Question about Kenmore Elite 45986 Front Load Washer
Drum Tilt My washer made a loud bang then the drumis now tilteddownward toward the back of the machine. The machine still runs but does make a banging noise while spinning.
  • 5,911 Answers
Your spin basket spider arm support on the back of the spin basket is broken. The spider arms support the entire weight of the basket and insert into the tub bearing in the back of the washer. You will need to replace the spin basket (stainless steel tub) in order to fix this problem. The tub is not repairable and cannot be welded, either (I have been asked this question before). I would not recommend you use the washer any longer as it will cause further damage to the outer tub shells. If you have a repairman perform this job, it can be quite expensive (around $300, $400, perhaps higher), because of the labor involved. Some smaller appliance repair companies won't touch a job like this. However, the washer is repairable, and you can perform this yourself. If you wish to accomplish this on your own, I can give you step-by-step instructions and where to order a new tub. Let me know if you want my assistance.
Posted on Oct 29, 2008
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
WMA30 Front loader
when a machine gets old it is always normal for the vibration and banging to occur, then, after the vibration it settled down smoothly.this is due to worn fan belt .bearings worn out and the preasure on the spindle.so dont get alarm .but you will soon have to replace the washer as the banging and the vibration will get worse eventually.or change the fan belt.and replace bearings.which can be done by a qualified personel.good luck.
Jun 09, 2007 | Hotpoint WMA30 Front Load Washer
Loud banging noise Kenmore model # 41744102301
Hello,washing machine is mounted on two supports, if it is damaged first which is where the engine so both need to be replaced because they wear out. If you're just a little handy so you know it himself .Ak you order parts so precisely that type because they are different .
May 02, 2013 | Washing Machines
Machine is making an extremely loud banging sound think the blocks come loose. How do I fix this what will I need ?
your washer is off balance the inside of the washer is banging the outside wall you can pull it towards the back of the machine and it should slide back into place...
Nov 10, 2011 | Samsung Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Washer works fine till it gets to the spin cycle, makes very loud bang bang bang like it's going to blow up, did find two brass pins under the balance plates in a small cup that it droped down into, lined...
those are shipping pins pull them back out,check the tub springs,also the triangle the tub sits on has 3 pads it rides on check them also,somebody has bypassed the lid switch,it's ok,let me know what you find-mike
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Banging while spinning
slid the machine out away from the wall and tilt back enough to see underneath. just below the door there is a large concrete weight. chances are it is loose and needs to be tightened. if this problem has been going on for a while the bolts holding the weight on will have snaped and the drum/weight or both will need replacing . ( ex hoover engineer)
Nov 13, 2007 | Hoover SE230 Front Load Washer
Loud bang during spin
Remove the top of the machine and check if the centralising spring/s is/are still attatched. Next remove back cover or tilt machine back and inspected the shock absorbers. One of the shockies could be broken or just pulled out of the guide. If springs and shockies are ok open the door and try to move the inner drum up, down and sideways. If it is very loose, then the centre bearing is worn.
Oct 27, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
415 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
