Question about Goodman GMS90703BXA Heater
Goodman GMS80903bha Blower mtr cuntinues to run after i disconnect the thermostat.also ohmed out the rool out switches.
    Problem Solver:
  • 22 Answers
Did you check high limit or safety switches?, was the filters plugged?
Posted on Nov 03, 2008
How do i fix AC Dolcool split type, Model KF61G, compressor not working. Breaker keep tripping.
It sounds like compressor is shorted,check ohms from compressor terminals to copper,clean area on copper.if it reads ohms,short,if not I would start by disconnecting outdoor MTR,indoor MTR,& see if still tripping
May 07, 2015 | Refrigerators
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Goodman furnace GMT115-5B Turn fan to on on
Bypass the tstat first but that's where I'd be leaning.
Aug 14, 2017 | Goodman GMS90703BXA Heater
Goodman model PGB036075-1B when I turn on the heater the blower starts soon as the burnner starts about 2 sec. later the blower stops. then of course it overheats. What would cause the blower to shut...
bad blower motor run capacitor and or motor. Test capacitor or just replace in expensive if dont have test meters. If change motor make sure get new matching capacitor for new mtr.
Nov 15, 2012 | Goodman Heating & Cooling
Goodman GMH950904CXAC with white rogers programmable stat. Turn the furnace on and the blower comes on whether there is a call for cool or not. Red led on control board is on, indicating OK. Disconnect...
make sure the blower is not set on rather than auto or the blower will run all the time. You might want to disconnect the thermostat and test the low voltage circuit to make sure the wires are not shorted
Aug 12, 2009 | Heating & Cooling
Goodman a/c blower fan will not shut off
Unhook the thermostat wires on the furnace. If the blower shuts off then your problem is either the thermostat or the thermostat wires. If it contiues to run check you high limit switches next. If all else fails you most likely have a bad blower relay. On most modern furnaces the blower relay is part of the circuit board.
Good luck
Mar 29, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman GMP050-3
If you do not have two furnaces hooked together, you have a bad circuit board or an improper ground or neutral wire.
Dec 09, 2008 | Goodman GMS90703BXA Heater
Goodman Furnace Intermittent
Does this piece, have an economizer and or vent draft options installed? I hope not. If not, I had the same sort of problem with a Payne unit, sort of the same style. First things first. bypass the thermostat by making a jumper or connecting the red to the white wire on the thermostat, see if that stops the problem. Repair techs are all to anxious to replace the board anymore. If the repair man installed a relay to bypass the blower control he is in over his head, the limit switch determines when the fan shuts on & off based on temperature. There is a relay on the control board that basically carries the load for the motor. Dont have anything else installed that need not be there (there is enopugh crap already from the factory) If you want to really fix this I need to know if you have and can read a volt/ohm meter and can understand a wiring diagram, hopefully yours is still there. let me know after the thermostat thing and I can walk you through this.
Dec 25, 2007 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
55 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
