Question about Gateway Computers & Internet
MY LAPTOP WENT TO GATEWAY IN TEXAS TO GET FIXED. I NEED TO LET SOMEONE KNOW THAT EVERY TIME NOW THAT IT WAS WORKED ON THE COMPUTER OPENS IN A DIFFERENT WAY .ALSO IT MAKES A NOISE THAT IT NEVER MADE BEFORE ALMOST LIKE A SOUND OF SOMETHING UNDER THE KEES HUMMING OR TURNING AND OR SPINNING DON'TKNOW HOW TO DISCRIBE. THE BATTERY DOESN'T HOLD A CHARGE NOE IT DID WORK BEFOR I SENT IT AWAY !
  • 749 Answers
The battery you will have to replace, but you can test it in your controll panel options marked battery.
there are only so many moving parts in your computer to make noises. here are the ones that make the most noise.
FANS - on motherboard, inside case, in the power supply and on video cards (these and the metal pieces under them should be cleaned monthly or bymonthly with canned dry air. they are the #1 noisemakers in the computer and can be replaced inexpensively and without too much effort).
CD/DVD drives - will make noise when the computer starts (moreso, if a cd/dvd is in them), also anytime you are using them.
HARD DRIVE/S- will make a little clicking noise anytime at accessing information which is about 3/4 the time your computer is on.
If either the hard drive or cd/dvd rom is making grinding noises, it's a good indicator that they need or will need to be replaced soon. ALWAYS KEEP A BACKUP OF IMPORTANT FILES ON cd/dvd OR flash drive.
KEYBOARD-no moving parts besides keys and buttons- if you are hearing something from the keyboard besides an electronic click when the nunlock kicks on, you might have something living in there. but keyboard are easy and inexpensive to replace.
MONITOR - it will click , flash then come one when the computer or monitor is turned on, also will make clicking moises if it changes modes or resolution.
You have this listed in the DESKTOP section and ime pretty sure your refering to a laptop. Please correct me if ime wrong. I hope this will lead you in the direction of fixing it.. Please post more here if i can assist you further..
thank you for using fixya.
Posted on Oct 29, 2008
What is the address to the emachine material review center in temple, texas 76504?
http://www.my3cents.com/showReview.cgi?id=61214
Did find this on FixYa, however,
Acer Repair Center
10986 N.W. H K Dodgen Loop
Temple, Texas - 76504
(Acer bought Gateway, and eMachines )
Regards,
joecoolvette
This is for warranty work right? Just for my edification, what is the problem with the eMachines computer?
What is the model number?
Back of desktop computer next to Windows product key, (Usually), or up on side of computer tower.
Bottom of laptop.
Dec 19, 2012 | eMachines Computers & Internet
My Gateway ZX4300 screen is not working. The screen does not turn on at all but the fan is working and the hard drive is as well.
gateway zx4300 black screen fix
i think i might have found a fix, if you know how to fix the xbox with the fan trick this one will sound close to the same.
if when you turn the computer an you get nothing not one bit of color or brightness from the screen this is your fix, well it worked for me.
i am not responsible for any more damage you might encounter, this does require disassembly
1. take the computer apart until you have the fan and heat sink in front of you.
2. remove fan and heat sink from mother board.
3. (at own risk) with computer open an heat sink off plug in the power cord and turn the computer on.
4. leave computer on for 8 to 10 mins.
5. turn computer off after 10 mins remove power cord and re install heat sink and fan.
6. hold pwr button down for 15 sec.
7. plug computer back in and you should now have your screen back.
this method worked for me i am using the computer with the bad screen to type this up an has been restarted a couple times an is still working fine! hope this works for you!!
Aug 11, 2011 | Gateway One ZX4300-41 (PWGAW02017) 20 in....
My monitor which is a gateway will not come on it says no signal. I was wondering if this has something to do with my label flash dvd thing not ejecting? i have taken it apart and tried to open it but you...
Very likely not related at all. Make sure cable from monitor is securely connected to the computer. If it is, try connecting it to someone else's computer to see if it works there. If it does your computer has a problem, probably hardware, a new video card might fix that. If the monitor doesn't work on the other person's computer then the monitor will probably have to be replaced. Good luck.
Feb 23, 2011 | Gateway GT5692 Desktop Computer
Gateway Profile 5.5 Randomly Shuts Down
it seems, You can try after disabling firewalls. please let me know the results. I can guide you.
Jul 02, 2009 | Gateway Profile 4 All In One (MPN...
Gateway crashed used disks to restore. Everything works except no
if you don't have the correct audio driver on your recovery discs and can't find them on gateway's web site there's one other thing to do - make sure you are current with your windows updates. in most cases i've seen, driver updates for most devices will be included in these updates - i rely on it a lot of computers i work on, especially gateways since they are annoying to find drivers for.
hope this helps
Jan 16, 2009 | Gateway DX300X PC Desktop
Hello, I have a Gateway MT3419 computer that works almost perfectly; the screen is a big problem. Works well, then suddenly goes dark. Can still see images on the screen when tilted towards the light....
Deffinitely worth fixing and be happy it will only cost $200 or less to fix.
Next time make sure you get the extended warrenty, there are 3rd party vendors such as found on amazon that covers this sort of thing.
Sep 25, 2008 | Computers & Internet
Computer not letting me open or close anything.
In some cases, the motherboard causes the screen to go blank and not load any program. Thats what happened to my HP Laptop. I called the company and explained them that nothing will load up and the screen went blank and they replaced the Motherboard.
So In tis case I think You need a new Motherboard.
Thank You and have a Great Day!!!!!
Jun 23, 2008 | Gateway 504GR PC Desktop
Computers & Internet Logo
78 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
