No output to speakers 3,4,5 of panasonic SB-WA15
Is some one able to help me with schematic diagram of panasonic subwoofer SB-WA15? Any help will be appreciated.
thanks
SOURCE: Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Posted on Nov 11, 2007
napps
SOURCE: Subwoofer
is it just the sub you have or do you also have the dvd unit with it?
Posted on Mar 10, 2008
redhead7377
  • 51 Answers
SOURCE: My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
Posted on Jul 25, 2008
  • 104 Answers
SOURCE: need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
Posted on May 23, 2009
Warf135
  • 137 Answers
SOURCE: When I use the headphone output jack (to drive a powered subwoofer), the default internal speaker audio output is disabled, leaving me with only the subwoofer output. How can I use both the internal
Your best option is to use a seperate amp with sub output from the audio outputs on the back of your TV. use this amp to power the sub and a good pair of speakers, and you'll have quality sound.
It is possible to prevent the TV's internal speakers from cutting when you use the headphone socket, but it means going inside your TV, and if your not skilled, you can easily blow your TV (and yourself) up. You just need to re-wire the headphone socket on the TV to stop it cutting the internal spaekers.
Posted on Oct 06, 2009
How to connect panasonic sb-dk-10 subwoofer speakers to another reciever
Yes... and no...sort of. The blue/gray wires can connect to a normal front channel (or rear) just like any other speaker would. However, the red/black (low frequency) need to connect to a dedicated LF connection. Most receivers don't have this output. What you could do is order a Low Pass filter and install it in line with any channel of the receiver you're not using. If the receiver has A/B speakers selectable then you should use the B output to this channel using the low pass filter (I'd order a 200Hz low pass filter .. PartsExpress has many lowpass filter options plus you can call them.
Feb 27, 2016 | Panasonic Audio Players & Recorders
I have a Panasonic SB-WA340 Active Subwoofer, and need to know if this is compatible with other Panasonic home theater units?
It should be compatible with other Panasonic equipment that has an output for a powered subwoofer
Dec 25, 2012 | Audio Players & Recorders
Hi i have a Panasonic surround sound model SBWA15 which is about 5 years old. The machine switches off and displays 'F76' in the display screen. i took it to a repair shop and they say the outputter has...
I have PANASONIC MODEL NO. SB-WA15, the radio works but when i try to work it witht he t.v. it does not come through the speakers. what do i do? i need help before the superbowl tonight!
Aug 05, 2010 | Panasonic SC-HT17 System
Wiring assignment for plug of Panasonic SB WA340
my woofer lost the sound I.C how can i solve this problem?
Feb 13, 2010 | Panasonic Audio Players & Recorders
How can I connect the subwoofer sb-wa920 to a any audio system
Some systems have a sub out. Does this sub have an output on it? If it does, use it first from your output then out to you other speakers. Hope this helps some but I could really use more information.
Jul 13, 2009 | Panasonic SC-HT920 System
Speakers work only on DVD
You might have connected your TV/Stereo Receiver up to the wrong audio outputs of the DVD player. Make sure you are coming out of the FRONT left/right audio outputs and not the CENTER?REAR left/right audio outputs.
Mar 13, 2009 | Panasonic SB-TP55 System
Panasonic subwoofer my receiver is yamaha
1. It's a passive sub. That means there is no amplifier built into the sub cabinet.2. Those are inductors. They passively filter the highs from the signal going to your sub.
3. It may work with the right adapters from Radio Shack. It would be a cheap experiment. Since the computer sub was 4 ohms and the Panasonic sub is 8 ohms, you are OK. You can always go up in impedance but be careful going lower. That's the quickest way to fry an amp.
Your Panasonic sub has 2 sets of speaker inputs and outputs. My guess is that the driver is a dual voice coil. If it says 8 ohms on the driver, then it is probably 8 ohms per coil. Wire the coils in parallel for a final load of 4 ohms and it will match your computer amp.
Finally, if that doesn't work then you can get an external amp to power the sub. Parts Express carries suitable amps from 25w to 3,000+w. Pick one that fits your budget.
Oct 19, 2008 | Panasonic SB-WA100 Subwoofer
Panasonic subwoofer
Any active subwooofer. I have an HE70 as well and I am using the SONY active subwoofer.
Nov 12, 2007 | Panasonic SB-WA100 Subwoofer
Help with SB-WA920 sub woofer PLEASE!!!!
Sure, you can use transition between SB-WA920 system cable with other output. So, you use them as speaker. That's it.
Sep 07, 2007 | Panasonic SC-HT920 System
Televison & Video Logo
219 people viewed this question
Top Televison & Video Experts
