SOURCE: wat is the region code for a samsung blu ray
Hi, kindly get the code here :
www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__3e5r
SOURCE: I want to make my
Hi
heres how its supposedly done.
1. Ensure that there is no disk in the tray.
2. Switch the player off and then back on. This is necessary to clean-boot the firmware.
3. Wait until the main menu page appears and the player stops doing anything.
4. Press the eject button to open the tray. (The button is between
the "Power" and "TV Power" buttons at the top of the controller.)
5. Press the eject button to close the tray.
6. Wait while the player searches for a disk.
7. As soon as the "No Disk" message appears at the top left corner do the following.
8. Press the REPEAT button - just above the TV channel selector at the bottom right of the controller.
9. Enter 5 7 5 3 8
on the number pad.
10. The region code "2" should appear at the top left corner of the screen.
11. Enter a "9" to make the player region free. (Enter a region code
if you want to lock the player to another region for some obscure or
perverse reason.)
12. Power down and power up again.
13. Play a foreign DVD to verify the change.
Now the tricky bits. This process is timing dependent.
Firstly, you must start entering the code just after the "No Disk"
message is shown and before the message disappears. If you jump the gun
or miss the boat it won't work.
Secondly, the REPEAT key is part of the code. All six keys must be
entered smoothly as "REPEAT 5 7 5 3 8
". The entry gets timed out so you
can't stop in the middle and restart. Don't bash away like crazy, just
do it smoothly and briskly.
If you don't see the "2" the first time, don't worry. Just repeat
the process. It took me about a dozen tries before I got it to work.
region codes are as follows
1 - 2 9 3 3 4
2 - 5 7 5 3 8
--- since your player is locked to 2 you use this code.
3 - 5 6 7 3 2
4 - 7 6 8 8 4
5 - 5 3 8 1 4
6 - 2 4 4 6 2
SOURCE: hi, samsung blu-ray player bd-d6500
There is no current procedure for unlocking the
Blue-ray and it is probably not necessary because over 80% of released
disks are region free anyway. (Just don't ever buy the other 20% and
they will get the message soon enough!)
To change the DVD from region 2 (your current location) to region 9
(region free) follow these steps using the remote control.
9. Enter 7 6 8 8 4 on the number pad.
10. The region code "4" should appear at the top left corner of the screen.
perverse reason.)
or miss the boat (isn't English great!) it won't work.
entered smoothly as "REPEAT 7 6 8 8 4". The entry gets timed out so you
If you don't see the "4" the first time, don't worry. Just repeat the
I can't guarantee that this player does not have a region change
counter so I would be a bit careful about changing regions back and
forth. I also can't guarantee that this will work with all released
firmware. Samsung seems to take this crazy region bastardry very
seriously for some reason.
For people from other parts of the world, all region codes are as follows
1 - 2 9 3 3 4
2 - 5 7 5 3 8
3 - 5 6 7 3 2
4 - 7 6 8 8 4
5 - 5 3 8 1 4
6 - 2 4 4 6 2
If you bought your player in the USA or Canada there might be no way to change the region in these countries as the only Samsung BluRay players we've ever heard about being able to be unlocked (and ONLY for DVD region free playback) were sold in places like Australia and maybe Europe.
Hope this was helpful to you.
Goosluck danteks
Elect_comp
SOURCE: Region Free Procedure for Samsung
In this unit the only thing that can be modified is the region for the dvd, not the one for the BR. Follow this
1. Press RETURN (bottom left)
2. Press the access code corresponding to your dvd zone
1 - 2 9 3 3 4
2 - 5 7 5 3 8
3 - 5 6 7 3 2
4 - 7 6 8 8 4
5 - 5 3 8 1 4
6 - 2 4 4 6 2
3. Your current region code will appear top right of screen, Press 9 to
change to region 9 (no region).
BD media does have region codes. But, unlike current DVD players, the region codes for BD media use letters instead of numbers to indicate a particular zone or region where the discs can be played.
The BD region codes are as follows:
