I have a Canon MF4690 and when changing the toner cartridge, a small guide attached with two small springs came off and can not see how it reattaches. I think it could be the guide for 2 sided copies, but not sure.
I have this same problem and can't figure out what to do with that weird part that has 2 small springs! The printer seems to work fine, but it must be used for SOMETHING!?
Posted on Apr 20, 2010
Imageclass mf4690 has streaks in copies
Several possibilities: if copying using the ADF - clean the glass under the ADF feed. If a print is the same as a copy - check the toner cartridge. This type of cartridge collects heaps of junk in the waste chamber which interferes with the print when nearly empty. If neither of those - dust on the imaging scanner = refer to service dude.
Jul 28, 2014 | Canon imageCLASS MF4690 Multifunction...
Mf4690 service manual
Free download of Canon imageCLASS MF4690 User Manual. Troubleshooting help from ... We hope you like our service. Recommend it to your ... Copying. • Basic Copying Method. • Scan Settings. • Image Quality. • Density. • Zoom Ratio ... www.retrevo.com/support/Canon-MF4690-Multifunction-Printers-manual/id/1304dj683/t/2/ www.retrevo.com/support/Canon-MF4690-Multifunction-Printers-manual/id/1304dj683/t/2/Hope this will help you
Jan 30, 2012 | Canon imageCLASS MF4690 Copier
How do i change the toner on this copy machine?
Canon iR3300 copier /image runner is a best machine which is not needed any expert mechanic. Thanks to the manufacturer.If the toner in the cartridge was completed a message may be displayed on the screen that 'refill the toner'. Even though there will be a small quantuty of toner in the cartridge the message may be appear on the screen. Please don't bother about this mesaage. You may think the machine be damaged some where else. You might have handling the 'motor bike' or 'scooter' and you may experienced about the resrve . i.e. even though there is some petrol in the petrol tank of vehicle , the vihicle may stops to work. After filling of the petrol the vehile may run as usual. So , after the reserve of toner in the cop[ier the machine will stops to work. The you have to refill the toner cartridge with the fine quality toner of 1/2 kg or with 1kg. The cost of the toner may be Rs.500/- to Rs.650/- depending on the quality and the company and availability of the toner in the market. The toner must be compatible with the iR 3300 copier. After purchasing of the toner you must shufle the toner bag up and down nearly (100) times , so that the toner in the bag may thouroghly mixed and see that there will not be hard particles. Then remove the front cover gently and turn the side levers 1). left lever to left side and 2). right lever to down side. Then gently drag the toner cartridge of only 3/4 size. Please don't try to remove the toner cartridge completly out side of the machine. The costliest cartridge and not avialability of the new cartridge in the market may be break.At the front and top of the cartridge , there will be small lever attached to the cover of cartridge . Just hold the front ant and top of the cartridge with middle fingers and thumb fingers either side of the cartridge by both the hands and just press the levers out side towards you with the fore fingers of both the hands.. Then drag the cover only 3/4 of cover out side towards yourself. Make a small hole at the corner of the toner bag and pour the toner gently in to the cartridge. while pouring the toner in to the cartridge gently move the cartridge inside and out side , so that the toner may evenly spread in the cartridge. After pouring of hole toner , close the cover the cartridge by pressing the edge of the cover from out side and then press the cartridge in to the machine and there after turn the levers in to the original position and close the front cover.
Sep 24, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Canon iRC 3380i error code E00025-002...help please?
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Jun 15, 2010 | Canon C3380i Color Copier
The error code says "Toner is not set". Removing and reinstalling the toner cassette does not resolve the problem. Any ideas?
To clear this message: remove toner cartridge, look into the cavity and locate the contact that matches the contacts on the FX-9 toner cartridge.
It is on the left side of the machine.
This contact is probably caught in the down position or stuck behind the plastic.
You can wiggle it out by flexing the spring just below it.
This should allow it to spring back into place.
Now replace the cartridge and all should be fine.
hope it works for u
all the best !!!!
Apr 07, 2010 | Canon imageCLASS®­ MF4690 All-In-One Laser...
Canon MF4690 keeps displaying 'toner is not, set insert toner...'
Hello
I think it is firmware problem.I only found firmware update tool for MF 4150.I am not sure this is also for 4690 but i think i do this before for this machine and it works.So you can try it.It can also be a problem with cartridge contacts so yuu can try to check it.
Here is the link - in drivers software tab :
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=14444#DownloadDetailAct
Jul 29, 2009 | Canon i-SENSYS MF4140 All-In-One Laser...
Replacing toner unit
i have a lot of quantity cartridge . open your copier front door and out the cartridge.Have your side any hp 1200 printer cartridge part no 15 change drum shatter put your old d320 cartridge then solve your problem
please send me success result
Jun 25, 2009 | Canon imageCLASS D320 All-In-One Laser...
Canon ImageClass MF 6550 Error Toner Low- Prepare New Toner
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
Dec 17, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Keep saying change cartridge
Yes i found one spring was out of its place it is near the paper feed assembly.
After placing the spring in its hinges the problem was solved.
Mar 31, 2008 | Canon L220 Plain Paper Laser Fax
Blank Copies
The Unit where you've put the toner cartridge could be to far from the drum. Make sure your developer unit (unit where you've put the cartridge in) is locked in place.
Mar 14, 2008 | Canon NP 7130 Black and White Copier
94 people viewed this question
k24674
jasbo
jasbo
