Question about Krups Stainless Steel Electric Kettle Electric Kettle
My Krups Electric Kettle has developed a gray sludge buildup
Have used kettle for 3 years but all of a sudden there is a gray sludge inside kettle. What caused this and will kettle be safe for use when sludge removed?
  • 279 Answers
SOURCE: krups kettle explosion???
go to krupsusa.com customer service
Posted on Sep 18, 2009
SOURCE: krups electric kettle leaks
You cannot fix it when they split like that.
Posted on Apr 01, 2010
SOURCE: Broken glass kettle
buy a new one
Posted on Jul 18, 2010
SOURCE: how do I clean
Fill kettle until 3/4 full with 1 part vinegar and 2 parts water. Boil and allow to stand overnight.
Empty solution from kettle. Fill the kettle with clean water, bring to boil and discard water. Repeat and the kettle will be ready for use.
Or you can use a proprietary kettle descaler, which is available at most hardware stores.
Posted on Sep 16, 2010
SOURCE: Krups electric kettle keeps shutting off
Buy a new one. Take the defective one, repack it in the old box and return it with the new receipt. Av a cup o tea.
Posted on Dec 18, 2010
My pot has a slow leak. I have tightened all the screws and bolts on the bottom and it still leaks or seeps.
I was successful at fixing my Krups Electric Kettle for $4. In my case the water was leaking from bottom somewhere close to the heating area. I think that a small hole was created in the seal around the heating area in the bottom of the inside of the kettle. One can try to find the general location of the leak by putting a small amount of water in the kettle, place the kettle in a larger pan, and tilt the kettle so that the water is slightly higher than the heating area in one area only noting the position where the water level is the highest. Leave it for a while and check for leakage. If there is none, rotate the kettle a few degrees and look again for leakage from the new area until you find the area where it is leaking. Alternatively you may wish to put a sealant around the entire area, 360 degrees, around the top of the heating area. You will have to remove the strainer first to get your hand in the kettle to apply the sealant.
I went to my local hardware store and looked for sealant that were:
1. Potable (ie safe since you will be using the water for coffee, tea, and other applications that you ingest).
2. That will withstand heat up to at least 250 degrees Fahrenheit. Remember that water boils at 212 degrees.
I found epoxies that required mixing two compounds but decided that this would be difficult to deal with and apply. In the end I bought "PC Plumbing Epoxy Putty" from PC-Products. This met both requirements and was easy yo use. You take the putty and roll it between your finger just like you did in kindergarten with the clay and make a thin string that you could position in the crevice around the top of the heating area. You may either cover the area where you found the leak or the entire 360 degrees. You will note a somewhat foul smell of the putty. The manufacturers says that it will cure in 3 hours. I found that the smell went away when it completely dried and hardened after 3 weeks!.
I will assume that the same solution is applicable to leaks in other areas of the kettle. I have also found that there are equivalent electric kettles much cheaper than Krups. I would certainly check the construction to see if there is one with less of a chance to develop a leak.
But the bottom line is that it cost me $4. I just finished testing the Electric Kettle and it is fine, not leaking, and the instant coffee did not have any bad smell.
Meir Elazar
Feb 12, 2011 | Cuisinart CJK-17BC Cordless Electric...
Water is leaking from the bottom
I was successful at fixing my Krups Electric Kettle for $4. In my case the water was leaking from bottom somewhere close to the heating area. I think that a small hole was created in the seal around the heating area in the bottom of the inside of the kettle. One can try to find the general location of the leak by putting a small amount of water in the kettle, place the kettle in a larger pan, and tilt the kettle so that the water is slightly higher than the heating area in one area only noting the position where the water level is above the heating area. Leave it for a while and check for leakage. If there is none, rotate the kettle a few degrees so that you have a new high point and look again for leakage from the new area until you find the area where it is leaking. Alternatively you may wish to put a sealant around the entire area, 360 degrees, around the top of the heating area. You mayl have to remove the strainer first to get your hand in the kettle to apply the sealant.
I went to my local hardware store and looked for sealants that were:
Meir Elazar
Feb 11, 2011 | Braun Kitchen Appliances - Others
The kettle leaks at where teh handle attaches at the bottom
Join the club ---I'm taking ours back this afternoon to BB&B. It's still under warranty and we have the receipt.
Nov 14, 2010 | Krups FLF2 Cordless Electric Kettle
My Krups FLF2 kettle leaks at the bottom of the handle
This is a known issue with Krups kettles. If you are a handy person then you can remove the base and use a high temp gasket maker (auto shops have it) to add to existing silicone seal which goes bad after a couple of years.
Jul 16, 2010 | Krups FLF2 Cordless Electric Kettle
Krups kettle leaks at base of pot
Unfortunately it's unfixable. A few recent Philips models do it as well and it's worst in hard water areas. Basically the cause is that a tiny bit of water gets into the bottom seam each time the kettle is used and leaves a residue behind when it dries out. Over time, the residue builds up and forces the seam apart so the leak gets worse.
All you can realistically do is hope that it's still under warranty and demand that Krups replace it, preferably with a different model. If they won't then you may have to exert whichever consumer rights exist in your country, but one way or another you need to stop using your kettle (it's dangerous!) and replace it with another.
May 21, 2010 | Krups FLF2 Cordless Electric Kettle
Krups electric kettle leaks
Apr 01, 2010 | Krups Stainless Steel Electric Kettle...
The heating element in Krups stainless kettle has burned out
the element is avilb on the web / look under small appliances / or better yet use your model # and google it . the cost of element and shipping may be more than your pot is worth . you be the judge . i would fix it but / it may not be cost efective .. hope this hepls **** ..
Dec 23, 2009 | Krups Stainless Steel Electric Kettle...
How do I clean
May 16, 2009 | Breville SK550XL Electric Kettle
Krups kettle explosion???
Oct 11, 2008 | Krups 848-70 \ 848-42 Aqua Control...
Krups Stainless Steel Electric Kettle Electric Kettle Logo
59 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Mike
ArcFlash
Level 1 Expert
Oloyede Monsuru
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
