Ricoh 1232c copier error code sc 517
I got a error code sc 517 on my copier how to fix the problm
and how to clear the error from the memory ( Ricoh 1232c copier)
  • Anonymous Oct 30, 2008
  • 183 Answers
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Posted on Jul 15, 2009
Code 792
SC 792 :Finisher error .The machine does not recognize the finisher , but recognizes the relay unit .Possible causes :Defective connectordefective cable incorrect installation
Apr 01, 2014 | Ricoh Aficio 1232C Color Copier
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Ricoh 1232c sc 672
The correct way to get into service mode is to first press the Yellow "CLEAR" button then press the numbers 1 >0>7 then press and hold the Red "STOP" button.... Good Luck
Jun 08, 2012 | Ricoh Aficio 1232C Color Copier
Copier error code 221
We are assuming that you are talking about Error Code SC 221
This code is a Scan length detection problem.
1.Disconnected Sychronization Detector
2.Bad LD-Unit/BICU Board
SOLUTION: Replace the Laser Diode & Laser Sync detect board
Hope helps (remember to rating this free answer).
Oct 12, 2011 | Ricoh Aficio 1232C Color Copier
We just transferred a Ricoh 1232c from storage at another of our offices in another state. On powering up the machine I got a SC542 code. Can you please assist?
SC 542: Bad melting temperature. The code can not disappear by itself, it must enter the program mode of the machine and delete it with mode 5810.
If the code comes back, there is a heating problem.
May 12, 2011 | Ricoh Aficio 1232C Color Copier
Comment enlever message sc 570 sur ricoh 1232c
This error code is related to a Insufficient oil.
The fusing oil tank is in the rear of the machine.
You have to call Ricoh to supply the oil.
See you
Mar 29, 2011 | Ricoh Aficio 1232C Color Copier
The machine has no fuser oil.
Fill the little tank at the back side of the machine. If the tank is full, check the tubes, oil pump, and oil sensor.
Reboot the machine to clear the SC.
The problem will be solved
Aug 10, 2010 | Ricoh Aficio 1232C Color Copier
Need to clear the memory of a Ricoh Aficio 1232c copier, it is printing out random copies of some kind of code, can't find
you do not need to clear the memory print the configuration page and see which driver is supported:
it can [RPCS] or [PCL 5e] or [PCL 6e] or [PostScript]
if you are using the driver which the machine does not support she will print documents as you say some kind of codes.
Jan 20, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Jan 09, 2009 | Office Equipment & Supplies
359 people viewed this question
