Question about HP OfficeJet 7310 All-In-One InkJet Printer
0XC0620004411:lib_micci2.c error on PSC1610
My printer still does not work.
Jan i have the same proble with my OJ7310 all-in-one
error
oxc620004
411:lib_micrci2.c
i turn it off for 20sec and turn back on while holding #,6 button. it make the same think on printing the alignment test.
I have a similar failure on a HP6210 All-In-One
Error: 0xC0620004411:lib.micci2.0
Issue cause:
This issue occurs due to hardware malfunction of the All-in-One unit.
Solution Summary:
Please perform the steps below to resolve the issue:
Step 1: 0x error Weblink
Step 2: Cleaning the Rollers
Step 3: Ensure correct installation of the front panel overlay
Step 4: Connect the All-in-One unit directly to wall outlet
Step 5: Power Cycle
Step 6: Semi Full reset
Solution:
John, I have provided the detailed information in simple steps and I request you to perform them step by step in a sequential manner. However, if you find any difficulty at any point of time in performing these steps, reply to this e-mail and I will respond to you right away.
I request you perform the steps given below in the weblink to resolve the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00489814&dlc=en
NOTE: Clicking the link above may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address is displayed in the Address box.
Now, check the functionality. This should resolve the issue. If the issue persists, please perform the steps below.
I request you perform the steps given below in the weblink to clean the rollers.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu01831&cc=us&lc=en&dlc=en&product=421991#N592
If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, ensure correct installation of the front panel overlay by following the instructions below. If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to re-install the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
NOTE: If the front panel overlay is already installed, proceed to the next step.
  1. Position the control panel overlay above the device. Figure 1: Positioning the control panel overlay 0XC0620004411:lib_micci2.c error on PSC1610 - c00227677.gif
  2. Press down firmly on all edges and in the center of the overlay until it snaps into place to secure it. Figure 2: Pressing down firmly c00227678.gif
  3. Try the print job again to see if this step resolved the issue.
    • If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved , continue to the next step.
If the power cord was plugged into a surge protector, plug the power cord directly into a wall power outlet. In some cases there are too many devices plugged into surge suppressors or the suppressor may be defective. Replace any defective surge suppressor or move some devices onto a different circuit.
Now, check the functionality of the All-in-one. If the issue persists, please perform the steps below.
Step 5: Power Cycle
Power cycle the unit to remove electrical surges from All-in-One.
1. Unplug the power supply from the wall outlet.
2. Unplug the power supply from the back of the printer.
3. Wait at least 20 seconds, then plug in the supply back into the wall outlet.
4. Plug in the power supply back into the printer.
5. Press the power button to turn the printer on.
Step 6: Semi Full Reset
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Now, check the functionality. If the issue persists, I regret to inform you that the issue you are experiencing is most predictable to be a hardware issue that cannot be resolved through e-mail and the unit needs to be serviced or replaced.
John, I wish to know whether the information provided in the E-mail assisted you to address the issue.
If you experience any difficulty in performing the steps, I request you to write back to us with the observations. We are here round the clock to serve our esteemed customers like you.
Have a Nice Day.
Sincerely,
Chris
HP Total Care.
Posted on Mar 04, 2009
How to fix OXC1AB0003 error on the P PhotoSmart 2575
Remove the cartridges and do a full reset without them in by removing the wall socket and re-plugging.
More information has been answered in another thread.
Error oxc1ab0003730 Lib micci2 tango
Apr 07, 2015 | HP PhotoSmart 2575 / 2575v / 2575xi InkJet...
Error:0xc0620004411:lib_micci2.c is flashing on the green window. Printer refuse to work.
Check inside the printer to see if any paper or object stuck up in there, there may be something something in there,take out whats in and start the printer.
Aug 16, 2010 | HP PSC 1610 All-In-One InkJet Printer
My samsung ml-1610 series printer's software is installed but the printer is not installed
my oj 7310 all in one is give me error mesege 0xc0620004 411:lib-micci2.c
Nov 03, 2009 | Samsung ML 1610 Laser Printer
Hp 2355 all in one error message
open the rear access door and clean the rollers with a cloth, dam it with little water and unplug the machine and press and hold the ON button for 1 min and release the button and plug in the power cord, it should resolve the issue.
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Error Code 0xc0620004411:lib_micci2.c
reinstall your driver and also check usb connection cable.
Jan 03, 2009 | HP PSC 1610 All-In-One InkJet Printer
Try doing power drain.
By Isolating printer from power and computer.
Press and hold power button for 5 sec.
Then try turning on. without connecting to the computer.
Sep 04, 2008 | HP PSC 1610v All-in-One Printer
reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Error: 0x07a74dd61959:lib-barracu
Its a Fimware Error.
Try a Hardware Reset.
-Switch the Printer on
-unplug the powerkable
-press "#" and "6" and plug in the Powerkable.
when the Display shows Initialising or Semi-Full-Reset. release the "#" and the"6".
sometime this is working
Jul 14, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
559 people viewed this question
Ben Johnson
