Hp C5180 printer will not print in black and white
Printer says it cannot print because colors are low. Now even when i order it to print in grayscale(B&W) it says it cannot because color cartridges are low...I just want a black and white print job done but none of the settings will co-operate.
thank you
peter
5 Suggested Answers
  • 238 Answers
SOURCE: computer doesn't print color
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
Posted on Dec 17, 2007
  • 103 Answers
SOURCE: Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Posted on Feb 05, 2008
SOURCE: hp c5180 printer: While printing a job, the
switch off the power, press and hold the ok and help buttons then restore power this will do a reset on the printer and cure this problem
Posted on Jul 12, 2009
aimrans78
  • 52 Answers
SOURCE: My HP Photosmart D7160 is printing color pictures
try to reinstall the drivers
everything is going well with the hardware
only software has some bugs
Posted on Jun 18, 2010
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to switch photosmart to just print in black
Go to the printer properties and open the tab. there will be a place to check black print only. Save your changes. You will have to uncheck it if you ever want to print color.
Sep 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
C5180 won't print in black and white only
I do not have this model printer or computer, but I thought I would offer that most printer set-up dialog boxes from the program you are printing from, will let you select mono. I'm somewhat familiar with this because I use CAD software and though I draw multi color lines, I want only to print black-line.
I hope this helps... Good luck!
Sep 02, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have a printer HP c5180 all in one, only have black ink , not color, i dont want print in color . can I use the printer black and white (not color) only?
You can go into the print properties and set it to print black only, however if any of the color cartridges are empty the printer may not print until you replace whichever cartridge is empty.
Aug 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
How can I print black only color cartridges are empty black is full . this is for HP photosmart C5180 all in one printer
sir when you chose the print option please select the settings button there in the color tab you can find this option that print with only black ink
alternative solution is that before you print please open the flap of the printer where the heads are and remove the color cartridge.. then print it will give you a warning saying that printing in reserve mode but ignore this warnings
Thnx and i hope this solves your problem
Please rate this solution
Jul 16, 2009 | HP Photosmart C5180 All-In-One InkJet...
My printer has suddenly started printing terrible quality photos
I discovered I had switched photo paper in the process. The new paper obviously isn't compatible with this printer. I went and purchased more of my regular paper and the pictures began printing well again.
Dec 17, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP c5180 tells me to replace cartridge but won't print color
some time first chip is black are bad or not work so any other color are says not work.
u change black chip first.
Nov 18, 2008 | HP Photosmart C5180 All-In-One InkJet...
How can I print Black only?
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
64 people viewed this question
jasbo
jasbo
