Question about Philips GoGear SA5285/37 Digital Media Player
Battery How do you get the back off of the MP3 player to change the battery? My battery has gone bad it won't stay charged.
  • 8,596 Answers
That battery wasn't meant to be replaced. 90% of the time, I have seen battery replacements fail to resolve the issue. Do yourself a favor - don't be like the other idiots here - skip the DIY stuff, call Philips, and get an in-warranty replacement if you purchased it in the last year. As far as getting the back off the player - you have to use a tiny screwdriver - what else can we tell you? Taking apart your mp3 player will void any warranty you have, so don't even try it.
-Tha Mp3 Doctor
Posted on Mar 18, 2009
Hi I just recently charged up my mp3 player after a long time it's charged but lock screen won't come off I hit the reset still no success
Hello if you see light the back light turned on and see nothing on the screen that mean the frame-wire is damaged and you need to buy new mp3. Or maybe the battery is not working change it as soon as possible and explain to the shop what is the problem. Please rate my comment
Nov 20, 2011 | Samsung Napster YP-910 MP3 Player
Sony walkman Sony Walkman Bean NW-E305 (512 MB) MP3 Player won`t charge
Good morning, afternoon, evening or night; whatever time of day you are reading this solution post. Thank you for choosing FixYa to assist you with your problem. Your Sony Walkman Bean NW-E305 (512 MB) MP3 Player won't charge properly? Well Danish, we must use a method called troubeshooting to figure out and solve this situation. There are several reasons why this player may not be charging properly. The cause is either coming from the battery inside of your MP3 Player, a bad or faulty USB cable connection, or something (software) isn't installed correctly. Let's look at the first cause- The battery. The battery life may be gone. If it is, you will need to replace it if possible. Your device takes a
Sep 26, 2011 | Sony Walkman Bean NW-E305 MP3 Player
I changed the language on my vl-567 mp3 player from visual land and ever since that happened my mp3 screen has gone white and never went back.
Refer from the device user guide to attain diagnostics. also normally the device may need reinstallments, charging or changing batteries, or power restarting to capture new effects.
Jul 21, 2011 | Visual Land VL-567K Digital Media Player
My onxy mp3 player won't charge despite being plugged into my USB port for hours
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 13, 2011 | Mach Speed TRIO Onyx MP3 Player
I have an RCA mp3 player M4304 and the battery says full, but it shuts down and reads "low battery" after 10 minutes. Can the battery be changed? If so, how?
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Jul 11, 2011 | RCA M4304 Digital Media Player
I have a rca M4304 mp4 and it will not turn on unless i plug it to the charder and when i unplug it it truns right back off
Ifthe MP3 player battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 27, 2011 | Audio Players & Recorders
I'm trying to charge my sansa fuze battery. I plugged it into the USB port of my IMAC, but the charge meter on the fuze never changes, it stays with the same charge. Do I need to do something else?
Battery : Remove the back and check and see if
the battery isn't fully connected I put a folded peace of paper and put it on top of the battery and put the back on.
Jun 15, 2010 | SanDisk Sansa e260 MP3 Player
Barbie mp3 quit working
You have to change the battery. To do that you have to take that thing off on the back of the MP3 player and unscrew it to change the battery.
Mar 05, 2009 | Mattel Barbie Girls MP3 Player
Recharging mp3
Whenever the PD-6070 is connected to a PC, it will charge. The battery indicator on the OLED screen will slowly fill over and over as it is charging. When the charging is complete, the battery indicator will stay filled.
Jan 18, 2008 | MyMusix PD-6070 MP3 Player
Philips GoGear SA5285/37  Digital Media Player Logo
196 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
