Question about Polaroid PDV-0700 Portable DVD Player
PDM 0742 all I get is bad disc and the disc is not bad. have tried to clean it with a new cleanning disc and still get the same message. It jjust wont play.
  • 31 Answers
Take off top cover and clean laser manually with wet q tip then use dry q tip to absorb moisture.
c
Posted on Oct 29, 2008
Bad disc error
Hi the chances are the problem you are having is going to be with the laser lense, you will probably find that it is covered in dust and is not reading the disks properly, so if you go into a computer repair or hardware shop you can buy a cd lense cleaning kit you then put the cleaning disk into your dvd player and it will then remove any dust build up and should get it working properly.
If after doing this your still having problems then the chances are the laser is on its way out and may need replacing, the problem with this is that the cost of repair could cost more than buying a new dvd player, so for now i would try the lense cleaning kit and see if that solves your problem.
9 out of 10 of the times it solves the problem so it is worth trying the cleaning first.
Also make sure you dvd's are clean and free from scratches you can run them under a cold tap to clean them and then dry them using kitchen roll just dont press to hard when drying.
Jul 11, 2010 | Polaroid PDM-0742 Portable DVD Player
I get the message "bad disc" with every disc I put in the player.
ok best bet is that your laser (what reads the discs) in your laptop is dirty, use a cd/dvd cleaning disc to clean the laser, can buy them from most computing, music shops
Jun 29, 2009 | Polaroid Portable DVD Player PDM-0822BD
DVD Player that repeatedly says NO DISC for Polaroid PDM-0752
either needs to be clean or the REGION needs to be set up to 1 or ALL , LETS TRY WITH cleaning the OPTICAL LENS with a dry Q tip , gently rub a few strokes at the lens , and give it a try, if NOT then try to set the REGION to 1 or all, if still not reading the disc , then have to replace the optical lens, good luck , AJ
May 28, 2009 | Polaroid PDM-0742 Portable DVD Player
Polaroid DVD Player PDM-0742 not playing dvds
I was a circuit board engineer for the on-chip set. there was a major techical issue with the units but due to the cost of investments by polariod, they decided to sell them to the public anyway. the promblem is in the chip that only works for a very short time before is overheats and the system will show "bad disk"
Jan 23, 2009 | Polaroid PDM-0742 Portable DVD Player
Bad disc comes up on portable dvd player
Hi
you have bad Pick up lens and or bad Flex ribbon Wire.
Thanks!
Nov 12, 2008 | Polaroid PDM-0742 Portable DVD Player
Polaroid portable dvd
take off top cover and clean laser manually with wet q tip then use dry q tip to absorb excess moisture.
c
Oct 29, 2008 | Polaroid PDV-0700 Portable DVD Player
Dvd-5820
Hi
Thanks
Jul 15, 2008 | Polaroid PDM-0742 Portable DVD Player
Bad disc...
1-866-289-5168 FOR ASSISTANCE. Try this number for technical assistance for you problem. Hope this helps you.
Jun 06, 2008 | Polaroid PDM-0742 Portable DVD Player
Bad disc
What type of disk is you are trying to play?
Aug 28, 2007 | Polaroid PDM-0742 Portable DVD Player
Polaroid PDV-0700 Portable DVD Player Logo
179 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
