/ohm meter
    President:
  • 2,712 Answers
I would check the soldering first for any cracks, and any obvious faulty capacitors or components. It looks like the power board is going into a protective mode because of a short / failed component somewhere.
It would be virtually impossible to guess exactly where with a spot check..
    Genius:
  • 1,142 Answers
Since how long are you facing the problem
Sp42a we have sound but no picture can this be fixed
there a Plasma screen defect, needs to be checked by a tech. send to repair.
Jan 02, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Vizio P42 HDTV no picture
Try first unplugging power cable for thirty minutes, then plug back, this will drain power from TV completely and will reset it.
See if it works.
Oct 18, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
yes you need to check the power supply board going to the pitcure tube board common problem bad transister
Oct 12, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio sp42a
your tv is having a problem of more than one component .to get rid of the problem u should rectify your vif horizontal and vertical sections
Sep 24, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
SMPS power supply for Vizio p42
Sure:
http://www.vizio.com/support.aspx
Call the support phone number early in the morning!
solutiondoct
Sep 05, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio p42 very dark screen backlight off
There is no back light in plasma TV, Base on the description, the Z Sustainer board is bad. Replace the board will fix the problem.
Jun 02, 2008 | Vizio L37 Television
Vizio P42 Plasma HDTV10A
THE CABLE INPUT IS SERVED ON 22" VIZIO HOW AND WERE CAN I GO TO FIX THIS PROBLEM IN ATLANTA
May 19, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio p42 type sp42a nov 2004 hd tv
POWER SUPPLY OR LCD PANEL INVERTER BOARDS . AVAILABLE THROUGH VIZIO , PARTSTORE.COM OR EBAY
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Picture fades to black then reappears and repeats fades to black .
Is the sound ok. Yust the Picture. If both dissapear replace power supply board. That is the main big board with the most heatsinks on it. Main power gos from a switch board to main power supply.
Nov 21, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P42HD Television Logo
907 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
