Question about NEC Computers & Internet
No video signal
I recently purchased a used NEC Multisync LCD 1565 monitor. While connected to a PC and when the monitor and PC are powered up the LED light goes green on the monitor and the screen flashes a solid Blue Color. Then during the boot up process the screen flashes a solid green color and then goes black, but you can determine that the back light is still lit. I have tested the graphics card wth another monitor and it is working just fine. With the unit not connected to a PC and powered up the same solid blue screen flashes, then approximately 10 seocnds later the solid green screen flashes and the monitor goes into a standby mode with the LED light changing to a orange color. Unfortunately, I am unable to have the monitor on screen menu display in order to reset to the factory settings. Any suggestions on how to proceed?
  • 11 Answers
SOURCE: Power on Green but no display (blank screen)
In the LCD1830 the inverter for the backlight always burns out. They are fairly easy to replace when you remove the back to get inside. A new one is available from MoniServ for $69.99. http://www.lcdpart.com/Products/uhp061104mss.html
Posted on Apr 07, 2007
jerryg50
  • 1689 Answers
SOURCE: Problem with an NEC MultiSync 1550V 15" LCD
The power supply section may be failed, or there may be a short on one of the boards causing the monitor to cycle through the protect mode.
Jerry G.
Posted on Jun 03, 2008
PaulRepair
  • 66 Answers
SOURCE: NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 02, 2009
SOURCE: touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
Posted on Jul 04, 2009
PCTechOnline
  • 532 Answers
SOURCE: how do i get power to the multisync lcd 1565
The power button is the top button on the right side of the monitor.
Posted on Nov 17, 2009
Xbox360 to NEC Display NEC MultiSync PA271W
You need a DVI to HDMI connector. You will need to connect the audio separately to your sound system as DVI does not support audio.
Dec 02, 2013 | Nec Display NEC MultiSync PA271W-BK - LCD...
In a move my NEC MultiSync 5FG monitor got disconnected from its BNC cable (5 BNC). Now I don't know which leads connects to which ports. Can anyone help?
The cable should be labeled with R (RED video signal), G (GREEN video signal), B (BLUE video signal), V (Vertical Sync signal), and H (Horizontal Sync signal), so you just have to match the plug to the sockets.
I hope it is clear explanations.
Dec 31, 2010 | NEC MultiSync 5FG (White) 17" CRT Monitor
How do i get power to the multisync lcd 1565 monitor
Nov 17, 2009 | NEC MultiSync LCD1565 (Black, Silver)...
Nec Multisync LCD 195VXM+ black screen after turning on computer
I'm thinking your video card is sending a signal the monitor doesn't recognize.
You'll need to start the computer and hit F8 until you get the black and white menu. Choose the VGA mode and it should work well enough for you to adjust the refresh rate or the resolution to get the monitor to work
Aug 28, 2009 | Computers & Internet
CRT Monitor power led is green then becomes yellow. The monitor is blank or black. Pls. help.
Signal from Pc is weak and may indficate a failing video card or a loose connection
Aug 02, 2009 | NEC MultiSync FE700M (White) 17" CRT...
Touch system not working NEC multisync 1550v
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
Bought a new computer. Getting no signal from my multisync 1700V
check the device manager and see what it says for the monitor...I know you can press CNTRL+ F5 for monitor selection , try this if everything is good in device mngr
Apr 13, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
What cable do I buy
If it is a dvi monitor then you would need a dvi cable. VGA monitor would need a VGA cable. HDMI monitor would need a hdmi cable. If it is compatible with both dvi & vga and your video card has a dvi output then dvi is a better quality than vga. You can purchase the cable online at a store like cables2go. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | NEC MultiSync 1525X 15" LCD Monitor
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
Computers & Internet Logo
60 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
