Question about Microsoft Windows Server Standard 2003 for PC
Unknown file There is a file named svchost.exe in the system32 folder,it appears to be a virus but KASPERSKY was unable toremove it and also i'v tried other scanners but still it wasnt removed ^ it takes 100% of CPU usage,(after i end the task manualy in task manager the cpu usage drops down) Bottom line is the file slows down my pc alot.....Plz give me a solution. THANK YOU V.MUCH
  • 76 Answers
In software Svchost.exe is a generic host process name for services that run from dynamic-link libraries (DLLs) within the Microsoft Windows operating system.
At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services permits better control and easier debugging, but it also causes some difficulty for end users wishing to see the memory usage or vendor legitimacy of individual services and processes. End users in Windows XP Professional (and derivatives, such as Windows Server 2003 and Windows XP Media Center Edition) can run the following command at the system prompt to get a breakdown:
tasklist /svc /fi "imagename eq svchost.exe" (NB: This command does not work in Windows XP Home.)
Due to being widespread among running processes, svchost.exe has long been a common disguise used by malware to hide its presence from the user. (One of the common trojan horses deceptively uses scvhost.exe). Users may then run tasklist with no arguments and match the reported PIDs with the previously shown Svchost instances. If memory usage appears abnormal, the user can look up the service names shown by their command on the internet to see if it is a known service or malware.
The Svchost.exe file is located in the %SystemRoot%\System32 folder. The main registry key involved at bootup is HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost (values in this key will show the user at least a partial list of the actual processes behind instances of svchost).
The 30 April, 2007 release of WSUS 3.0 led to reports of svchost.exe issues, including 100% CPU usage, memory hogging, and excessive laptop fan/power usage.[1]
[edit] See also
Posted on Oct 29, 2008
Is the file wmipruse.exe a virus or something that can be used to disrupt my laptop?
To avoid stopping all the services when a provider fails, providers are loaded into a separate host process named Wmiprvse.exe. Multiple instances of Wmiprvse.exe can run at the same time under different accounts: LocalSystem, NetworkService or LocalService. The WMI core WinMgmt.exe is loaded into the shared Local Service host named Svchost.exe.
Note: wmiprvsw.exe is the Sasser worm!
Note: The wmiprvse.exe file is located in the folder C:\WINDOWS\System32\Wbem. In other cases, wmiprvse.exe is a virus, spyware, trojan or worm!
May 25, 2014 | Microsoft Windows 7 Ultimate for PC
When i start my Computer after displaying Welcome Screen the Message appears " The Apllication failed to Initialise properly ( 0xc0000017). Click OK to terminate the Application". So Pls send to me a...
Option 1.
Restart the computer in safe mode, and then remove Aventail Connect. To start Windows in safe mode, press F8 during startup, and then select the safe mode option from the extended boot menu.
Option 2.
Add the Svchost.exe executable file to the Aventail Connect exclusion list. The Svchost.exe file is stored in the %Systemroot%\System32 folder. For example, this file may be in the following location:
C:\Windows\System32
Sep 01, 2010 | Computers & Internet
Generic host process for win32 services has encountered problem and need to close we are sorry for the inconvience -- can u plz gimme a solution for this. This pop is very disturbing. Plz help
Read the Thread here.
Note:-
Generic Host Process for Win32 Services or svchost.exe is a legal and essential component of Windows which is used to host services which run from dynamic-link libraries (DLLs).
Please note that legal svchost.exe should reside in Windows\System32 folder and should not appear in startup list.
If it does appear, do a Malware/spyware/virus scan on your PC.
May 19, 2010 | Microsoft Windows XP Media Center Edition...
Antivirus for ''doomsday'' virus
I had this virus, and the following procedure seemed to work in getting rid of it for me. Hopefully it works for you as well.
open command prompt my going Start > Run and typing cmd.
You should be in a directory called something like “C:\Documents and Settings\User”. if you are not, change to it by typing ‘cd’ and the directory above (replacing ‘user’ with your username), and then pressing enter.
type ‘attrib’ and press enter. There should be a file called svchost.exe, and will have the attributes SHR (which stands for System-file, hidden, and read-only).
type ‘attrib -s -h -r svchost.exe’. This removes the SHR properties and allows you to delete the file.
type ‘del svchost.exe’. This should delete the virus from your computer.
NOTE: svchost.exe is a critical system file if it is located in C:\WINDOWS\System32. If it is located elsewhere (as this one is), it is generally a virus.
Then, insert infected pen drives (memory sticks, iPods etc.) which carry the virus. Change the directory to the pen drive by typing ‘E:’(or whatever letter it is) ENTER. Then type ‘attrib’ as above.
there should be the files ‘protector.exe’ and ‘autorun.inf’ which also have the properties SHR. type ‘attrib -s -h -r’ ENTER, and then delete the files by typing ‘del autorun.inf’ ENTER then ‘del protector.inf’ ENTER. This should remove the virus. Autorun.inf might reappear, but this shouldn’t be a problem.
Do not open the pen drive after you insert it, and cancel any autorun windows that come up.
May 13, 2010 | Computers & Internet
C windows system32 keyboard services.exe
The virus that cause in action in these system file's is using up of pen-drive's without running an anti-virus check before accessing it,if people's use pen-drive's in like internet cafe's or anything like that.You can wipe it of if you know how exactly find the file in the registry.(The Temp folders should be cleaned out periodically as installation programs and hijack programs leave a lot of junk there. Download CleanUP.).I personally recommend to use Avira Ant-virus or Kaspersky works well and don't slow down the system.
Please find out the URL link.
Hope this Helped!
Oct 10, 2009 | Computers & Internet
Trojans wont go away. Hijackthis SCAN help
I am of the mind to do a complete reinstall of the operating system including flash the BIOS even if it is the same version. I worked many hours tracking down and thinking you found every part of the problem on to hit an .EXE and it all starts over again....I just clean out everything and start fresh.
If you tell us what make and model of computer along with the operating system it is we can direct you to the drivers for the reinstall. Some off those programs - for example AOL seem to be virus magnets. (if it is a dell it is really simple if you just put in your service code- it give you your particular driver of your computer.)
That is what I would do...Or you can keep hunting.
please leave rating,,,thank you
May 11, 2009 | Microsoft Windows XP Media Center Edition...
Hijack taskmanag and hijack regedit removing
to repair it you need to install autorun eater.
download here: http://www.softpedia.com/get/Security/Secure-cleaning/Autorun-Eater.shtml
install and it will scan.
also suggested to install avira, bitdefender or mcafee(trial also work).
after install.
restart: press f8 you will enter safe mood. in the safe mood you will see a icon on your taskbar name by mcdonald(the autorun eater software. right click and selct repair task manager, right click again selecr repair regedit and do the same thing select repair folder option.
after that wait untill about 30 minutes(autorun eater to finish scan)
to repair other like no desktop icon download the repair utilities here:
http://www.kellys-korner-xp.com/taskbarplus!.htm
Jan 27, 2009 | Dell Latitude D600 Notebook
I have deleted svchost.exe accidently from windows xp and cannot now log onto windows. I have tried expanding the file from dos however still cannot log on
this is going to be a tough one to fix. since I don't know which svchost you have deleted from the system.
usually when that happen the only solution is to reinstall the OS. even try to fix it from the registry key, the key and the pointer will be there, but not the excution file, and there is not way which svchost control what services.
The Svchost.exe file is located in the %SystemRoot%\System32 folder. At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services allows for better control and easier debugging.
Svchost.exe groups are identified in the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\CurrentVersion\SvchostEach value under this key represents a separate Svchost group and appears as a separate instance when you are viewing active processes. Each value is a REG_MULTI_SZ value and contains the services that run under that Svchost group. Each Svchost group can contain one or more service names that are extracted from the registry key.
Dec 02, 2008 | Microsoft Windows XP Home Edition
I have deleted svchost.exe from windows xp
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Svchost
"Svchost.exe" (Generic Host Process for Win32 Services) is an integral part of Windows OS. It cannot be stopped or restarted manually. It manages 32-bit DLLs and other services. At startup, Svchost.exe checks the services portion of the registry to construct a list of services that it needs to load. In normal conditions multiple instances of Svchost.exe run at the same time. Each Svchost.exe session can contain a grouping of services, so that separate services can be run depending on how and where Svchost.exe is started. This allows for better control and debugging. The svchost.exe file is located in the folder C:\Windows\System32. In other cases, svchost.exe is a virus, spyware, trojan or worm! To detect if it's a virus sometimes it will add letters to the Svchost to read thus SSVCHOST or SVCCHOST or something like that, thus making multiple services to run and slow down the computer, if that is the case the current antivirus you are using is not removing the virus, this can be done in the registry, its a complicated process if you do not know how to do it, so i would suggest you purchase a registry cleaner. NOTE: remember to backup the registry before you clean it
Aug 15, 2008 | Microsoft Windows XP Professional
Microsoft Windows Server Standard 2003 for PC Logo
200 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
