Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Would a neighbors linksys router interfere with my belkin connection?
My house has 4 cpus,my cpu is the only one that wont get internet explorer, and it says i have little or no connectivity on my belkin.have noticed that my cpu notices a linksys in my area??
  • 488 Answers
Do check the signal strength of the wireless connection..you can improve signal by removing any big objects between the compu and the router/access point and/or re positioning the router.also intervening walls will affect signal..the fact that you are getting a linksys signal impilies that your home network signal is weak..hope it helps!
Posted on Oct 31, 2008
Vista wireless connection to belkin-n
It sounds like your linksys is your main connection so therefor it will not always let belkin connect because your pc has registerd your linksys to be your connection.
Sep 20, 2009 | Belkin (F5D5231-4) Router
Access point router and wireless router communication
You said that the router connected to the modem is acting like an access point. that means the DHCP server on that router must be disabled. The second router is connected to the first with the ethernet port. What you can do, you can enable the DHCP server on the first router and make the second router work as an access point.
so that both the computers will be in the same IP address range.
If they are already in the same IP address range then you can try to ping the second computer's IP address form the first computer.
Click here for more info.
Sep 18, 2009 | Belkin (F5D8231-4) Wireless Router...
I have a Belkin Wireless G Plus MIMO Router and a Toshiba Satellite Laptop. The laptop will not connect to the wireless signal from the router. It shows it as an option on the laptop, but will not connect....
It appears that your neighbour has an unprotected wireless router setup for you (and anyone else) to connect into his router and get onto the Internet. You should suggest to him to secure his wireless router.
To connect into your own wireless router, you need to configure the wireless card with your router's wireless configuration settings, eg.the SSID and encryption settings. Check your router manual on how to configure the router or go to the Belkin WEB site to download this info.
You can also connect to the Internet by using a LAN cable and plug it into the Belkin router.
Sep 02, 2009 | Toshiba TR 602A (TR-602A) Router
I use to be able to conect to my company vpn, since i added my belkin wireless G router (fd7230-4)for my sons laptop i am no longer able to do so. Any help would be welcomed. My IT guy says that our...
See if Belkin has a firewall setting in the routers control panel. You have to log on to the routers address to find out. In order to access a linksys control panel you have to put 192,168.1.1 in to internet explorers address bar. The user name by default is Admin and password is the password. Try doing a google search for the belkin log on address to use.
Jul 01, 2009 | Belkin (F5D7230-4) Router (587009)
Connection lasts about 5 minutes
Basically if you do a connection test on the ps3 and it comes back as NAT3 then you will have problems. You need to forward some of the ports of your modem to get to NAT2. You will need to assign static ip addresses to your PS3s so that you can set up port forwarding
You may have interference from a nearby cordless phone (keep these away from router), could be interference from neighbor, try changing channel you use on wireless router.
Some people have reported success just by turning off SSID broadcast in the wireless router.
PLAYSTATION®Network Guide
Jan 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Dropped Calls on Skype
Try to change the channel of the router. If you are using a cordless phone, you need to change it to a handset phone because that will cause interference and it will drop your internet connection
Jan 12, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys router causing tv interference
Apparently, your router is working at a frequency too close to your TV's incoming signal. You can try changing the channel (frequency) that your wireless operates on. Click this link for Linksys' troubleshooting wizard, which will show you how to do this.
If this doesn't help, you might return your router for a different model (I only use belkin myself).
Dec 26, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
I upgraded my Linksys WRV54G firmware from 2.39.2 to 2.39.2e and completely lost internet connectivity
hi there,
have you tried to reset your wireless router so that the default settings are being used, then try reconfiguring it again for your Internet connection.. then try to connect wireless again ... sounds like your router may have lost its settings which happens for some firmware upgrades.....
or
Wireless Interferences
Neighboring wireless networks or any appliance that operates on the same frequency as your wireless device (e.g. 2.4 GHz) may cause interference and therefore may affect your wireless connection and signal.
Common sources of interference are:
  • Neighboring wireless networks
  • Microwave ovens
  • 2.4 GHz cordless telephones
  • Bluetooth devices
  • Wireless baby monitors
To solve the problem, change the channel and SSID on your Access Point. Preferred channels to use are 1, 6 and 11 since they’re considered non-overlapping channels.
May 01, 2008 | Computers & Internet
Router loses connection to Internet
Note : The steps below are applicable only for Belkin routers.
  1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  2. You will get a login page. Leave the password blank. Click Submit .
  3. On the left side of the page, click Channel and SSID below Wireless .
  4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
  5. Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
CauseYou are not able to connect wirelessly mainly due to environmental interference. When the wireless channel is set to auto, the router will cycle to though channels when it detects significant interference. When the router changes channel the wireless connection will reset itself and disconnect all wireless clients connected to the router. SummaryWireless signals are prone to interference from cordless phones and electrical appliances (e.g., vacuum cleaners, microwave ovens). This is the reason wireless connections can drop. This article explains how to overcome frequent wireless disconnections by changing the channel number (frequency) on the Belkin router.
Nov 08, 2007 | Belkin (F5D7231-4) Wireless Router
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
134 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
