Question about Parsons QuickVerse 7 Essentials (fe11044) for PC
Cannot install Quickverse 7 version from year 2000 because of Microsoft DAO.
I'm not sure if this is the same version being used now, because it was purchased around the year 2000, but maybe this is a common problem. When I try to install Quickverse it says it cannot be installed because Microsoft DAO is currently running. What do I need to disable or do to install Quickverse when this situation arises?
  • 10 more comments
  • ladyrona Dec 08, 2007
    having the same exact problem as Caleb's went I try to install quickverse 7
  • quick help Dec 19, 2007
    I have the same problem. Cannot seem to locate/disable the DAO. HELP!
  • jm0375 Jan 09, 2008
    Same problem
  • dougfuls Feb 02, 2008
    Have Windows XP and also cannot install QuickVerse 7 Essentials. The program loads until one of the final steps when it's checking the configuration. Then a MicroSoft window pops up saying it has to close the window and sends an error report. The files appear to be on the ocmputer but when you open them, the pages are blank. I've tried installing it disabling the anti-virus and also in safe mode, but the results are the same. Any suggestions? Thanks
  • DavidJJ Mar 24, 2008
    This is in regard to QuickVerse from around 2000, not the more recent QuickVerse 7 Essentials. I have tried to install with administrator privileges and in safe mode. All efforts end up with "setup has to close." It gives me the shell of the QuickVerse program in my Vista, but not the books (Bibles, etc). [I'm not sure what Caleb is referring to when he says "Microsoft DAO. problem." I don't think that has come up on my screen.]
  • Anonymous Apr 13, 2008
    Same problem with installation of QuickVerse software. Notice window appears saying to exit Microsoft DAO before proceeding. What can I do?
  • Anonymous Apr 29, 2008
    Cannot install Quickverse 7 version from year 2000 because of Microsoft DAO. problem, and notify you when a new solution is offered.
  • rlarline Sep 01, 2008
    Cannot install Q.V. 7 due DAO being on
  • amenglish Jan 01, 2009
    Unable to reinstall QuickVerse Version 7 due to an error message stating that my computer is running Microsoft DAO and all programs running this must be closed prior to installation.
  • Anonymous May 10, 2009
    I have vista hp os. when I try to install qv6 the drop down tells me installation can't cont. because microsoft dao programs are running. I am curious that maybe that works is conflicting? help!!!
  • Anonymous Mar 15, 2014
    installation of quickverse 7 on windows 8
Hi, I had the same problem and fixed it, (loaded my quick verse bible software by loading the software in SAFE-MODE. This mode stops the dao that is running. (probably micorsoft office at start up). This solution worked perfect....God bless
Posted on Mar 15, 2008
    New Friend:
  • 22 Answers
Installing Quickverse 6 in Safe Mode works ok on XP Pro. I suspect we need to instal Quickverse before installing MS Office, if not installing in Safe Mode.
Posted on Sep 11, 2009
The Augurst 17 post above worked great for me!! Thanks so much! I like QV 7 the best even though I get the updates, all the way through 10 - but with the above instructions I can add the books from the later versions onto 7.
Posted on Oct 25, 2008
Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the QuickVerse version 7 Essentials CD into optical drive & close tray. This begins the auto run / install process. (Please do not remove CD until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message box appears at the end of the installation: “QuickVerse installation has encountered a problem and needs to close” Choose “Don’t Send” The installation program exits.
Navigate to: Start Button / All Programs / Parsons / QuickVerse 7 / (from drop down list) find “QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog Box appears, “The librarian datafile library.mdb not found etc…” Select “New” / "Open Book" dialog box appears click on “Close”
Now with QuickVerse 7.0 running go to File / Add Books. “Registration Guide – Introduction” box appears. Choose “Next” The path to the new collection to register should identify the optical drive (with the QuickVerse CD already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight QV Essentials in the LH pane. The RH pane shows all the books present on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…
Posted on Aug 17, 2008
  • John McKee Sep 09, 2011
    I used the solution posted by 'Guest' back in 2008 that was labeled 'Best'.. It worked like a charm. Thank you.
SOURCE:
Can I install Quickverse 7.0 on Windows 7?
Locate the setup file for QuickVerse. Right click on the file and choose 'Properties'. On the 'Compatability' tab, click the check box next to 'Run this program in compatibility mode for:' and choose 'Windows XP Service Pack 3'.
After QuickVerse is installed, you may have to perform the above steps for the application file as well.
Jul 26, 2012 | Computers & Internet
Quickverse 7.0 and vista
run msconfig and check if any Office programs
are running at startup uncheck them or delete the entry run from the registry ,and any Office programs that
are running during installation it exist
Dec 19, 2007 | Parsons QuickVerse 2005 Expanded Edition...
I want to install Quick verse 7 on my new windows 7 computer. What special instructions do I need? Bruce
The system requirements of this software are Windows 95 / 98 / ME / NT / 2000 / XP only. but their are new version of Quick verse 7 that are compatible in window 7 visit this link..
http://www.quickverse.com/Shopfiles/product_details.asp?ID=41244
Apr 25, 2011 | Parsons QuickVerse 7 Essentials (fe11044)...
I cannot open the file downloaded from Microsoft to enable me to use the help file. I am trying to find the meaning of the symbol (underline circle) appearing in text as a superscript. This is in...
I Think Your problem no in QuickVerse 8 Deluxe, but on Windows 7.
1. Software for XP, few can installed on Windows 7 -> i think you use Application for XP
2. Usually windows 7 must be Pacht-ing for use windows XP Application
3. May be you can Try install -> on software -> Right Click -> Run As Administrator "you Must enable Administrator befor".
Feb 19, 2011 | IMSI QuickVerse 8 Deluxe (QUICKVERS8E) for...
I cannot get my software to install and function
NOTE: QuickVerse Smart Tags will only work with Microsoft products that support the technology. (Your version of Microsoft Word must be 2002 or newer.)
during the installation of QuickVerse. However, if a Microsoft document was open during installation, you may have to walk through the following steps manually.
Phase 1 - Manually register the QV13SmartTags.dll file
  1. Download and extract this ZIP file to your desktop
  2. Windows XP: Right-Click and select Open
    Windows Vista: Right-Click and select Run as Administrator
Phase 2A - Turn ON Smart Tags in Microsoft Word 2007
  1. Start Microsoft Office Word 2007.
  2. Click the Microsoft Office Button, and then click Word Options.
  3. Click the Proofing tab, and then click AutoCorrect Options.
  4. Click the Smart Tags tab.
  5. Verify that the Label text with smart tags check box is selected and that your smart tag is both listed and selected in the Recognizers list.
Phase 2B - Turn ON Smart Tags in Microsoft Word 2002 or 2003
  1. Start Microsoft Office Word 2002 or Microsoft Office Word 2003.
  2. On the Tools menu, click AutoCorrect Options.
  3. Click the Smart Tags tab.
  4. Verify that the Label text with smart tags check box is selected and that your smart tag is both listed and selected in the Recognizers list.
click on this link directly for more troubleshooting
http://www.quickverse.com/shopfiles/Faq.asp?ID=41221
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Nov 28, 2009 | Findex QuickVerse Bible Suite 2008
I am asked to close microsoft dod before I can install quick verse 7 How do I do this
Most likely you'd have to uninstal MS Office, as I think this is the program using Microsoft DAO. Restart the computer in Safe Mode, then Quickverse will instal ok.
Jul 15, 2009 | Parsons QuickVerse 7 Essentials (fe11044)...
I have used Quickverse VErsion 7 Deluxe for years on previous laptops using Windows 98 and Windows XP. However, I have installed it on my new laptop using Vista 32 bit and if I right click on the desk
From their website
Question 1:
Can QuickVerse 2007 run on Windows Vista?
Answer: Configure QuickVerse 2007 for Microsoft Vista Compatibility Mode
  1. Download and install the latest Maintenance Release
    Browse to the Program Files folder for QuickVerse 2007
  2. Configure Compatibility Mode for these 2 files:
    C:\Program Files\QuickVerse 2007\qv11.exe
    C:\Program Files\QuickVerse 2007\QVBookManager.exe
  3. Right-click each file listed above and select Properties on the Menu
  4. Click on the Compatibility tab and make the following selections for both files listed above:
http://www.quickverse.com/Shopfiles/Faq.asp?ID=QV2007WIN
Apr 23, 2009 | Computers & Internet
Installing QV 7 produces warning MS DAO preventing installation.
I,too, have the problem of installing my Quickverse 7 on my computer with Vista. What do i do to stop the running of Microsoft DAO?
Apr 08, 2009 | Parsons QuickVerse 7 Essentials (fe11044)...
Want to install Quick verse 7 on Vista
the Quick verse 7 was made only for 95 98 2000 and XP but you can try this method on how to install the QV 7 on winXP sp3
"Install QuickVerse Essentials version 7 on WinXP w/sp3
Default Drive
Close the dialog, exit the program, remove the CD and you’re away…"
hope this helps./
Nov 04, 2008 | Computers & Internet
Quick verse 7
Default Drive
Jul 11, 2008 | Parsons QuickVerse 7 Essentials (fe11044)...
Parsons QuickVerse 7 Essentials (fe11044) for PC Logo
1,239 people viewed this question
Top Parsons Computers & Internet Experts
Marvin
Marvin
Norman Al-Anbar
Andrew Taylor
Andrew Taylor
Are you a Parsons Computer and Internet Expert? Answer questions, earn points and help others
