Question about Apple iPod nano
Nano unable to register
I PLUGGED MY NANO UP TO MY COMPUTER AND NOTHING REGISTERS WITH ITUNES. ITS AS IF THE NANO IS NOT CONNECTING AT ALL. WHAT CAN I DO??
  • 1 more comment
  • CARLOSGIBS Oct 29, 2008
    i beleive the nano is one of the newer ones which is not long its short in size. I am unable to connect it to my computer, last time i connected was a month ago and now it wont even come up on itunes.
  • Debs
    Debs May 11, 2010
    have you tried downloading the latest drivers and itunes for your version of windows
  • Debs
    Debs May 11, 2010
    is the nano turned on when you plug it into the computer? If it is turned off the computer will not register it at all.
  • 903 Answers
If you go here you will be able to download the latest version of itunes. http://www.apple.com/itunes/download/ It will have all the necessary drivers for your ipod with it. I hope this helps you. (if you need to contact me for more advice please post a comment not a solution and then I will get your message).
Posted on Oct 29, 2008
Im not sure if i have, where do i go to make sure that i have all the drivers
The nano is on but it just isnt connecting to the computer. I tried holding the center key and menu and it just turns back on and it still does not connect.
How do i register my new ipod
Try connecting it to a computer. This is weird because the first thing it asked when turning it on, is for resgistration.
But use a computer, conenct it to iTunes (you must have iTunes in order to work). Once iTunes recognize it, if it isn't register it should recognize as simply iPod, once the iPod is register, then it should recognize it as "yourname's iPod". Good luck.
Jan 19, 2015 | Apple iPod nano
Register site
reinstall itunes on your computer
Apr 11, 2014 | Apple iPod nano 8 GB Pink (3rd Generation)...
Cannot be found in the computer when connected. the usb cable is fine coz the charger works but the computer will not register the usb connection as a flash drive connection under my computer
First try switching to a different driver on your computer... if this is unsuccessful then there may be a problem with the iPod: try holding the "Menu" button and "Middle" button simultaneously until it asks you to connect to iTunes...
This should reset any user changes and allow you to communicate with iTunes...
when you plug in your device and open itunes it will say that you must restore in order to use with iTunes... click OK and continue with that process when you are all done you should be able to sync with iTunes normally :)
Jul 20, 2010 | Apple iPod nano
How do i resgister my ipod nano
hi
first you have to download itunes at
then you connect your ipod to your pc and itunes should start
you will have the option register
and i would recommend you to register so you can download the latest firmware for your ipod
less bug YEAHHH
Good luck and don't forget to disconnect safely your ipod with itunes and windows option in the taskbar
Jun 19, 2009 | Apple iPod nano
3rd gen ipod nano not showing up in itunes
I tried different computers and cords... I ended up opening iTunes without the iPod and going under Help/Run Diagnostics. I selected to run diagnostics on just the iPod, an error message came up and then it worked. I'm not sure HOW it worked, but it did.
Jan 14, 2009 | Apple iPod nano 3rd Generation
My iPod doesn't show up on my computer!
try to log out of itunes, and set up your own account, log in each time you connect your ipod, your ipod has it's own serial number, and your computer tries to open up ipod 1 even when ipod 2 is being used.
Nov 15, 2008 | Apple iPod nano
Help with my ipod
first reformat your ipod using the right click on the mouse
then you can get a program that works with the ipod but you dont need itunes
its called yamipod and it works great you can get it from here if it dosent solve your problems contact me and i will help you i currently use yamipod my self
http://www.yamipod.com/main/modules/home/
Aug 03, 2008 | Apple iPod nano
Ipod nano 4 DB silver
  1. if you have Vista you need to run ALL update that came with the computer
Jan 06, 2008 | Apple iPod nano
Registering & Syncing Ipod Nano 3G
try reformatting the ipod. that might reset it.
Dec 20, 2007 | Apple iPod nano 3rd Generation
Ipod wont show up on itunes
Okay, I had a similar problem with a 5th Gen 30GB, and I stumbled upon a solution that I have not seen anywhere else.
Basically, my iPod was mounting as a disk drive, but would not show up in iTunes. I reset it many times and ran the diagnostics (left and center upon Apple logo at startup). Nothing worked, and of course I couldn't restore it, because it wouldn't show up in iTunes. It did the same thing regardless of what PC or Mac it was plugged into -- it always mounted, but never showed up in iTunes.
Another odd observation was that it was mounting on my Mac desktop with the "external hard drive" icon, not with an iPod icon.
Here is what I did that fixed it:
1. Plugged it in to a Mac. 2. Opened a Terminal session 3. Browsed to the /Volumes/iPod/iPod_Control/ folder 4. Renamed the iTunes sub-folder to iTunes.backup 5. Ejected the iPod, then re-connected it
At this point, iTunes detected my iPod just fine! I went through the restore procedure as a precaution; because I have no idea what this directory really contains.
I realize that the circumstances surrounding my successful restore are somewhat unique, and probably don't apply to very many other situations, which is why I described some of the quirky things (like the icon showing up as an external hard drive) in detail at the beginning of this. Don't attempt it if you're not comfortable with what I described, or if your iPod has different symptoms!
Dec 24, 2006 | Apple iPod nano
Apple iPod nano Logo
42 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
