Question about Motorola Mobility RAZR V3
Motorola RAZR V3 Battery discharge
My cell phone discharges a freshly charged battery in about 3 hrs. I carry extra batteries to change when it goes dead.
I've changed batteries with another RAZR V3 phone. That phone works just fine, so it's not a battery problem. Given that the phone is supposed to have about 4 hrs of talk time, it seems that my phone doesn't go into standby mode.
Is there a fix?
Thanks,
Drew
drewdo25@aol.com
  • drewdo25 Oct 29, 2008
    I didn't have the default security code which is:
    000000
  • Anonymous Mar 11, 2014
    I did not get a new switch, I just put the wires together and basically hot wired the car, so I am working without a switch, just wires
    Genius:
  • 2,035 Answers
TRY this :
You have the option of using Master Reset or Master Clear to reset settings, and remove information.
Master Reset resets all settings on device to factory default.
Master Clear resets all settings to factory default, plus clears all data from the device including: PIM data, Call History, Settings, etc.
To perform a Master Reset or Master Clear:
1.
Press Start.
2.
Scroll to and select System Tools.
3.
Scroll to and select either Master Reset or Master Clear.
4.
Press Yes when Alert appears.
5. Enter Master Code (normally 00000)
If this did not help then there is the problem phone hardware which draining the battery ....
Posted on Nov 05, 2008
    Sergeant:
    Champion:
  • 275 Answers
I dont think there is any kind of hardware failure with the phone ... it could be some software which keeps running in the background tht drains the battery ... the best option i would suggest is flash the phone with the latest firmware and the issue will be resolved
  • 1,879 Answers
Check display or phone settings for power saving features.
Posted on Oct 29, 2008
  • 13,433 Answers
It is most likely a internal issue in the phone, best served by a repair professional at motorola, hows your warranty? contact your dealer and complain about it, possibly get a replacement or send it in for repair, theres not much I would recommend .. can't really take the phone apart to correct the issue, I feel its best you contact your dealer.. a home fix might be to replace the mainboard of the phone but if you got warranty on your phone, then theres noting to worry about,.
    Genius:
  • 1,142 Answers
Please try a reset of the phone to remove any kind of static.
if this does not work it could be a problem of the circuit board not charging the battery upto the mark
The battery doesn't work fine
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 26, 2012 | Motorola Mobility RAZR V3
Battery is completely discharged and mobile is not charging
switch off the mobile and charge up to 3 to 4 hrs continuaoly
Jul 03, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Battery
Before you change the battery:
  1. Charge the battery fully
  2. Discharge the battery fully
  3. Repeat steps 1 and 2
If the battery does not reset itself and start lasting longer then you do need to replace it.
Jun 26, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Battery
sometimes it happen when you accidentally drop your phone but most of the time there is some loss parts inside ... try to check the pin connecting to the phone & battery and if you dont know how to do it just go to the nearest phone repair shop to fix it for you before you change the battery......!!!!
Apr 08, 2008 | Motorola Mobility RAZR V3
Charge
hi your battery has created a memory because you didn't follow simple battery guidelines:
For a new phone with a new battery;
1)Use the phone the first time until the battery dies,
2)Do a full charge - 6-8hours for the first time
3)Use the phone until it dies the second time
4)recharge the battery for 3-5 hours
then your battery should be good, but now your battery needs to be changed, as it already has memory and can only be restored if completely discharged by a battery conditioner
Jan 30, 2008 | Motorola Mobility RAZR V3
Charge battery.
Normally you would use the usb charger supplied with the phone. If that does not work, then your battery may be completely discharged, and you will have to replace it.
Jan 09, 2008 | Motorola Mobility RAZR V3
Motorola razr v3 white screen problem
try the new battery, but be sure it the right battery and fully charge V6.0 or higher. if no change, than you may have damage on the inside from the liquid discharged (short)
Nov 30, 2007 | Motorola Mobility RAZR V3
Motorola razr battery problem
The only solution is to get a new battery. When you do, charge it completely when you first get it, then discharge it until it dies. This will maximize the life of the battery.
Nov 29, 2007 | Motorola Mobility RAZR V3
Battery
Turn on the battery save feature and select a slow search frequency.
Nov 09, 2007 | Motorola Mobility RAZR V3
Razr
its battery get discharges totally , so change battery
Oct 21, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
21 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
