Question about Insignia Digital-to-Analog Converter for Analog TVs
Converter Box Problem
I have a newer Analog Magnavox TV and a RCA Converter Box. When the Box is on, I can't receive NBC or CBS, no matter how I ajust the antenna, but if I put the Box on stand-by and use analog signal, I receive them fine. Could it still be an antenna problem?
  • 5 more comments
  • Anonymous Nov 11, 2008
    I can pickup CBS but not NBC. I live in north MS.
  • Anonymous Dec 08, 2008
    ABC had the best reception with just the antenna but now with the converter box I can't get it at all? I can get other signels that weren't as strong. That doesn't make any sense. Does anybody no what to do?
  • Anonymous Dec 27, 2008
    I just hooked up my converter box and, while I get all the other stations just fine, I can't get CBS.
    Also, when I videotape anything, it looks lousy.
  • rubzaza Dec 29, 2008
    the box sucks for me too! :o(
  • Anonymous Feb 05, 2009
    wilmington de I can get NBC some of the time but less than 50%
    I the weather an issue?
  • melchickie Feb 22, 2009
    I have the same problem. I can't get CBS with my digital converter box, but I can get it if I switch to analog signal. I thought that maybe CBS wasn't broadcasting in my area, like the person said below, but there are people I know who don't live that far from me that are receiving it. What could the problem be?
  • Anonymous Apr 10, 2009
    I just installed the magnavox converter box and can not pickup NBC. Please help.
    President:
  • 948 Answers
That just means that stations you can't pick up while the box is on are not broadcasting digital signals yet. Most will be after February.
Posted on Jan 01, 2009
IS RCA DIGITAL TV CONVERTER BOX DTA880 COMPATIBLE WITH ANALOG MAGNAVOX TV COMBO MWC24T5B?
they sell those cable adapters almost every where tv antennas & cables are sold even home improvement stores like home depot and Menards
Sep 22, 2015 | RCA Televison & Video
Dtv converter box digital analog signal
If you do not have a control number for the box as listed by the Remote Manufacturer; then you may try contacting RCA directly.
Dec 12, 2013 | Magnavox TB100MW9
Do I need a digtal converter box to pick up local stations via antenna?
Some local broadcasting will still be in analog but this is just jor simple programming such as college stations. To get local programming such as NBC,ABC,CBS etc. you will need to get a converter since the government has mandated all broadcast be in digital to free up air space.
Note that it may be a case by case basis for some smaller areas.
Dec 29, 2010 | GE 31GT720 31" TV
I can't see NBC with the digital conveter box
Is it only NBC? Or are the other over air channels (ABC, CBS, Fox) also not seen?
Are you going through a splitter with the incoming signal? if so, make sure the splitter frequency range is at least 5 to 1000 Mhz.
You should see the 'temporary lost signal' wording on the channel. Check all cable connections to make sure the cable to connector plug are tight and not loose.
Oct 04, 2009 | Insignia Digital-to-Analog Converter for...
If you are receiving digital signal and channel is fuzzy, something wrong. Only Analog signal is fuzzy. With Digital it is great picture or nothing. For channel 6, check to see if they are broadcasting in digital yet. If they are not, this is why you are not getting a signal. If they are broadcasting in digital, then you need a stronger antenna.
May 27, 2009 | Insignia Digital-to-Analog Converter for...
How do L set up the converter with a TV , a vcr and "Dish" satte
It sounds like you need a three way splitter.
You need to reverse the connections; the splitter has input and out. Hook exterior antenna, converter box, and satellite to the three side terminals (out). Hook the single sided terminal to VCR input. Connect the VCR out to the TV input. This configuration assumes that you will be using the VCR to record from all inputs. The TV has to be set to channel 3 to act as a monitor for your other devices.
Hope this solves your dilemma.
Feb 22, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
What type of antenna are you adjusting? If it is not a UHF then you will have to try another such as a Smart Antenna or one from Wal-Mart for digital TV.
Feb 05, 2009 | Televison & Video
Insignia Digital to analog converter menu doesn't come up
When my Menu did not come up, I found it on the AUX channel (one below channel 3). I was able to go through the set up, but found only one digital channel available. Hope this helps!
Nov 10, 2008 | Televison & Video
2006 RCA TV Digetal Receiver
NBC newsperson said I should check nbc.com to learn
what to do for the change in February. Where is it ??
You want my solution ? Improve your web site.
Feb 23, 2008 | Televison & Video
Insignia Digital-to-Analog Converter for Analog TVs Logo
952 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
