I have a32in.jvc tv model#AV-32f734,after you turn on set screen turns blue then timer light blinks green and set turns green with white lines through it.repairman said mean picture tube is shot.Is this true
  • 375 Answers
SOURCE: No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Posted on Aug 18, 2007
SOURCE: Green screen crash
i have a projection tv. It is a a Samsung HDTV 55" widescreen. There is a green curvey lines at top of screen. Can you help?
Posted on Jan 20, 2008
  • 579 Answers
SOURCE: Tube TV - one thin horizontal line of bright light
Vertical defection failure. Common failure. Pretty easy to repair ($50-75?). However, my general rule of thumb is not to waste any more money on TVs over 10 years old. Too much other stuff in there ready to fail as well.
Posted on Jan 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: JVC AV-56WP74
You would need the service manual in order to change the picture tube properly as there are dangerous voltages stored inside the tube also the tube would have to be set up properly as well. You can get the service manual for your model at the following link. They will email it too you right after purchase. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 28, 2008
  • 2336 Answers
SOURCE: sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Posted on Jun 17, 2008
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
JVC projection TV green timer light comes on, tv turns off
It sounds like your main projection lamp is burned out. They are fairly easy to replace yourself if you can find the lamp at a local repair shop or online. www.projectorlampcenter.com is one, also Fry's Electronics and Best Buy carry a few.
Sep 22, 2009 | JVC LT-40X776 40 in. LCD HDTV
Tv shutting off timer light blinking
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Feb 19, 2009 | JVC AV-27530 27" TV
JVC tv fault
if there are no retrace lines you possible have a video ic fault.
Mar 27, 2008 | Televison & Video
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Tv picture is black, sound is fine
Sorry, no easy answer here. On an older set this would be espected and not worth repairing, but you should take this to a TV shop for troubleshooting. Most likely culprit is the flyback transformer and/or the horizontal deflection.
Hope Ya Fix It.
Jan 31, 2008 | JVC AV-27F702 27" TV
Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
Jan 12, 2007 | JVC AV-32FA44 32" TV
TV turn off itself and won't turn on
Sounds almost like you have a voltage missing on the power supply board. if its a missing voltage a service manual and a multi meter should help ya find whats missing But a shop repair on a set like this could cost a bit as anything over 27" is a little costoly to fix these days. Only way to see is call and say to your self How old is the set? is it the set you really like do you wanna spend 150 to 225 to repair? it up to you. Good Luck
Jun 03, 2006 | JVC AV-32FA44 32" TV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
