Question about Invacare HTR5500 Tilt & Recline Wheelchair
Power control problem
Have a quickie s-626 power wheelchair. it is controlled by a qtronics device with tilt and 5 levels of speed. when i turn it on now, just all the lights blink off and on but it doesn't work. can this be fixed, or where can i buy a new control?
  • laurdalton Oct 29, 2008
    i will let you know!
  • laurdalton Nov 03, 2008
    appreciated the support of the email address and website. thought about your comment that just replacing the part would probably not be the answer. figured it then must be the wiring from the control. checked along the wiring and found a section that was covered with black electirical tape. with the lights flickering, as i manipulated the wire, the connection was suddenly ok. didn't last, so decided to remove the tape. underneath was an actual connection, and it had become loose. i connected them firmly, and has worked perfectly ever since. the response you gave was exactly what i needed to solve the problem... thanks so much! Carol
    Brigadier General:
  • 3,614 Answers
Check the remote battery connection, it could be only a malfunction on that area. it is better to check it first before you replace of something.
Posted on Oct 29, 2008
    President:
  • 2,712 Answers
I dont think just replacing the controls will help. Best send an email to Quickie support: information@quickie-wheelchairs.com
Or if you are confident of repairing this yourself, you can get parts direct from the website:
http://www.justquickiewheelchairs.com/quickies626.htm
Need fault codes for otronic wheelchair controler
You can look up the codes here:
http://marketing.sunrisemedical.com/qtronix_troubleshooting/main.html
Dec 12, 2016 | Health & Beauty
I have a Quickie S646SE wheelchair with a Qtronics Pilot+ romote controller. I charged the chair last night. When I turned it on today the profile lights scroll left to right and the chair does not move. I...
Press and hold power button til beep then push joystick forward and hold joystick til beep then pull the joystick back and hold joystick til beeps. turn power off then on. should be unlocked now
Mar 17, 2014 | Quickie Wheelchairs Quickie S-646 Power...
Freestyle quickie led lights and horn do not work Motor works great hard to tell with no lights on control panel when it is on or what mode your in or the level of battery left, How do you make repair to...
Hi robert wa211
USA REPAIR CENTER:
PG Drives Technology Inc
2532 East Cerritos Avenue
Anaheim, CA 92806-5627
Tel: 714 712-7911
FAX: 714 978-9512
E-mail: usrepairs@pgdt.com
www.dgdt.com
Call for a return authorization # and mail your controller to these people. I use them all the time. Great folks to work with. (bubble wrap controller well)
Have your model # and serial number ready when you call.
Good Luck
mimobility
May 04, 2011 | Quickie Wheelchairs Quickie Wheelchair 18"...
What does it mean when the speed control lights flash? This is on a Freestyle M11 power wheelchair by Quickie.
its in lock mode see my tips on how to unlock a VSI joystick Hope this helps
Mar 03, 2011 | Health & Beauty
Hi, I have a Quickie P200 elect. wheelchair. The power level is controlled by a potentiometer or rheostat. Everything works fine when the potentiometer is turned no more than half way up. But when I...
Mike you probably have a bad speed control pot. There is a broken wire after the center tap in the pot causing it to shut down. That shouldn't be hard if Quickie can get you the part. You could always chech at a local electronics store for a pot but it would have to be like the one on your chair Hope this helps
Oct 01, 2010 | Electric Health & Beauty
After two or three minutes of travel, the power
You got some bad batteries or your charger is not working. If Medicare purchased the chair contact Repair Xpress at 1-877-581-3733 Medicare will pay for most of the repairs
Jul 25, 2010 | Quickie Wheelchairs Quickie Aspire...
I have a quicky power chair, i think its an F-35 b...
I think you have locked your controller, or put it in "sleep mode". Turn on the chair again and push the joystick forward, then to reverse, then forward again and release. It should fire up. Let us know if that worked.
May 21, 2010 | Quickie Wheelchairs Quickie Aspire Power...
When you turn the chair on the light just binks
If it is just one red light blinking, then your batteries are below the level necessary to power the chair. Charge and see if they come back up, or replace if they won't.
Oct 23, 2009 | Quickie Wheelchairs Quickie Aspire Power...
Invacare HTR5500 Tilt & Recline Wheelchair Logo
167 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Louis Smith
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
