Question about Kenmore 63942 Dryer
ROPER DRYER WILL NOT HEAT
PLEASE HELP
NEARLY NEW ROPER DRYER RUNS BUT DOES NOT HEAT
READ ON LINE THAT A RESET BUTTON MIGHT NEED TO BE PUSHED
WHERE EXACTLY IS THAT
WE HAVE THE BACK OFF AND CAN NOT FIND IT
THANKS
  • 550 Answers
Put the back panel back, and hope you havent done permanent damage
the back does not come off roper dryers for service
the front does
the back panel serves solely as a mounting point for important fixtures
there is no reset button
there are thermal fuses, if the thermal fuse, mounted on the exhaust duct or fan housing has failed, it must be replaced, but they are not expensive
look like this ROPER DRYER WILL NOT HEAT - de074eb.jpgbcb6b5f.jpg to access the dryer mechanism
unplug dryer
remove lint filter
remove 2 screws under lint filter
with putty knife or other blunt blade, depress spring catches at front corners of top cover
raise front cover
remove 1 screw each side of front panel 1/3 from top
remove door switch wires
remove front panel set aside
test all thermostats heater and thermal fuse with ohmmeter, remove 1 wire test for conduct replace wire, no conduct replace
the local parts store will have the part, labelled whirlpool, ~$14 for thermal fuse, ~$40 if heater
examine rear panel reinstall any thing that is dismounted
while the dryer is open
Clean the lint out of fan, fan housing, ducts
airflow blockage is the 99% cause of thermal fuse blowing, some lint always gets past the lint screen
Posted on Oct 31, 2008
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
Dryer won't heat.It is not the element , thermostats or thermal fuse.When it stopped heating,I used it for a while on air just to fluff.After having everything checked we found that the lint filter housing...
If you are sure thermostats and fuses are good (most dryers have 4) and its not the element, then the heat circuit also runs through the motor and timer.
Oct 17, 2017 | Roper REX3614KW Electric Dryer
Model number LER4634EQZ
I looked up your model and it is the same as a roper dryer I repaired some time ago. I did a video on it entitle roper dryer no heat. I believe you will be able to repair the machine you have if you watch the video. The dryer runs so the fuse mounted on the blower is fine. That means it is either going to be the heater element, one of the heater element safety limits mounted on the heater housing, the timer, or a bad electrical breaker/elkectrical receptacle. The motor runs on line 1 and neutral and is a 120 volt motor. This means the breaker could be open o the line 2 side and no power is getting to the element so you need to first verify power to the unit is 240 volts. Remove the rear panel and look for open components on the right hand side which is the heater assembly.
Your service manual can be found HERE
Jul 03, 2013 | Dryers
IT RUNS BUT DOES NOT HEAT
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Roper Dryers
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
Roper Dryer won't heat
check the upper and lower limit switches on the heating duct. they act like fuses and and pop if the go bad. to check. first unplug dryer then remove back panel. the heat tube should be on the right and have two disc looking things with two wires going to them. check top one first. pull wires off and with jumper wire connect the two wires together. now plug dryer in and check to see if it heats. if not check the lower one. do not run dryer for longer then i takes to see if coils heat up. if still no heat then u need to pull heating element off and check for an open in the coil.
Jan 30, 2009 | Roper REX4634KQ Electric Dryer
I just moved and my LG dryer does not heat up.
Your ignitor (glow bar) got broken during the move. They are more fragile than your grandmother's fine china
Dec 16, 2008 | LG DLG9588 Dryer
My roper dryer is not heating
YOUR HEATING ELEMENT IS BAD OR YOUR HEATER BOX FUSE IS BAD,IF YOU HAVE A METER YOU CAN CHECK THEM BOTH-LET ME KNOW-MIKE
Dec 06, 2008 | Roper REX4634KQ Electric Dryer
Runs fine just no heat.
the heating element is out, or it has overheated and burned the wiring that runs to it
Mar 07, 2008 | Roper RES7648E Dryer
Kenmore 63942 Dryer Logo
1,648 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
