Copier Ricoh 1232c error code sc517
How to clear the error from the mechine
Paul
  • 81 Answers
"yellow clear" then press 1 0 7 and hold down stop.. go into copy sp and enter 7 8 0 7 and then press " # " press the execute button.. when it says done power down from the red switch.. then power back up.. that will clear the error.. but you may need parts if the error returns
Posted on Jul 07, 2009
Ricoh 1232c sc 672
The correct way to get into service mode is to first press the Yellow "CLEAR" button then press the numbers 1 >0>7 then press and hold the Red "STOP" button.... Good Luck
Jun 08, 2012 | Ricoh Aficio 1232C Color Copier
Copier error code 221
We are assuming that you are talking about Error Code SC 221
This code is a Scan length detection problem.
1.Disconnected Sychronization Detector
2.Bad LD-Unit/BICU Board
SOLUTION: Replace the Laser Diode & Laser Sync detect board
Hope helps (remember to rating this free answer).
Oct 12, 2011 | Ricoh Aficio 1232C Color Copier
Comment enlever message sc 570 sur ricoh 1232c
This error code is related to a Insufficient oil.
The fusing oil tank is in the rear of the machine.
You have to call Ricoh to supply the oil.
See you
Mar 29, 2011 | Ricoh Aficio 1232C Color Copier
I have a ricoh 1232C multifunction and it has just stopped working and gives an error code sc440 " Functional Problem with the copier "
The problem is Main motor error.
The problem can be two diffrent things.
1. Defective main motor
2. Too much load of the main motor drive
Oct 18, 2010 | Ricoh Aficio 1232C Color Copier
ERROR SC 570 RICOH AFICIO 1232C HOW CAN I FIX
The machine has no fuser oil.
Fill the little tank at the back side of the machine. If the tank is full, check the tubes, oil pump, and oil sensor.
Reboot the machine to clear the SC.
The problem will be solved
Aug 10, 2010 | Ricoh Aficio 1232C Color Copier
Need to clear the memory of a Ricoh Aficio 1232c copier, it is printing out random copies of some kind of code, can't find manual...help.
you do not need to clear the memory print the configuration page and see which driver is supported:
it can [RPCS] or [PCL 5e] or [PCL 6e] or [PostScript]
if you are using the driver which the machine does not support she will print documents as you say some kind of codes.
Jan 20, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1232c copier error code SC571
Enter SP 5-810 and set to 1, then switch off and on the machine.
Oct 30, 2008 | Office Equipment & Supplies
For Ricoh 1232c copier error SC517
See previous threads on how to clear.
Oct 29, 2008 | Office Equipment & Supplies
Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
85 people viewed this question
jasbo
jasbo
