Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Problem with Hotpoint WD64 Washer Dryer
My Hotpoint WD64 is not washing/spinning correctly.
When selecting a program and turning the machine on. The machine fills with water and the timer seems to click more than usual. The drum may turn a few times before the timer clicks some more (The wash cycle does not seem to complete correctly). The machine then drains before the moving to the rinse cycle, where the machine will fill and the drum rotates for a period of time before draining again prior to the spin cycle. The spin cycle seems to get skipped then the program ends.
I’m pretty sure that the wash water is not getting heated up. I have a dual cold feed configuration.
I have performed a number of tests in order to resolve the issue.
  • The motor works because the drum does turn, and I can force the machine to spin by starting the program on spin and switching it on.
  • I have checked the drain sump for blockages. The drain sump is clear and the machine seems to empty in a timely manner.
  • The drain pump therefore seems to work correctly.
  • I have checked the pressure vessel for blockages and leaks. Both the pressure vessel and pipe are clear.
  • I have tested the pressure switch by blowing into it and testing the continuity between various terminals. There appears to be 2 pressure switching actions working.
  • I have test the wash water heater element, this works correctly.
  • I have tested the wash water thermostat. The resistance at room temperature is approx 10K Ohms. At 90C it is approx 2K Ohms. So this appears to work.
The timer seems to click more than normal the cycles are not completing correctly before skipping to the next cycle.
Any help would be appreciated.
Thanks
Nick
  • 2 more comments
  • Basset Man Nov 01, 2008
    I have checked and cleaned all connections on the control board. The problem remains the same. Clicking when on Programs C,D and E. I have disconnected the motor and ran the machine with the front off. To check the Heater voltage, the heater is only powered twice during the program. Even then it is only powered for a short about of time <2minutes (not long enough to sufficiently heat the water). I tested the water temperature with my hand, it was still cold. It seems that the water is not getting heated and there for the wash cycle does not complete correctly before moving on to the next cycle???
    Let me know if you need further information.
    Thanks
    Nick
    I don't believe this is a power supply issue. The dishwasher uses the same supply with no issues.
    Thanks
    Nick
    How do I test the timer?
    I tested the element by connecting directly to power supply. Takes a long time to heat the water, even to luke warm (5-10minutes)
    Thermostat has resistance between 2K ohms and 20K ohms.
    Machine fills quickly, less than a minute.
  • 728 Answers
You might need a new circuit board because water may have gotten on the one you have now causing it to short out and making it malfunction causing it to do some things that you do not want like it skipping the last cycle. You may need to get it checked at a shop to confirm the suspicion and to get it fixed.
Posted on Nov 01, 2008
    President:
  • 2,712 Answers
This is definitely a control board/timer failure, and hence instructions are getting warped. Although the connections look good, the circuitry itself may be faulty. The heating element seems to be OK, as it IS getting warm.
Replace the timer and/or control board to resolve the issue.
  • Hotpoint Master
  • 19,396 Answers
Effectively it looks like a water heating problem.
When the water cannot be heated sufficiently, the machine waits until water reaches desired temperature.
So that the program takes longer to complete.
Heating problems can be caused by:
Faulty heating element
Faulty heating element solenoid.
Faulty thermic switch (in this case the water will get hotter than normal)
The heating element and the solenoid can be tested for continuity using a multimeter.
If the machine is slow to fill check also that the inlet valve is fine and not obstructed.
  • Ginko
    Ginko Nov 01, 2008
    Then you have a faulty element, replace it.
    Genius:
  • 1,550 Answers
It looks to be bad timer .
Timer is malfunction better have check over it .
  • SAM ANDERSON Nov 01, 2008
    Unplug
    the washer. To access the timer, remove the control knobs and the panel
    that covers the controls. This may be a front panel, or access may be
    through a panel at the back of the unit. Carefully examine the wires
    that connect the timer to the other parts of the washer. If the wires
    are loose or disconnected, try pushing them into position; they usually
    fit into their terminals like plugs. Use long-nosed pliers to avoid
    breaking the wire connections -- never pull a wire by hand.
    To
    test the timer, use a VOM set to the RX1 scale. Disconnect the power
    leads to the timer and clip one probe of the VOM to each lead. The VOM
    should read zero if the timer is working. Since the timer is a multiple
    switch, turn it through its cycle and test each pair of terminals in
    turn. The meter should read zero at all of these points. If one or more
    readings are above zero, the timer is faulty and should be replaced.
    Source:howstuffworks.com
    Genius:
  • 1,913 Answers
Check your power supply waltage and also check earthing propelry working.
    Brigadier General:
  • 3,614 Answers
This possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Posted on Oct 31, 2008
Hotpoint Aquarius Extra washer dryer WD64 will not drain water. Spin works ok.
Was it working before? You may have a blocked outlet hose. Try taking it off under the sink to look for a blockage. You could also try getting some water in from that end with another hose to see if it comes out into the machine. If it is not a blocked hose, then the pump may be faulty.
Dec 09, 2010 | Hotpoint Aquarius WD640 Front Load...
Tip
Rattle or leaking condensor on Hotpoint WD64
This website has been good to me so I thought I'd post back!
A common problem with the WD64 washer dryer is the condensor working itself loose from the heater box on the top of the machine. This will result in terrifying banging on spin and, if left, screws and rubber seals appearing under the machine. If left longer, as it was with my own, the machine will leak from the condensor to backplate joint at the back of the machine.
The problem is caused by poor fixings at the condensor (the white plastic piece) to the heater (the silver box at the top of the machine).The solution is to remove the condensor, clean it and refit it with new more robust fixings. Hotpoint provide their workmen with a kit of heavy duty bolts, but I did it with a few loose bolts I had. Save all rubber parts as they are riduculously expensive to buy. I had to by the o-ring from condensor to drum backplate and could only get 5 at silly money. If anybody wants one at a good price I'm kolleykibber on ebay.
on Jan 23, 2009 | Hotpoint Aquarius WD63 Front Load...
I have water leaking from the dispensing tray, only on the pre wash filling..any suggestions I have a hotpoint washer dryer wd64
Check the level of the machine, may be leaning slightly forward allowing water to leak on that one fill cycle. Lift the front a little by using the adjustable feet and see if it stops.
Feb 16, 2010 | Hotpoint Aquarius WD640 Front Load...
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd64 front load washer-dryer filter
if your hotpoint has no obvious filter its likely to be the type that has the filter built into the main exit hose from the drum to the pump. Clearing these is not as easy.Pull machine out and unplug it, on the rear there is a panel at the bottom which when removed you will see the pump where the exit hose attaches. From the pump to the drum is normally a wider black pipe and this contains the filter. removal of the pipe from the bottom of the drum is normally a jubilie clip but some have plastic clips that are easy to break. once you have dropped the pipe from the drum ( water goes everywhere ) you can then remove the white filter assembly which is like a shuttle **** with ping pong ball in it. clean out fully and make sure its all back together as before.
Sep 12, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD64 is not spinning or emptying
check the pump, make sure drain hose is not cloghed, ensure the belt is in the place, spin the drum a bit by pulling the belt. then give it a go.
Update me about your progress
Jul 24, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd64
Check power is at these Points.
  1. Mains filter at top right - Check for live and Neutral Presence.
  2. ON/OFF Switch - Check for Power in and Out when switched on.
  3. Door Lock - Check for Power down 1 wire and when Locked, Power ( Live ) present in 2 wires. The third wire is the Neutral for the door locking circuit. Check this Neutral is OK. - Let me know.
Mar 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd64 washer dryer
mits86 , you are correct - it could be the belt.
REMEMBER TO UNPLUG BEFORE STARTING ANYTHING!
To do the belt...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel.
If you see a broken belt then remove it and re-order one from hotpoint...see http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=634224&brand=&model=wd64&part=belt.
6. to replace belt - see motor shaft at bottom of unit. Dangle new belt round shaft of motor and gently pull so it does not come off motor.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
- If the belt is not broken in your case - it could be the brushes on the motor - I can give you info on this if required!
Please dont forget to rate me as fixya.
Mar 07, 2008 | Hotpoint Aquarius WD63 Front Load...
MY WD64 does not spin
First see if there is power in your wall socket; then check your washer plug, or plug fuse, wires.......
Sep 30, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
306 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
