Question about Casio Parts Cash Register PC Desktop
E04 Suggested solution to flag clear has not worked. Register still saying E04 and beeping after pressing every button. What can be done to get rid of this error? Thanks
  • cbd232 Oct 29, 2008
    its a ce-3700 and there was no print out after flag clear, just beeping and error 04.
    We have unplugged the machine and resorted to an old one. Have contacted Casio for help and said the batter might be dead.
    Thanks anyway :)
  • Anonymous Nov 29, 2008
    I did the same thing, I pressed clear, but it did not solve the problem.
  • 737 Answers
Hi. What was your model number?
Also, when the machine printed out after the flag clear, there should have been a big number printed at the bottom (usually with the word INIT or FC). Can you tell me what the number is? If you no longer have the printout, just flag clear again.
Mark
Posted on Oct 29, 2008
  • flexion1
    flexion1 Oct 29, 2008
    Hi. Yes, I'd say the battery has either failed, or gone flat from being left off for too long.
    I helped someone else with the same problem. The complete solution is here.:
    http://www.fixya.com/support/t941086-cas...
    If the codes mentioned don't work for your version, just let me know.
    Mark
My sam4s er-180t cash register wont respond it just beeps and comes up with E00
try to do an 'initial clear'
turn power switch on right side of reg to OFF pos
turn control lock to P position
press and hold SBTL key and turn power switch to ON pos
should print 'Initial clear ok'
might need to repeat a couple of times
Jun 22, 2014 | Sam4s ER-180T Cash Register
Screen has frozen Casio qt 6600
flag clear the till, and try again,
if it is a long report the till will stop and then start
flag clear power off the till on the side
hold the button down at the front
power on the till
press the ok button
then after 30 sec to 3 min
press yes
Feb 09, 2013 | Casio QT-6600 Cash Register Touchscreen...
I have just baught a second hand casio TE8500f cash register and every time i turn it on it displays init 1.flag clear 2.init2 and every button i press it then displays operator mistake
Highlight "flag clear" and press YES button. If it still does not work, you have a flat or (usually) faulty memory battery and it will need to be RAM cleared then re-programmed.
If anyone needs more informaton on the Casio TE-8000f or TE-8500f, the manuals are here:
Programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-7000S_and_TE-8000F_and_TE-8500F_programming_manual.html
Service (repair) manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-7000S_and_TE-8000F_and_TE-8500F_service_version_2_manual.html
Feb 11, 2011 | Casio Parts Cash Register PC Desktop
I have casio ce-3700 cash register and i have problem E04 and noies come beep any one help me plz.
This is caused by incomplete initialisation. it means the program may be corrupt from being unplugged for too long, or you may have a bad battery inside the machine (change it every five years).
Firstly, try a flag clear to jump it back to REG mode:
Turn power off at wall Turn key to program position Hold down RECEIPT FEED button. Keep your finger on it. Turn power on at wall Wait 5 seconds, then let go of RECEIPT FEED Press SUBTOTAL
Turn key back to REG mode and try it. If the programming is corrupt, you will often see the decimal point in the wrong place.
If you want to re-program it, there is a manual for the CE-3700 here:
http://the-checkout-tech.com/manuals/TOC/cashregisters/Casio/CE-3700%20operators%20and%20programming.TOC.pdf
Aug 26, 2010 | Casio Parts Cash Register PC Desktop
TE-8500F says Device ID Not Set when I try to use Credit
I have a few questions.
1. where did the Datacap come from, or was the register programmed to use the datacap?
2. there is a place in pgm3 wheere you assign devices, its called I/O and in there you have to enter the right codes for it to work. Also after its been installed you must do a FLAG CLEAR.
3 To do a flag clear on an 8500 on the right side turn the machine off hold down the REC FEED button. While holding down the buton turn the machine back on and wait till the screen comes back and press subtotal. after that it will go through a bunch of funny looking stuff and the it will come to screen where it asks if you want to flag clear or init 2 use #1 flag clear and press yes. sign on and test.
Chris
May 15, 2009 | Casio Parts Cash Register PC Desktop
BT XD5500 manual
BT Freelance XD 5500
Resetting the base & handset/s on a BT Freelance XD5500:
Hold the Find button on the base unit until you get a double beep then
tap the Find button 7 times.
On the handset:
remove a battery
hold the menu key and refit the battery
screen says SW VERSION
press up arrow key until screen shows REGISTER CLEAR
press menu
press menu again and wait for OK to appear
remove a battery and refit
Registering the XD5500 handset.
Then register the handset to the base as follows:
Hold Find button on base unit until you get two beeps
On handset:
Press menu
Scroll to register
Press menu
Scroll to Register Base
Press menu
Press 1
Wait
When it says PIN ? Enter 0 0 0 0 (four zeros) and press menu.
Note:
If you have more than one handset then repeat registering the handset to the base for each subsequent handset/phone.
If this procedure fails to solve the issue, then you have a unit with a
fault and if it is less than a year since purchase the retailer should
change it for you.
Aug 03, 2008 | Lands Phones
Casio CE-3700 cash register MAC instructions
Hi. I would advise both of you to try a flag clear first to see if you have any program left.
Turn key to program. Power off at wall.
Hold RECEIPT FEED, and turn power on at wall.
Wait 10 seconds, then let go of RECEIPT FEED.
When you see 'FFFFFFFFF' press SUBTOTAL.
Turn key back to REG and try it.
If you still need help, let me know.
Mark
Apr 15, 2008 | Casio Parts Cash Register PC Desktop
Innovage Gear wristwatch beeps every hour
To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Mar 11, 2008 | Watches
Casio cash register not working
error code 1 on your cash register is due to Mode switch position changed before finalization
you can fix this error by Returning the mode switch to its original setting (does not beep) and finalize the operation
Jan 19, 2008 | Casio Parts Cash Register PC Desktop
Casio te-8500f
With the power switch off, hold down the RECEIPT FEED button and turn the register on.
Continue to hold the button until white text shows up on the screen.
Release the button and press the SUB-TOTAL button.
When the register asks "1. Flag Clear / 2. Something Else", select "1. Flag Clear" and press yes.
This is the Casio ECR equivalent of CTRL-ALT-DEL; it should fix the printer-cycling issue.
Cheers!
Casio Parts Cash Register PC Desktop Logo
279 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
