Question about GE JGBP28 Gas Kitchen Range
Das oven which will not come on.
I have a simalar problem with my oven. All the top burners work fine.
I was fortunate enough to have a "nice" gas represenative come out
when I had problems with another gas problem. He took the oven
apart inside. Where all the baking is done. He showed me a part
3-4 inches long, secured onto the gas pipe 3/4 of the way down the
pipe (funnel) This piece comes off with screws and is commonly
easy to replace. I just need the name of part? Can anyone help?
    Problem Solver:
  • 4 Answers
I think you are referring to the Thermo-coulper. It has to heat up to allow the gas to flow and acts as a safety device to shut off the gas if the flame goes out. Good Luck.
Posted on Oct 29, 2008
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Broiler works, oven settings - no flame, no heat.
Hi, it sounds like the oven ignitor might be bad. Remove the floor panel inside the oven and you will see the ignitor attached to the burner assembly. Turn the oven on and see if it glows. You can test the connection for the ignitor and see if it gets 120V to it. The most common problem with the gas oven is the ignitor. Most of the time, the ignitor glows but is not strong enough to open the gas valve.
Please let me know if this was helpfull or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | GE JGBP33 Gas Kitchen Range
Top burners on our Viking work fine, however the
Hi, There is a good chance the ignitor is bad. Even if it glows, it could be weak enough that it will not open the gas valve. It is very a common problem with the gas stoves.
I would change the ignitor.
Vic
Jun 27, 2009 | Ovens
Oven burner won't light
You likely have a bad ignitor. It's like a mini element that heats up and then ignites the gas once the valve releases it. When the ignitor gets old it doesn't glow bight enough or draw enough amperage so the gas valve won't open. If you set bake and see a glow coming from under the plate in the oven but the burner never lights that's your culprit. They probably cost about $50-$80. Good luck!
Apr 28, 2009 | Hotpoint RGB745 Gas Kitchen Range
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Amana arg7800ww oven will not come up to temperature.
Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
Jan 13, 2009 | Ovens
Whirlpool SF377PEGQ 0 ,Gas Oven not igniting...
if you have 120 v to ignitor then ignitor is bad.
Dec 26, 2008 | Kitchen Ranges
Oven will not lite
Unplug the unit, change the igniter maybe it does not draw enough ampage.
or check the gas control knob if somebody mistakenly turned it to off position. the ON position should be inline with the gas pipe.
Dec 18, 2008 | Frigidaire FGB24S5A Gas Single Oven
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Oven not lighting
Sounds like the ignitor in the oven is weak and not building up enough resistance to the gas valve to allow gas to the burner. I would replace the ignitor if it is more than 3 or 4 yrs. old.
Oct 05, 2007 | Magic Chef 31000 Gas Kitchen Range
GE JGBP28 Gas Kitchen Range Logo
59 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
