Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My ice maker is not working...
The ice stop coming out of the despenser and this little round piece fell into my cup that was broke I tried to glue it back it worked fro a second and then the ice stopped coming put again. Where can i get that little round piece from
  • hcherish Nov 05, 2008
    Thanks for the info! I will check it out. i just hope that this kit is not too expensive
  • Anonymous Mar 16, 2014
    ICE MAKER FELL OUT OF SAMSUNG RF266 HOW TO PUT IT BACK
  • 59 Answers
It sounds like the piece that holds the little ice door in place with a pin. If this is broken the only way to fix it is with a kit that Whirlpool has released. The part number for it is 8201756 and most appliance parts stores will have it. It contains a metal bracket that replaces the tabs as well as a new door assembly and instructions on how to install it. Hope this helps!
Posted on Nov 02, 2008
Samsung rf4287hars ice dispenser doesn't work
The whole unit must be removed and unplugged. There is a screw in the bottom near the dispenser opening. Remove this screwn and then take a butter knife and start prying the unit outword.
The lever that operates the microswitch may be broken and was on mine. This part is cheap plastic and breaks when over entended in the least. If the actuation lever is broken, you will NOT feel any resistance when pressing the Ice despenser and will push on through to dispense water. Problem is there is NO fix for this except replacement and Samsung will not pay for it.
I fashioned a piece of bailing wire in place of the lever that will act the same and have a little spring incase someone presses to hard with their cup/glass. Yes... its bailing wire and works great. You must drill through the middle of the broken support, fashion the wire, coat with super glue and put in position pretty quick. 43e0da13-0ab4-425d-8cad-f17e16cccb58.jpg
If you find a small plastic piece on the floor and your ice maker stops dispensing.... I think I know your problem.
Oct 06, 2012 | Samsung RF4287HARS French Door...
Sub Zero 650 won't stop making ice
The arm activator is wire if you raise it up it should stop making ice. It sounds as if your stop may have broke. This would cause a continuous ice flow
Dec 28, 2011 | Sub-Zero 650 / O Bottom Freezer...
My keurig only dispenses half of a cup of coffee. Half the water comes through the kcup and the other half is despensed back into the water reservoir
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Nov 03, 2010 | Keurig B60 Coffee Maker
Our ice maker stopped working but it still despenses water
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
wryt
Sep 19, 2010 | Whirlpool GD5SHAX Side by Side...
I have a side by side that has the ice maker in the door, when it makes ice cubes, they come out all connected and this makes it difficult to get ice to despense from the shoot and most of the time it will...
It sounds like you have too large a fill of water in the ice maker. If you remove the ice maker there is a fill adjustment screw under the cover of the ice maker.( the only way to get the cover off is to remove the ice maker)
Very small plastic screw head of about 1/8 inch or less. Ice maker controls water valve by time fill. Believe there is one turn adjustment total available. You might want to put a small hole in the cover before you reinstall it to adjust screw the next time without removing ice maker, believe it will be side facing out. Lastly I think you turn adjustment screw in to decrease and out to increase time of fill.
Suggest leaving a towel on the floor for awhile until you have solved problem.
Next thing to try would be a different ice maker, or if normal sized ice is melting and refreezing in the bin, you have a cooling or thermostat problem .
Good luck
Mar 07, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Somehow the rubber gasket on the ice depenser popped off. It's the round black rubber piece that closes when not dispensing ice. How do I get the front off to reattach? My hands are too big to get up...
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
I need an ice maker for my GE refrigerator, made in the 70's
PART NUMBER IS WR30X10093 @ $148.00 available from AP Wagner or Marcone appliance parts
Apr 09, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Front of in door Icemaker door spring fell out!
Any chance of some photoes may be able to figure out if have some pics.
Jul 19, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore elite side by side refrigerator
do you hear the little click of the switch when you push the paddle?? Its likely that the microswitch had broken from its plastic mounts. Pretty common on this refrig. ill need the model # to be sure what kind it is.
Nov 19, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
132 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
