Question about Toshiba TN50X81 50" Rear Projection Television
FLASHING POWER LAMP
No video or audio, power lamp just flashes. Any idea? Thanks
    President:
  • 3,130 Answers
A power regulator or a sweep power supply problem. The power regulators in the main power supply, and will have or start with STR###-## The # are numbers or letters. This is a repair that should be done by an amature or layman. This is a solid state set, and there are no user replaceable parts inside these sets. Have it looked at by a trained tech, Good Luck
Posted on Sep 06, 2006
BENQ W1060 projector POWER lamp flashing but not working. What's wrong?
When you replace the lamp you have to reset the hours menu on the lamp. It is found in the menu under settings.
Aug 19, 2014 | BenQ W1060 - Dlp Projector
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I replaced the lamp in my Sony E50A10 and the tv still doesn't power up.The indicator flashes red.Any ideas?
if its the lamp indicator flashing its an issue with the lamp. If the lamp is new I would double check to see if its making contact completely when its slid in often the pins can get bent slightly. If it were the ballast the power indicator would blink 5 times.
Feb 09, 2013 | Sony Wega KDF E50A10 TV
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Sony KDF E50A10
If standby light flash 3 times that means Lamp Cover is open or not fixed properly on its place.
Please make sure lamp cover is fixed securely.
Have you replaced its lamp recently?
Thanks.
Sep 04, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Power Light Flashing Red
Change the lamp. If red led is flashing 4 times. replace lamp fan.
Apr 22, 2009 | Televison & Video
Samsung HLN467W Flashing "LAMP" LED
remove the lamp and visually check if inside looks broken.if visually do not see any thing wrong,check if you have 300 volts dc supply on the ballast which starts the lamp.if you do then the ballast may be defective.if you do not then the power supply should be checked.
the lamp should always be tried first especially if is older than two years.
note - be aware about the switch at the door lamp.the door should be closed,otherwise tv will not work.if you remove the back cover,make sure to bypass the switch temporarely so you could work on the set.
Sep 03, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Sony Grand Wega KF50WE610 Video/Audio disappears every 1-2mins
Hello apharcha,
99.99% its the lamp. You may also have a faulty door, but thats kinda just 2% possibility. Change the lamp...its due anyway.
List Price $200.00
Part Number A-1606-034-B Description LAMP BLOCK XL2100U
Best regards
circuitcity
Jun 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba TN50X81 50" Rear Projection Television Logo
214 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
