Question about Cannon i70 Printer
Variable ink darkness
Every other line prints dark then light. And some lines appear wavy. If line 1 is dark, so is line 3,5,7,9, etc. And lines 2,4,6,8, etc. will be light. We use the printer almost every day to some degree. We have replaced ink cartridges. No change. We did deep cleaning and ran out a black ink cartridge. No change.
  • 24 Answers
If the printer has been used exrensively then its probably the printhead that needs replacing. The i70 printer uses a QY6-0046-000 Canon Printhead Printheads are available from many sites on-line and thru PC World
Posted on Dec 31, 2006
Printing with horizontal dark lines
Did the dark lines start after the change? If so, maybe the drum on one of the cartridges is damaged. (Since you mentioned dark, I'd suspect the black cartridge.) Try replacing cartridges.
If that doesn't fix it, you can send it in for repair if it's under warranty. If it's outside warranty, I'd probably just replace it, unless you want to learn a lot about the innards of a laser printer.
Apr 21, 2015 | Dell 3110cn Laser Printer
SHARP M455N PRINTING LIGHT
The ink toner is is now infected by foriegn matters by effecting the printer laser head.Tries air compressor machine blow out the ink toner print head ink injector and laser printer print head.Wait about and hour reinstall the the ink toner to the printer,the toner should work find again.Not the ink toner is not saveable,must have be replace for normal operation again.
Mar 18, 2014 | Sharp AR-M455N Copier
DARK LINES/SHADES APPEARING ON BACK OF PRINTS
when the print-out shows lines or streaks on the back of the paper when printing single sidedly, this usually means that the fusing unit is dirty or broken. another possible broken part may be the photoconductor unit.
Apr 20, 2010 | Canon iR 2016i Black and White Copier
Dell 3110cn - getting grey tint and wavy lines
It sounds like you have leaky toner or the imaging drum needs to be replaced.
Feb 17, 2010 | Dell 3110cn Laser Printer
Schiller machine is not printing
If the unit print lightly or not printing anything at all?
The most common causes for not printing ECGs is one of those:
1- Too little heat on the stylus
2- Insufficient stylus pressure on the paper
Solutions:
1- Using an insulated probe, such as a screwdriver, gently press the stylus onto the paper.
2- If a dark line appears on the paper, the problem is too little pressure, but if no dark line appears, the problem is not enough heat.
Jun 19, 2009 | RTO Schiller CARDIOVIT AT-1...
MY PRINT OUTS HAS LINES
your printer has either:
1.low ink
2.the movement of the in slider is to slow
3.the paper is going too fast when it is printed
i sugesset you either take it back (if its new) ,or get a new printer
Dec 31, 2008 | Fargo Persona C11 Thermal Printer
Dark vertical lines on printed photos 18cm apart
Remove the cartridge and put it back in. If same issue persists, try to do head cleaning and nozzle checks simultaneously from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on those patterns appears, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Dec 24, 2008 | Epson Stylus Multifunction Inkjet Printer/...
108 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Clive
Clive
Inky Fingers
Inky Fingers
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
