This problem should be removed because:
Problem with Car Amplifiers
where is the ground wire?
deck
I don't know on which sequence of wires on the back of my deck to put on first without frying my deck.
ground wire has burned plastic cover on my amp
well i guess the ground wire was kinda loose and the wire was making contact with the plastic cover in witch the wire goes into on the...
cant find a constant ground connection
I had a constant ground connection when i shortened up the ground wire and then when i tried to hook up the subs i lost the ground...
bad ground feedback?
my car is giving bad ground feedback. i tried everything moved the ground many places in the car. can it be the deck?was working fine then...
wont turn on i bought
wont turn on i bought it though craigslist
Tips for Helping Lauren With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
Need a service manual for PG Tantrum 400.4 or...
Other three channels in this amp are the same layout but this area is different.So NOT so easy to just refer to their...
q29 transistor is burnt and i need to find the...
the power supply transistor Q29 is burn and i cant see the part number to get a replacement
i need a part number for zx1500.1
transistor q29
deleting mp3 files off of radio.
Plugged in my USB card and it downloaded all my songs. but then wanted to update and get rid of some. but when i deleted...
Fix-O-Meter
12
12 people viewed this problem
- 0 people are following this problem. Be the first!
Top Car Amplifier Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
