Question about Microsoft Office Professional 2007 Full Version for PC
Word closes when I click on the top tool bar
Hi, When I click on the circle icon on the top tool bar in word2007 to go to open or print. My document closes. I thought maybe I had a virus and ran a scan. I came out clean. I then tried the office diagnostic scan and came out fine. Any other ideas?
  • 76 Answers
How to set watermark at printer?
normally the water mark is set in the document as it is being prepared , same as headers and footers
The printer just prints the document as it is presented
open up a new document in the tool bar at the top you will see tabs --home --insert---design--page lay out etc
click on design and to the right you will see an icon with watermark under it
that is the section that you use to put a water mark on the document you can open a document already saved and you may also be able to add the watermark after it has been completed as it is a change to the document
Nov 20, 2015 | Office Equipment & Supplies
I don't know how to disable "keep printed documents". I have an Artisan 800 series printer.
Hi Michelle,
Follow the steps below and you will be able to fix the issue.
Click on START button
Click on Control Panel ( or Settings for windows XP )
Click and open Printers and Faxes ( or Printer folder icon )
Highlight the Printer icon and Right click on it
Left Click on Printer properties
Click on Advanced TAB on top and look for "Keep Printed Documents"
If there is a Check mark, you can Uncheck it.
If there is no check mark on it, Check mark it.
Click Apply/OK and Close the window and try to print.
If this does not resolve the issue, Try the step below
1. Open Printers and Faxes.
2. Right mouse click on the Epson printer and left click Properties.
3. Click on the Advanced tab.
4. Click the Print Processor button.
5. Under Print Processor, select WinPrint.
6. Under Default Datatype, make sure RAW is selected. Click OK.
7. Back on the Advanced tab remove the check next to Keep Printed
Documents.
8. Click Apply and OK.
Regards,
Sean
Sep 14, 2012 | Epson Artisan 800 Series
WHEN I WONT TO PRENT MY PRENTER TOLD ME THAER IS NO SOFTWER MY PRODUCT : oPTRA t 610 WHEN I WONT PRENT I TURN OFF & ON oR OBEN THAE DOOR
Default Printer Issue
The wrong printer is set as the default. See the image below for an illustration.
What to do
Open the Printers or Printer and Faxes folder and locate the correct printer icon. To do this:
    1. -In Windows XP, click Start > Settings > Printer and Faxes (or Start > Control Panel > Printers and Faxes).
      -In Windows Vista, click Start > Control Panel > Hardware and Sound > Printers.
    2. Right-click on the printer icon, and click Set as Default Printer. A check mark displayed above the printer icon now identifies it as your default printer.
    3. Try printing again.
Topic 3: Printer is "Offline"
The printer is set to Offline and the printer icon appears washed-out. See the image below for an illustration.
What to do
  2. Right-click on the printer icon, and select Use Printer Online.
Topic 4: Printer is not Ready
The printer is in an "Intervention Requested" state (e.g. paper jam, paper out) but no Windows print error notification message is displayed.
Explanation
The print job cleared the print queue. This means the print queue icon has disappeared from the notification area ('systray') of the task bar. The printer is holding the job, however, until the the printer is returned to a ready state.
What to do
Check the printer LCD, or operator panel menu, to verify that the printer is in a ready state. If not, return it to the required status.
Topic 5: Printer is Paused
The printer or print queue is paused and the print queue icon remains in the notification area ('systray') of the task bar.
Explanation
This is typically an end user error. Dragging the mouse cursor over the print queue icon in the notification area will reveal (1,2,3) document(s) pending for (User name).
What to do
    1. Double-click on the print queue icon to open the print queue. (This may also appear as a small printer icon in the lower-right notification area of the task bar.)
    2. Click on Printer in the upper left-hand corner of the menu bar.
    3. Is there a check mark next to Pause Printing?
      -If yes, click on Pause Printing to turn off this Windows feature.
      -If no, confirm that there is a check mark next to Set As Default Printer and make sure Use Printer Offline is not selected.
Topic 10: Windows Print Spooler Issue
A problem with the Windows print spooler is preventing successful printing.
What to try
Stop and start the Windows print spooler. To do this:
  • -In Windows XP, click Start > Control Panel > Administrative Tools > Services, click on Print Spooler, click on Stop the service, and then click on Start the service.
  • -In Windows Vista, click Start, type services.msc in the Start Search box, and then click services.msc in the Programs list. Right-click on Print Spooler, and then click Stop. Finally, right-click on Print Spooler again, and then click Start.
Remove the first print job from the print queue. To do this:
  2. Click on the first job listed so that it is highlighted.
  3. Click on Document in the top menu bar.
  4. Click on Cancel.
  5. Click Yes when you see: "Are you sure you want to cancel the selected jobs?"
Click here for illustration.
Topic 11: Other Issues
Other possible causes of a print job not printing include:
  • -USB connection problem if locally connected only.
  • -Firewall issues preventing communication.
  • -Workplace virtual private networks (VPNs) preventing communication. VPN tunneling may be required to ensure successful communication. Enabling this feature may require network administrator approval and assistance.
  • -Document formatting.
  • -Driver settings.
  • -Application-specific issues relating to the application's Printer Setup.
Topic 12: Last Resort
If you have tried all of the above suggestions to no avail, try the following:
  1. Reboot your computer and try printing again.
  2. Turn the printer off and on, and then try to print again.
  3. Install a different printer driver, e.g. PCL, PostScript, HBP, or XPS driver.
Dec 14, 2010 | Lexmark Optra T610 Laser Printer
Error code 2075 keeps coming up when I try to scan a document to desk top what do I do?
To resolve this error code:
  1. Close Home Center Software.
  2. Go to Start>Computer.
  3. Show hidden files and folders:
    • Select Tools>Folder Options.
      NOTE: If the Tools menu is not available on the menu bar, press the <Alt> key on the keyboard, and then a menu bar with the Tools menu will appear.
    • Select the View tab.
    • In the Advanced Settings, select Show hidden files or folders.
    • Select Apply.
    • Click OK.
  4. • right click on the Kodak icon on your desktop and select properties. •Then select find target.
  5. Right-click AiOHomeCenter.exe.config and select delete to remove the file.
  6. Hide hidden files and folders:
    • In the Advanced Settings, select Do not show hidden files or folders.
    • Select Apply.
    • Click OK.
  7. Run Home Center Software to run as an administrator:
    • Right-click the Home Center icon, then select properties.
    • Select the Run this program as an administrator check box in the compatibility mode.
    • Click OK.
  8. Open Home Center Software and print or scan a job.
Jun 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do you clear que on a c6300 photosmart
Windows XP Operating System
Restart the Print Spooler device
  1. Open Administrative Tools.
  2. On the Windows taskbar, click Start , and then click Control Panel .
  3. Click Performance and Maintenance . NOTE: This step is not necessary in XP Classic View.
  4. Click Administrative Tools .
  5. Double-click Services .
  6. Click Print Spooler .
  7. Click Stop to stop the Print Spooler.
  8. Click Start to restart the Print Spooler.
  9. Click OK .
  10. Restart the computer.
  11. Try the print job again.
Manually clear the print queue
  1. Return to the Printers and Faxes folder that you opened in the previous steps.
  2. Right-click the name of the product, and then click Open .
  3. Click Printer , and then click Cancel All Documents .
  4. Click Yes to confirm the action.
  5. If documents remain in the print queue, restart the computer.
  6. Try printing again.
Windows Vista Operating System
  1. Return to the Printers folder that you opened earlier in this document.
If the issue continues, proceed to the next step. Restart the Print Spooler device
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), click Control Panel , and then click Administrative Tools .
  2. Double-click Services .
  3. On the User Account Control window, click Continue .
  4. Click Print Spooler .
  5. Click Stop to stop the Print Spooler.
  6. Click Start to restart the Print Spooler.
  7. Click OK .
  8. Restart the computer.
  9. Try the print job again.
Oct 03, 2009 | HP Office Equipment & Supplies
I accidentially told my HP Deskjet 882C printer to print a large document. How do I cancell comand
Hi
Thanks for using FixYa. The easiest way is to switch off the printer. However, basically you can double click on printer icon showing in the bottom of the tool bar of the window and select cancel all printing documents. Then all the printing documents will be stopped printing by the Printer.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 17, 2009 | HP DeskJet 882c InkJet Printer
How do I fax from OpenOffice.org Writter??? I have a HP Officejet J5780 that fax hard copy just fine, but want to fax right from the word processor. I am using Vista Home os.
Sending Faxes and Configuring OpenOffice.org for Faxing
To send a fax directly from OpenOffice.org, you need a fax modem and a fax driver that allows applications to communicate with the fax modem.
Sending a Fax Through the Print Dialog
1. Open the Print dialog by choosing File - Print and select the fax driver in the Name list box.
2. Clicking OK opens the dialog for your fax driver, where you can select the fax recipient.
Configuring OpenOffice.org a Fax Icon
You can configure OpenOffice.org so that a single click on an icon automatically sends the current document as a fax:
1. Choose Tools - Options - OpenOffice.org Writer - Print.
2. Select the fax driver from the Fax list box and click OK.
3. Click the arrow icon at the end of the Standard bar. In the drop-down menu, choose Customize.
The Toolbars tab page of the Customize dialog appears.
4. Click Add Commands.
5. Select the “Documents” category, then select the “Send Default Fax” command.
6. Click Add and then Close.
7. On the Toolbars tab page, click the down arrow button to position the new icon where you want it. Click OK.
Your Standard bar now has a new icon to send the current document as a fax.
Mar 06, 2009 | Microsoft Windows Vista Home Premium with...
Unable to print from web on Lexmark z2300
hi ..
log on to lexmark website..www.lexmark.com ...downloaded lexmark tool bar to ur desk top ...once download is complete .install tool bar...then open web page..don not print from file..instead use the printer icon on the top right corner to print...this should fix it
good luck
Feb 12, 2009 | Lexmark Z2300 InkJet Printer
Canon MP810 printer will not print documents, messages come up on screen: printer not responding, printer offline, document failed to print. Other capabilities are fine.
Hi, there is a possibility that the printer is set off-line or there is a pending print job that was stucked in queue. To check that please go to printer & faxes, right click on the printer icon (your printer), cancel all documents and click yes. Then right click again on the printer icon then select use printer on line. Try printing. If issue still present, restart prinrt spooler services. To access print spooler, goto control panel then administrative tools then select services. Scroll down the vertical scroll bar until select print spooler. Open it then click on stop then start. Try printing again.
Tirzo
Jun 12, 2008 | Cannon Office Equipment & Supplies
First print doesn't work
are you using msword?
Spooling while printing does not work when printing from Microsoft Word. SOLUTION: Resolve this issue as follows:
  1. In the Microsoft Word menu bar click Tools then Options .
  2. Select the Print tab.
  3. Uncheck the Background Printing option.
  4. Re-send the print job.
The printer is in Ready mode, but nothing prints. SOLUTION:
  1. Restart the computer.
  2. Verify that all of the cables are properly seated and within specifications. This includes the USB, network, and power cables. Try a new cable.
  3. Reinstall the printer software. In the Windows task bar, click Start , Programs , HP , HP LaserJet 10xx series , and then click Uninstall HP LaserJet 10xx series . Turn the printer off. Install the printer software from the CD. Turn the printer back on.
  4. Close any applications that are running. To close an application that has an icon in the task bar, right-click the icon, and select Close or Disable .
another option is make sure you have the latest firmware:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00386985&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en
Nov 12, 2007 | HP LaserJet 1020 Printer
Microsoft Office Professional 2007 Full Version for PC Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
