Question about Dell Inspiron 2200 Notebook
Dell Inspiron Battery problem
Hello Tech Support
My dell inspiron 2200 lately does not get power from the battery although the battery (when plug in) is showing 100% fully charge but if i unplug the unit is goes dead. Is this battery dead despite showing that it's full.
regards
Richard
  • Anonymous Nov 07, 2008
    With my laptop, it actually tells me when booting, that the battery cannot be identified, so it will not be able to charge. Then the same thing happens, if unplugged from the power chord it will go dead.
    Problem Solver:
  • 16 Answers
Try this trick. Remove the battery from the laptop and make sure the ac adapter is not plugged in also. Hold the power button for 30 seconds. Place the battery back in and see if it powers on. If not let me know.
Hope this helps.
Posted on Oct 29, 2008
How to remove the battery of inspiron 2200
1. Turn your Dell 2200 laptop over.
2. Find the laptop battery release button lock for your Dell 2200 laptop.
3. Now that your Dell 2200 laptop battery is unlocked, find the battery release button down.
4. Holding the laptop battery release button, gently pull your battery away from the laptop.
5. Now that your Dell 2200 battery is removed, grab your replacement Dell 2200 battery for installation.
6. Insert the battery into the slot. Push the Dell 2200 battery towards the laptop and secure it in place.
Jul 04, 2016 | Dell Computers & Internet
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
I own a Dell inspiron 2200, the battery life is less than 30 Min. any suggestions where to purchase an inexpensive replacement or fix.
http://www.laptopbatterydepot.com/shopping/productdetails.asp?brand=Dell&recordid=242&battery=Inspiron+-+2200
Jan 26, 2010 | Dell Inspiron 2200 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 2200 Charger Malfunction
Try to turn off the computer and remove the battery from the bottom of the notebook. Turn on the computer with just the charger plugged in. If it doesnt turn on. you may have a bad power port.
If it has no power/charging issue since that happened except that the indicator light doesnt turn on when you plug in the charger, you may just need a bios update. Click here. That's the bios update for the inspiron 2200 from dell's website. You should have at least 30% charge on the battery and the ac adapter should be plugged in so you can run it. The computer will restart and will come back normally after this. I'd suggest that you backup your files before running this.
Sep 28, 2008 | Dell Inspiron 2200 PC Notebook
Dell inspiron 2200 is not powering up after being switched on, its on black screen! help
The most probable cause of failure is the memory sticks on the computer. Follow the troubleshooting steps given below and you would be able to get the system up
http://tinyurl.com/5gmvww
Thanks
Proton
Donot forget to rate the solution if it was helpful or resolve your issue
Jul 26, 2008 | Dell Inspiron 2200 Notebook
MY DELL INSPIRION 2200
it might be due to problem with ram or your display adapter in the both the cases you have to open the case,
May 19, 2008 | Dell Inspiron 2200 Notebook
Removing Battery
the following website tell you how to remove the battery
http://support.dell.com/support/edocs/systems/ins2200/en/SM/begin.htm#1084976
May 07, 2008 | Dell Inspiron 2200 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 2200 Notebook Logo
303 people viewed this question
Alun Cox
