Question about Ricoh Aficio SP-C210SF Printer
Deterioration on the left side
Hi Jaylex,
I am getting deterioration of color on the left side when I print. This is most notable with Cyan in the upper left quadrant edge (one inch from edge of paper, but I can see in black areas (lower left quadrant) that there is fading as well. Given what I am describing I am assuming that toner is not the problem...Any ideas?
Thank you!
kathryn.guthrie@tabordasolutions.com
I have same issue and had a service tech to take a look at my machine. I was told that the OPC Belt was bad and should have it replaced. Not a great answer considering the drum costs well over $399 each!
Posted on Oct 30, 2008
Why does the 2550n printer not printing fully in the left column
Is the print quality poor on left side for all colors? You may have one bad cartridge. Create a paint document with Yellow, Magenta and Cyan squares on the left side and see if one color prints better than the others. You can also gently shake the cartridges to redistribute toner.
Sep 08, 2014 | HP Color LaserJet 2550n printer + HP Color...
Aficio SP C411DN does not print cyan
Well, since you've tried everything, my recommendation is to try to clean the contacts with dry cloth in the left or right side inside the printer where the cartridges place in. see the result
Feb 01, 2014 | Ricoh Aficio SP C411DN Laser Printer
Instead of Bule print DC12 prints Violet
Hi there! The blue color is becoming violet because the Cyan and the Magenta toners are not getting mixed in the proper 100:100 ratio (100% Magenta and 100% Cyan make CMYK Blue). Since the print is violet, the culprit is the Cyan toner. Now, first, get the Cyan Developer Assy checked if there is enough developer in it. If no, get it refilled by a proper tech and manually mix about 50 grams of the Cyan Toner with the developer. Also get the tech to check the trimmer gap on the Developer Assy with a metering gauge. If yes, next check the Cyan dispenser motor located on the backside of the Toner Housing Assy. It is probably broken and not dispensing any toner to the Cyan Developer Assy . Additionally, check for the Cyan Dispenser Auger blockage or jam. It is located under the Cyan Toner Cartridge in the Toner Housing Assy and also check the auger under the Cyan Developer Assy. After sorting these out, you should get proper CMYK blue from the 10th or 12th page once you resume printing.Let me know. Regards
May 26, 2011 | Xerox DocuColor 12 Color Copier
My magicolor 2350 has cyan print problem
replace the cyan image unit might go a bad one
Oct 04, 2009 | Minolta magicolor 2350 Laser Printer
11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
Streaks on left side of paper when printing in color
go to the control panel and then printers and fax. double click your printer and click on the tab and button to "clean print heads". after doing this, click on "align print cartridges". this will fix the streaking problem you have
Feb 25, 2009 | Dell 5100cn Laser Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
Ricoh Aficio SP-C210SF Printer Logo
88 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
