Question about HP LaserJet 4350 Printer
Printer is displaying 65.12 error - HP LaserJet 4350 Printer
    Genius:
  • 1,605 Answers
There is no 65.xx error code
the following code should help you.
66.00.15 EXTERNAL DEVICE FAILURE
Description
The stacker or stapler/stacker was removed and then replaced with the printer power was on.
Action
1. Turn the printer power off.
2. Make sure that the accessory is properly seated on and connected to the printer, without any gaps between the printer and the accessory. If the accessory uses cables, disconnect and reconnect them.
3. Turn the printer power on.
4. If the error reappears, record the message, and contact HP Customer Support.
Posted on Dec 05, 2008
  • Frank
    Frank Dec 05, 2008
    66.12.XX OUTPUT DEVICE FAILURE For help press?
    Description
    A stacker or stapler/stacker error has occurred. The stacker or stapler/stacker LED is continuously illuminated in amber.
    Action
    1. Press the ? (Help) button for detailed information.
    2. Press the (Up Arrow) button and the (Down Arrow) button to step through the instructions.
    3. Turn the power off.
    4. Verify the stacker or stapler/stacker is installed correctly and that its electrical connector is seated in the connector on the printer.
    5. Turn the power on.
    6. If the error 66.12.03 persists, replace the stapler unit.
    7. If other error messages persist, replace the stacker or stapler/stacker.
    8. If the above action does not solve the issue, contact HP or authorized service provider.
How to fix Error 900.43 service RIP soft ware
Reset Factory Defaults.
1. Turn off the printer.
2. Press and hold and .
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
If that does not fix this issue,With Error Code 900 displayed, press and . Post the complete list of Sub Error Codes on the display.
Jul 27, 2015 | IBM Infoprint 1532 Laser Printer
Canon MX922 printer displaying code C000
Try switching printer off then unplugging the power for 15 or so minutes. If that doesn't work and same error pops up when you turn printer back on, contact Canon.
good luck
Feb 28, 2015 | Canon PIXMA MX922 Wireless InkJet MFC /...
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Printer display says "Printer Error
format your computer, an error on your system32..
Apr 16, 2011 | Epson Stylus NX300 All-In-One InkJet...
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
Feb 15, 2010 | IBM Infoprint 1352 Laser Printer
Ribbon Stall
Printer errors are various messages displayed on the LED display of printers. ... We also carry a lot Lexmark Toner & Ribbons for your one stop shopping experience. ... ERROR 54 - Duplex Feed Error (IID/IIID) or Main Motor Stall 2686 A/D ..... Sharp Printer Supplies, TallyGenicom Printer Supplies, Texas Instruments ...
www.printersupplies.com/errors.html
Dec 03, 2009 | Office Equipment & Supplies
Error message on printer screen
my hp officejet 6310 printer just started displaying cartridge error. what should i do?
May 18, 2009 | HP Officejet 6310 All-In-One InkJet...
I JUST CAN SEE IN THE DISPLAY ERROR LSU. WHAT I CAN DO IT FOR FIX THE PRINTER
Sir I see the error of my printer kindly make me answer for LSU ERROR
thanks
raju kale
Sep 24, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Error message #Oxc19a0013----Ink system has failed
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jul 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP LaserJet 4350 Printer Logo
243 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
