Question about HP LaserJet color laser printer
Ricoh Aficio MP C3500 PCL 6
I have this error code: PCL XL error
Warning: IllegalMediaSource
4 Suggested Answers
  • 65 Answers
SOURCE: printer wont do anything ricoh aficio 1515 pcl 6
The first thing to try is to turn the machine off, then back on at the red "main power" switch located on the left side of the machine. If the code returns it is indicative of firmware problems or a loose connection.
At this point I would seriously recommend getting a service tech to come out. However, if you want, you can take off the back cover (MAKE SURE THE POWER CORD IS UNPLUGED) and double check all of the connections by (GENTLY) pressing them into their connections. Hope this helps. Let me know.
Posted on Nov 25, 2008
jeffdynamics
  • 18 Answers
SOURCE: Printing problem "PCL XL error"
reinstalled driver w- pcl
Posted on Apr 14, 2008
  • 7 Answers
SOURCE: pcl xl error warning: Illegal media source
Some people have issues with the PCL6 driver this causes pcl xl error like this to print. Change your driver from the PCL6 driver to the PCL5 driver. If you don't have the software you can down load it from HP at: http://welcome.hp.com/country/us/en/support.html
Thanks...V
Posted on Sep 19, 2008
don_farr
  • 1011 Answers
SOURCE: PCL XL error when i give command to the printer
I already answered this, but the response did not get posted.
The short answer is that the PCL XL interpreter has picked up the use of the "Escape Code" (0x1B) in the incoming datastream. This command is used for the standard versions of PCL, most notable PCL 5e. It is not used in the PCL XL datastream.
Don
Posted on Aug 16, 2009
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
Jai un C3500 mp Aficio de Ricoh qui a sc erreur 792
finisher cable not plug into copier. I f you don't have a finisher don't worry about it or you need to remove bridge unit to get rid of code.
Sep 20, 2014 | Ricoh Aficio Mpc 3500 Color Copier
Using the PCL drivers for our Ricoh Aficio MP 3350
Try using the RPCS (Ricoh's proprietary print driver) for printing from Word, and see if that works any better. You could also try another version of PCL -- if you're using PCL6, try PCL5, for example.
All of the 3350 drivers can be downloaded here (just choose the correct operating system):
http://ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/mp33/mp33en.htm
Dec 02, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
PCL XL error problem
Try to update the latest firmware for your printer.
Aug 24, 2009 | Ricoh Aficio 450 Copier
PCL XL ERROR - ILLEGALMEDIASOURCE
I would advise trying to use the PCL 5 Driver - I presume that at the moment you are probably using the PCL 6 driver.
If you need any further infor please post back with a little bit more info!
Aug 23, 2009 | Ricoh AFICIO SP4100NL MONO-LASERPR 31PPM...
Adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Apr 10, 2009 | Ricoh Aficio 2015 Copier
Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Mar 26, 2009 | Ricoh Aficio MP1600SPF Copier
Pcl xl error warning: Illegal media source
Thanks...V
Sep 19, 2008 | HP LaserJet color laser printer
HP LaserJet color laser printer Logo
2,738 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
