Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Power Problem AGAIN!! KV-32FS120
KV-32FS120. Set started with occasional problem coming on. What I mean is you would have to hit the power supply button or remote power more than once to turn on. Problem got worse over several weeks until finally set doesn't power up at all other than no matter how many times you hit power! (8 blink code.) Any thoughts for repair or just right off set.
Thanks for your help!!!!!!
  • fm354 Oct 29, 2008
    Just to add to my previous question. The TV worked great other than the power problem. Once it was on video and sound were great and it never turned itself off. Just had problems turning it on.
    Not 8 blinks but 9. Sorry!
  • Sony Master
  • 5,568 Answers
Wish I could reach the set from here; I'm pretty sure the problem is caused by a 50 cent (maximum!) part called a capacitor in the range of 4.7 - 100 uFd that is responsible for feed back that keeps the power supply ticking. If you decide to have it repaired and the problem is as above, tell the tech to use a low ESR part and add a .1-.5 uFd ceramic capacitor in parallel to the one he/she replaces. That cap will handle the fast rise times that causes the electrolytic cap to break down chemically and fail.
Posted on Oct 31, 2008
Sony wega flat screen power problem. does not turn on led red power light blinks 2 seconds and then truns off again
The problem of your TV is in the power supply section.Maybe the regulator is deffetive thats why the power supply not comes on.Its maybe also the harizontal output transistor is deffective.So check the regulator an harizontal output and replace if deffective..
Sep 19, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I press the power button and hear the click but no picture appear
Unplug the TV Remove the cover wait until the TV cools then plug in, turn on and, it should come on... if it does; purchase a computer fan to cool the chassis of the TV wire it into the 12 volt side of the power supply and, install the cover
Aug 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Won't turn on
Capacitors in the power supply section. Same area where your power chord is soldered to the board. Be sure to discharge the set before attempting to work on it. High voltage kills. Good luck and stay safe!
May 24, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Jul 12, 2008 | Sony KV-36FS100 36" TV
Sony kv-32fs120
The 6 blinks mean no horizontal. Check the horizontal circuitry. I'll look up your specific model later and post more details.
Dan
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS120 blinks 4 times
good day.
Have you tried first resoldering the terminals in the circuitry?
Also, try to check for the ABL supply near the flyback. Watch out for the small voltage zener diodes.
response is highly appreciated.
chris
Mar 26, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega model: kv-32FS120 doesn't turn on
Check your power supply board and resolder the pcb, check the switching diodes and zeners.
Jan 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Jan 13, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
KV-32FS120
Seven Blinks: High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into shutdown. Check power supply and horizontal circuits.
Culbert Communications
New Brunswick, Canada
Nov 23, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
44 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
