This problem should be removed because:
Problem with Car Amplifiers
i need a five pin female plug for my hiphonics odin VIII. THE PLUG IS FOR THE POWER AND SPEAKER wires
the five prong plug goes to the power and speakers of my hiphonics odin VIII amp. the plugs to the hiphonics thor VIII are the same . there has to be a distributor out there that still has these plugs can you help me.
Suggested Solution (3)
The right speaker will connect to the R+ and R- terminals and the left speaker will connect to the L+ and L- terminals. Only one speaker per connection. If both speakers are not exactly the same brand, part number,size, etc. then they may NOT sound the same. Be sure to watch the polarity of the speakers so they don't interfere with each other. I.E. speaker + to amp + etc. Good luck.
if you are using RCAs as inputs to your amp.Swap the R to L @ RCAs to see if its comming in okay from radio.If both RCAs have audio then amp is bad ,If amp has any type of switches , move swithces to see if it comes back .Also if both RCAs inputs have audio .Move the RCAs when connected on amp to see if amp has bad connection in board to RCA jacks..If audio comes back on bad side when jack is moves .Then you have bad solder joints on board..If not then you must have bad outputs on amp..
Source: Right side speakers don't work
try using power directly from main to the remote terminal to see if headunit has a problem or the amp.please disconnect remote from head first.
Source: Jensen XA4100
Hifonics Problem
Hey guys, I have the Hifonics Odin series VIII just installed. But when the remote turn on sends...
overheating
I`ve had a Hifonics Thor (old brand) for 19yrs. and this is the first time it`s over-heating.Wanting to find the specs on how to hook up one...
sound loss
Hi, I have a Alpine CDA9856 hu rf cpapacitor feeding a Infinity 475a for four speakers. In addition a RF 550 punch driving two 10' dual...
i hook the hifonic amp up and it cuts on but the
i hook the hifonic amp up and it cuts on but the subs dont beat but the subs work
i hook it up and the diag light comes on
i hook up my amp and the power light comes on then goes off and the diag light comes on and i have checked the ground
Tips for Helping frankie gray With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
Need a service manual for PG Tantrum 400.4 or...
Other three channels in this amp are the same layout but this area is different.So NOT so easy to just refer to their...
q29 transistor is burnt and i need to find the...
the power supply transistor Q29 is burn and i cant see the part number to get a replacement
i need a part number for zx1500.1
transistor q29
deleting mp3 files off of radio.
Plugged in my USB card and it downloaded all my songs. but then wanted to update and get rid of some. but when i deleted...
Fix-O-Meter
12
12 people viewed this problem
- 0 people are following this problem. Be the first!
Top Car Amplifier Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
