Question about Max Displays MD-219 (Gray) 19 in. Flat Panel LCD Monitor
I have max displays md 219, 12v and I can't locate an ac adapter,Where I can buy one?
  • et2008 Oct 29, 2008
    amazon does not show anything under md-219 ac adapter, do you have model number or specs.
    Thanks.
    I have max displays md 219, 12v and I can't locate an ac adapter, do you know the manufacture name? and amazon does not show anything under max displays md-219
  • 19,396 Answers
Max displays is out of business, and the adapter is not distributed anymore.
As you can see is not in stock here
Part number for the adapter was AED70US12
The only seller that has part in stock is the following:
http://www.fadfusion.com/manufacturer.php?man=MAX+DISPLAYS
Here is the link to the power supply :
XP POWER AC-DC POWER SUPPLY, AED SERIES, SINGLE OUTPUT
Do not forhget to accept the solution if you are satisfied.
Many thanks.
Posted on Oct 31, 2008
  • 749 Answers
Four things to consider while purchasing a replacement
1.voltage--we know its 12 volts DC
2.wattage-- your monitor uses 80 watts - this will take a ac adaptor with about 1 ampre
3. polarity of the adaptor- the inside tip of the adaptor cord needs to be the same polarity (posative or negative) as the plug it's going into. there should be a little insignia near where you plug the adaptor into the monitor with a partial circle and a line going to the middle of the circle, each having a plus or negative sign. the line that goes to the center is the inner cnnection (refered to as TIP)
4. size of the tip - dont accept any plugs that fit loosely as they will cause problems down the road.
If you have the old adaptor, you can carry it down to radio shack and they should be able to match it up for you. If not , print these specs and carry them in with you when you go----
here is the page showing the power specs available http://www.ciao.com/Max_Displays_MD_219__15408106#productdetail
Posted on Oct 29, 2008
  • 1,879 Answers
Amazon.com
Can you bind the Heli max Helis to a D6i transmitter
Yes, you need to buy an AnyLink transmetter that will plug in the trainer plug of your tranmitter.
I put a web link to Tactic anylink products that can be order from internet from online hobbyshop, look in the Where to buy tab on anylink website. Have fun :-)
Dec 09, 2013 | Heli-Max MD-530 Flybarless EP Tx-R...
Medion MD 98200 My laptop will not turn on after my son removed the battery pack accidentally
Turn on the laptop without the battery, using only the AC adapter. If doesn't work remove the AC Adapter and battery. Hold down the power button for 30-45 seconds then plugged in the AC Adapter and put battery back in then [on]
Apr 11, 2013 | Computers & Internet
Need to buy a charger for my Hyundai S900-charger 100-240V 50/60Hz 9v-2.5A, saw on Amazon you had thisCostMad 7 / 6 Way 1.5A 1500mA max. AC to DC Universal Universally Multi Voltage 3V / 4.5V / 6V / 7.5V /...
You can buy car accessories here,they are one of the best electronics wholesales in China. http://www.ankaka.com/Wholesale-car-accessories_c10005
Feb 18, 2013 | Televison & Video
How do i find a manual for max md215
http://www.retrevo.com
go here and it should have the manual.
Aug 07, 2010 | Max Displays MD 215 (Gray) 15 in. Flat...
I am looking for an ac adapter for a Max Displays monitor
You may get it from your nearby shop of electronics or from the place from where u bought the device
if u are not getting that model from shops than u may buy i t from internet
thanks
May 15, 2010 | Computers & Internet
you can purchase it from the website www.lcdparts.com by credit card .just give proper part no
Mar 29, 2010 | Computers & Internet
Power adapter i need a power
SPU65-105 SINPRO Stock 1 75.00 75.00
Lodi, NJ 07644 USA
Tel - 1-973-779-8282
Fax - 1-973-779-1490
135 Pasadena Avenue
TRC Electronics, Inc.
www.trcelectronics.com
This is the replacemnt power supply for this monitor.
Jul 20, 2008 | Max Displays MD-218 (Gray) 18.1 in. Flat...
Toshiba Portege 7100 AC Adapter
all are not same but you buy through ebay you cant replace it go the shop and verfy onces
Jun 11, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Need a new adapter TAD-10 need locations- Thank you
You can buy an after market Tad-10 tad10 ac power charger adapter for your Durabrand PDV-709 here:
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
Dec 20, 2007 | Durabrand PDV-709
Open Questions:
Nvidia Vetro Geforce 6800GT on E510? Need help setting up max displays MD 219 dual displays Hi all, Hi all, I recently upgraded my video card to the Nvidia Vetro Geforce 6800GT from the stock Radeon X300 on my E510. I'm trying to run dual monitors on this system, however, my computer isn't picking up the second monitor; It does not give me the option to stretch the screen. I've installed and reinstalled the drivers and still no go. To be more specific, I have the Max Displays MD - 219 but I can't seem to get both monitors to come on at the same time. These monitors are connected and share a single power source. II've tried using two seperate computers to turn on both monitors simultaneously and that has worked, so it seems both monitors do power on and work properly. I've tried hooking up just the right monitor and my old dell monitor to the card and it works fine with the extend desktop in properties/settings, but for some reason the left monitor just won't get detected (it gets stuck on a screen that says Self Diagnostics, Digital, No Signal, Check Signal Cable). I tried using a Y splitter with the Left and right monitor, and both left and right displays come on with the same image, so from my understanding it's able to turn on and have an image. I've also unplugged the right panel when it was working, then plugged in the left one and that seemed to make the left one work; however, when I plug in the right panel afterwards they both go out. The Card seems to work perfectly fine as I can run both my old dell monitor and the right monitor as an extended desktop. Does anyone have any ideas at all what I'm doing wrong? Thanks in advance.
Mar 17, 2008 | Max Displays MD-219 (Gray) 19 in. Flat...
Max Displays MD-219 (Gray) 19 in. Flat Panel LCD Monitor Logo
469 people viewed this question
Top Max Displays Computers & Internet Experts
David Payne
David Payne
Are you a Max Displays Computer and Internet Expert? Answer questions, earn points and help others
