Question about Norelco SmartTouch 9160XL Electric Shaver
Fallen apart shaver
I have a norelco smart touch 9160xl razor and as i was opening it up to dump the hair out, the top fell off, including the blades, the heads and a three hole triangular piece. I do not know how to reassemble this so i need help fast because i am in college so i really can't afford a new one and i have to keep clean shaving for the ladies, you know.....anyways, i was wondering if i could get help with this.
    Problem Solver:
  • 4 Answers
This has happened to me several times. You just slip the metal tab sticking out of the blade assembly ( the flip up part} back in the slot until it snaps in to place.
Posted on Aug 31, 2009
How do I take apart razor to lubricate the motor?
Oster Classic 76 hair clipper - take apart to clean or fix ...
? 9:53
https://www.youtube.com/watch?v=nu8UaoCxtxo
Feb 20, 2010 - Uploaded by darwincollins
It is an amateur video demonstrating how to take apart a Classic 76 clipper. ... your clipper with Oster Kool Lube 3 Clipper BladeCoolant Lubricant Cleaner. .... Motor did not slide out but all wires shredded and motor was in pieces ... What's that little button just below the '76' for and how do you know exactly ...
MOTOR TEST Checking the motor on broken Hair clippers ...
? 0:32
https://www.youtube.com/watch?v=TaWUxcdGBSg
Mar 29, 2015 - Uploaded by You can Fix It!!!!
Testing motor on shears clipper trimmer razor shaver. How doyou know if the blades or motor are brok... ... oils oiling oileddisassemble disassembling take apart taking apart .... 3:21. How To ' Change Cord ' Change Switch ' How To Repair Wahl Clippers ' - Duration: 2:24. by ronsclassickuts 13,453 views.
How to sharpen a Norelco electric shaver - Instructables
www.instructables.com/.../How-to-sharpen-a-Norelco-electri...
InstructablesYou will need a small brush to clean shaver and heads, also a flat piece of ... I then take a tool I made from a broken Norelco razor and a writing pen which ... Mix a 1;3solution of White toothpaste [1] and Mineral Oil [3] on the back of a ... Disassemble[keep the screens & blades mated] and spray with Bathroom Cleaner. 5.
Taking Care the Right Way to Keep Electric Razor Like New
Dec 06, 2015 | Health & Beauty
I have a norelco arcitec shaver and the heads no longer turn. I haven't had it that long so of course very disappointed with the razor. I would like to take it apart to clean it, thinking there may...
You are problable correct in thinking that the blades are clogged up. Unfortunately, you are also correct about the terrible design. The blades on Arcitec models can not be removed from the head assembly for cleaning
complaints can be made to Noreclo at 1-800-243-3050
Replacement head assembly can be purchase from shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
May 10, 2011 | Health & Beauty
I installed 3 new heads but the shaver just is not shaving off my 5 day old beard... It's battery seems fine as the motor seems to be running at normal speed. Confused Carl
Your Norelco shaver is not designed for cutting 5 days of growth. Your shaver is designed for cutting one, maybe two days of growth only. Use the trimmer on the back to cut the whiskers to a shorter stubble. Then the hairs will more effectively poke through the holes and slots in the combs allowing the blades to shave them as designed.
May 08, 2011 | Norelco SmartTouch 9160XL Electric Shaver
What part can i submerge in water when cleaning the blades?
Even though it has water resist body,like some wristwatches , You are not suppose to submerge it ,to clean just try to keep it under the pouring water in faucet ..
To clean deeply,You can take the Razor Heads assembly out and leave it in cleaning solutions overnight. (please do not disassemble of the blades of its main frame )
My regards.
Oct 06, 2010 | Norelco SmartTouch 9160XL Electric Shaver
My razor appears to have died even though the LED
Usually the batteries last only a few years before needing replacement. Rechargeable batteries are good for only so many cycles so you've done well to go 8 years. You can replace the batteries if you're handy with a soldering iron - I've done it many times. However, with 8 years on the clock you'll probably want to replace the blades too. The batteries are about $10 for the pair (AA rechargeables with solder tabs) and the blade set is about $30 so you're approaching the cost of a new shaver already. Here's a link - you'll need two.
http://www.zbattery.com/NiCad-AA-1000mAh-Rechargeable-Battery-with-Solder-Tabs
Apr 18, 2010 | Norelco SmartTouch 9160XL Electric Shaver
How i clean my razor
I have this razor as well. Just flip the heads open, dump the hairs in the garbage and rinse the heads (while open) under hot water. Keep the heads open until dry and close on up.
May 20, 2009 | Norelco Arcitec Electric Shaver -...
Norelco SmartTouch 9160XL Electric Shaver Logo
247 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
