Question about Linksys SD2008 10/100/1000 Gigabit Switch (8-port) (C01003)
SD 2008 linksys switch slow
My 8 port Gb switch SD 2008 Linksys falls back to only 10 Mb on autoconnection. The switch is connected to 2 PC's with linksys EG1032 through patch cat 6 cables (3m). The system used to work properly on Gb . Both PC's now fall back to 10Mb
  • 1 more comment
  • axys Oct 31, 2008
    I first assumed that it was my onboard broadcom netXtreme NIC but after reading reviews at http://www.newegg.com/Product/ProductRev... I think it is a common fault with the SD2008 v2.1
  • thope Nov 11, 2008
    Same problem - switch appears to revert to 10MB on some ports - tried to manually force speed from NICs - no luck -
  • natecasp Mar 25, 2009
    I too have this same issue but it does seem to matter what type of NIC is connected to the switch. If I use a Broadcom NIC the performance is horrible however if I use a Linksys or Intel NIC all is good. Anyone know why or have the same problem?
Same problem here - switch appears to revert to 10MB on some ports and 100MB on others. Tried to force 1000 from NIC, but that just lost connectivity - had to reset back to auto to get any connectivity at all
Posted on Nov 11, 2008
"Uninstall and Reinstall the Switch."
it's an umanaged switch - there is no install - powering off doesn't help
Posted on Nov 03, 2008
  • axys Nov 11, 2008
    These Linksys SD2008 switches are rubbish.
    I have been to several sites with reviews/comments about the SD2008 and they all say the same thing. See http://www.newegg.com/Product/ProductRev...
    Most users have problems with them some after only a few months but they all start going slower after a year of so and will not connect at 1Gb. If you can get down to board level solutions there is a capacitor near the heat sink that is usually the problem.
    The best solution is to throw it away and replace with a better brand.
    There is some talk of a Limited Lifetime Warranty but I wouldn't put much faith in that....
HOW DO I CONFIGURE A LINKSYS SD208 SWITCH
This unit does not require configuration. Simply connect main drop / ISP modem and use. The ports are auto detect, so basicly you can use any port. Uplink and / or crossover ready.
The full manual is only 9 pages, but even the 2 pager said it all.
http://www.manualowl.com/p/Linksys/SD208/Manual/42252
Oct 05, 2012 | Linksys Sd208 8-port 10/100 Switch
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
Linksys SRW2008 blocking ports
blocking ports and QoS is a layer 3 function, switches are layer 2 unless you buy a layer two switch. You will need to do this on your router.
Mar 31, 2010 | Linksys SRW2008 8-Port Gigabit Ethernet...
Dell XP 200 Dimension ethernet port
Hello.
I'd suggest testing with another computer and the same Ethernet cable to your modem to see if the results are the same and to narrow down which component is the problem.
Was it always slow with this setup or did something change.
Is the Linksys adapter connected via USB ? That would be slower than an internal adapter.
Try updating the Linksys adapter software - Device Manager - rightclick - update driver.
Hope these suggestions help.
Dec 23, 2009 | Dell XPS 200 PC Desktop
Linksys EZXS16W Issue
Hi There, first of all you need to connect from your modem or router's port a link. Use a cat5 ethernet cable from the modem to the switch or if you also use a router from a port in back to the switch. Then when you plug in other computers it will see the internet connection. Good Luck...
Oct 28, 2009 | Linksys EtherFast 10/100 16-Port Workgroup...
Home Computer Network Confusion
it easy plug your big plug rg 45 cable from the 2010 into your port 1 on your router then buy more rg45 cable from comp store plug it into port 2 then into comp 1 plug another one into port 3 on your router and plug it into other comp. everything should work xp will pick up and install anything needed. have fun surfing
Sep 30, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Not all ports working
Sounds like you may have some wires cross between your switch and your router. And if someone worked on your pc, there probably something wrong with it too. Most places dont know how to fix a computer they just reinstall the OS and hand it back to you, less the unique drivers from your computer mfg for hardware such as network adapter drivers. Connect dirctly to the modem and got to dell support or whomever and check drivers
Aug 27, 2017 | Linksys SD208 8-Port Ethernet Switch...
Cannot connect
what is the model number? you can go to this site
www.linksys.com/download
or www.linksys.com only and search for the product. the model number is underneath your device.
Oct 01, 2007 | Linksys 5-Port Ethernet Switch (SD205-UK)
Linksys SD2008 10/100/1000 Gigabit Switch (8-port) (C01003) Logo
1,024 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
