Question about Samsung DVD-V3500 DVD Player/VCR
Trys to load and skips from frame to frame
The dvd trys to load and play. I get two or three wiggly frames, then nothing. Counter keeps counting and I get audio now and then. I bought a laser cleaner by Phillips, ran it several times, but same results when I tried a dvd. What do you think?
  • mcpheel Jan 01, 2009
    says loading then makes a whirring noise, worked good for about 3 months
  • 31 Answers
I would try and take off top cover then using q tips to manually clean the lenses dont worry about the laser it is made to move in all directions so go ahead and apply slight pressure when cleaning i usually use a wet one then a dry one to asorb excess moisture.
C
Posted on Oct 29, 2008
Picture turn
The frame count is displayed on the panel atop the camera. See page 21 of the manual: http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Jul 27, 2013 | Nikon N65 35mm SLR Camera
I'm using d-link dwl-3200 ap ( three) Received Frame FCS Error Counts indicate a problem? ___________________________________________ WLAN 802.11G Traffic Statistics Throughput Transmit...
Transmitted Error Count 4734440
Ack Rcv failure Count 15269951
  • As per the above there are error on Transmitting the packet and also for receiving the acknowledge packet.
  • Please check whether any disturbance in the link
  • Each PPP packet has a checksum attached to ensure that the data being received is the data being sent. If the FCS of an incoming packet is incorrect, the packet is dropped and the HDLC FCS count is increased.
  • Another reason for seeing too many FCS errors may be that the remote end has stopped talking PPP.
Feb 27, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
SYNCANISATION OUT
It sounds as if the software is 'dropping frames'
Video consists of 25 frames per second. When capturing video, the computer has to read and compress each frame in real time. If your processor is not fast enough, it cannot keep up and will drop frames.
The problem is it only drops the video frames, not the audio frames, so over time the picture and sound go out of sync.
Make sure your computer meets the minimum specs. for the software. Also close any other programs that are running as this will lighten the load on your processor. If you've got loads of icons in the lower right-hand corner of your screen (these are all progrmas running in the background) close as many of these as possible as well.
Hope this helps,
Matt
May 01, 2010 | Pinnacle Dazzle DVD Recorder
Only 1 game is skipping frames
Please call 1-800-4MY-XBOX for troubleshooting steps.s
Jun 15, 2009 | Microsoft Xbox 360 Console
DVD player skips audio and/or frames
PowerBook G4 is at least a five-year-old machine at this point. A DVD drive can **** in lots of dust in five years. Try hooking up to an external DVD drive. If it plays the same discs with no problem, you need a cleaning or replacement. Frankly, an external DVD drive is cheaper than replacing your internal drive.
Mar 07, 2009 | Apple PowerBook G4 Mac Notebook
Pandigital 7" photo frame won't play video
It appears that the Pandigital 7" frame (7001W01) can only play back videos encoded with the Motion JPEG A codec. The instructions do not articulate this properly and only inform you to use .avi and that video from other sources other than your camera may not be supported. Problem is, not all cameras use MJPEG A to compress the footage. But this workflow will allow you to make any type of video playback on the frame.
Just to clarify - .AVI is not a video format. It's a wrapper that holds the video. The same goes for things like .MOV or .OGM. These are only wrappers. So for Pandigital to say the frame supports ".AVI" does not explain much. It does not support codecs like DiVX or H.264, for example.
At any rate - your best option to get video to play back on these frames is to download MPEGStreamclip from the developer Squared5 (it's free) and use it to convert your videos to Motion JPEG A avi's. I'm not sure about Fixya's linking policy, but you can easily search google for "MPEGstreamclip" and find Squared5's website.
MPEGstreamclip is available for both Mac and PC platforms.
1. Once you have the software, open it and go to FILE -> OPEN FILES and select the video you would like to encode. It will load in the viewer.
2. Next, go to FILE -> EXPORT TO AVI. This will open your compression options for an .AVI
3. The first option you are offered is "Compressor" - this is the most important. Click on the arrow and scan through until you find "Apple Motion JPEG A" Click it to select this as your compression codec.
4. Leave the quality setting at 50% I found that the Pandigital Frame will choke on larger files. We're going to be shooting for a file size of appx 300mb for 3-4mins of video in order to keep things moving. Video data is very large, and the fact is is that this frame is not meant to playback very data intensive files. So you will be best off playing it safe and keeping your bitrate (kbps) low.
5. If your video file has sound, leave your Sound setting at MP3 / Stereo / Auto, but drop the bitrate to 96kbps or 128kbps. Again, we're trying to keep file sizes down and the audio out of the Frame is not great to begin with. If you must have audio, keep it low (96kbps or 128kbps) If your file does not have sound, click the MP3 drop down menu and select "No Sound"
6. Choose your frame size. If your video is 16:9 (rectangle) select 854x480 (16:9) if it is 4:3 (square) select 640x480 (4:3) - Please note, if you are using 4:3 videos, your video will have black bars on both sides of the frame. This is the nature of video aspect ratios. Aside from magnifying your video to fit a 16:9 screen, you will need to have black bars.
7. Check the box "Deinterlace video"
8. Ignore the other options.
Click "Make AVI" and the video will begin to be compressed. As I mentioned, video is a very data intensive process and compression can take time depending on the length and size of the original video. I tested this on files that were 3 minutes and 3 GB to begin with on a MacBook Pro and got the file down to 300mb in 15 minutes using these settings. I repeated this on a PC running Windows XP and had the same experience. Your times and sizes will vary.
I do not recommend trying to playback files over 700mb on the frame. My first attempt gave me a 1GB file that froze the frame when it tried to playback.
In all likelihood you will need to put the video file on a SD card or use a USB thumbdrive as the internal memory of the frame is 128mb.
Good luck! And don't be afraid to try other settings in MPEGstreamclip to better render your videos for the frame. Video compression is all about trial and error :)
Dec 17, 2008 | PANDIGITAL 7" Digital Photo Frame With...
When I play a dvd or watch dvd programs on my mac frame freeze
Try getting a DVD player cleaning kit and clean your Mac's DVD drive.
You can also try using an external DVD drive to verify that it's the drive, and not the software, that is the problem.
Nov 22, 2008 | Apple iBook Mac Notebook
Audiovox fpe1506dv
The problem that I'm having is that when I put a dvd into the player it tries to load the disc but never does. Therefore I cannot watch any dvd.
Dec 31, 2007 | Audiovox FPE-1505 15 in. HD-Ready LCD...
F--
Unlike other cameras that start at frame #1 after loading and count up as the film is used, the N55 advance the film to the last frame during the loading process. When loading is complete, the frame counter stops at the number of available frames on the roll (usually 24 or 36) and counts down as photos are taken. I know it sounds backwards but it actually makes a lot of sense to engineer it this way. After the last photo is taken (displays 1 on the counter), the camera automatically winds the end of the film into the cassette and the counter shows a blinking E. I am assuming that that is what is being displayed and not a blinking F. it it is an F, perhaps there is a problem with the LCD display? If so, it probably isn't worth having it repaired.
Jun 26, 2007 | Nikon N55 35mm Film Camera
Samsung DVD-V3500 DVD Player/VCR Logo
Jerry Greenberg
Jerry Greenberg
