Question about LG Cell Phones
My touch screen dose not work propley if i make a call to press 7 8 or 9 i have to press the top of the screen as if the touch part has moved up
  • 488 Answers
Try and align the screen in the settings section..that should help...
Posted on Oct 29, 2008
Touchscreen not working.
Do you hear a beep when you touch the screen? If you do it is more than likely a software issue, or the cameras are misaligned..
First thing to try is Scroll Lock Calibration.. Press Scroll Lock on your keyboard 5 times quickly, your cursor should move to the top left of your screen, press and hold your finger on it until you hear a beep, remove your finger and itshould automatically move to the top right, repeat for each corner, when it is done the cursor will move to the middle of the screen, and the touch screen should be working
If the computer does not beep when you tocuh the cursor and the cursor does not move when you remove your finger it means your touch is not being recognized... it could be a software or hardware issue, here is one way to find out..
First do a power drain.. shut down the computer and unplug everything from it (including the power cord) and press and hold the power button for 30 seconds.. Now boot the computer into BIOS by tapping F10 on startup.. inside the BIOS touch the screen.. do you hear a beep? if so it is a software issue, if not more than likely it is a hardware issue
A few other things you can try... open the Touch Screen Configuration Tool inside the Control Panel, make suire the touch screen and sound are enabled, select the Troubleshooting tab, click Restore Defaults, try the Calibration function... beyond that you could try System Restore/System Recovery..
Good luck
Nov 24, 2013 | Acer Aspire Z5600 PC Desktop
Mio moov 300 screen alignment problem
Download the user manual online and look for factory resettings. Follow instructions and it should work. On my Garmin, the same thing happened. On Garmin, you turn the unit off, press and hold the top left corner of your screen, and turn the unit on while pressing the top left corner of the screen. You wait for 10 seconds and a black dot appears and requests you touch it. The dot moves around the screen and you keep touching it. Once done, your screen perimeter is identified and all the letters fall in place when you press them. Good luck!
Dec 02, 2012 | SNK Mio Moov 300 GPS Receiver
My samsung tocco lite touch screen wont work only the buttons and the camera button work i try and touch something on the screen and if it is at the top of the screen it will move if i touch by the bottom...
same thing happen's to mine, and i'v only had mine for two months :O aha, although i believe it's 'cause i got the screen wet, i mean it's happened before but, usually worked but, this time i think that the water dissolved into the phone making the touch screen not work, mine's still not fixed but, trying taking the phone apart and re-building it. That might help. Kayleigh xx
Jan 15, 2011 | Cell Phones
Touch screen not responsive after speaker replacement It worked before speaker replacement.
To calibrate the touchscreen on a nuvi 300 or 600 series:
1. Power the unit On.
2. From the Where to? / View map screen, touch Settings (wrench icon).
3. Touch Display.
4. Touch Recalibrate.
5. A new screen will display that says Press Dot.
6. Touch the center of the dot.
7. Keep touching the center of the dot as it moves around the screen.
8. When Calibration Complete appears on the screen, please touch OK.
The touch-screen will now be recalibrated.
Nov 04, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
The touch screen doesnt work propley if i press for example 4 the * key gets pressed.. its jusst not write i cant even check my text please help me out.
try looking for the pen calibration in the settings menu, after you have located it perform what is said on screen, just follow the instructions, if that doesnt work, it means that your touch screen has physical damage already and the only thing you can do is to replace the lcd assembly.
Jun 01, 2010 | LG KP501 Cell Phone
My screen is cracked and the touch screen does not work propley
THer is no fix, you will have to replace the screen, which means the phone has to be replaced...
Feb 28, 2010 | LG KU990 Viewty
Touch pad mouse will not move
There will be a button above the touch pad or using function key to disable it. try both and find out which is the prob. Some drivers may not installed properly. Run the touchpad driver in administrator mode and if you are having the xp driver set to xp sp3 compatible mode.
Jan 13, 2010 | Computers & Internet
The time and date has disappeared on my LG Envy Touch and I can't figure out how to get it back on.
go to the menu on the fron screen slide out tab button thing. then click more widgets and get the clock one. then drag it to the top of thescreen. it will appear onur front screen at the very top. then you can move hint down to where you want it.
NOTE: it starts at the very top once you drag it on. If you try to move it you can put it way up on the top again. I just dont move it on the screen bc i like it at the way top
Oct 30, 2009 | LG enV Touch VX11000 Cell Phone
Wihte screen on old ipod touch
try doing a hard reset by holding the power and home button for at least 10 sec or till the ipod resets no doing a hard reset dose not erase your ipod
Mar 05, 2009 | Apple iPod touch
Used Lanier LD435c needs to get reset to factory settings
enter the [user tools/counter] then before you press [system settings] hold it down pressed the [#] key and while the [#] key is pressed press the [system settings] key (on the touch screen or if dose not have touch screen than press ok) and the copier will return the settings to default. You can repeat the procedure for all settings.
Jan 10, 2009 | Ricoh Office Equipment & Supplies
Cell Phones Logo
44 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
