Question about NAD C521 CD Player
C521 reads "no Cd" when cold and cd is inserted
But when the cd player is warm, after some 30 minutes, it reads ok. If I let the room cool down to say 68 degrees from 72 degrees, the player will not see the CD again. Many thanks for help.
  • Alan12345 Oct 29, 2008
    That is what I am doing, keeping the temperature up to 72 degrees. However, even at 72 degrees, the player takes 30 or more minutes before it starts working properly, which should not be the case. I am wondering if there is an adjustment, or if a chip or other part might be temperature sensitive, such as U201? Any other thoughts?
    Thanks.
    President:
  • 2,712 Answers
Yes, most electronic devices work at an optimum temperature, and if the temperature rises or falls below this, the circuitry could go out of spec.
If the temperature is too cold, you could try to warm up the back of the player with a hairdyrer for a few minutes. This generally does the trick..
Posted on Oct 29, 2008
Why will my CD Players (Two of Different Makes) not play Sony CDRW Audio CDs Continuously on "Repeat Modes? When a Alanis Morisette CD Repeats OK and plays continuously and does not turn off after about 14...
Have you closed the session when you made the CD? It is necessary to do that in order to play it in anything else besides the computer that made the CD.
Jul 29, 2016 | Sony Audio Players & Recorders
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
How to insert cd into dell c521 tower
Anonymous,
You can press the button on the front of the cdrom and the cd drawer will open.Insert the cd and then you can then press the button to close.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
#iwork4dell
Oct 14, 2014 | Dell Dimension C521 PC Desktop
Why does my CD player display "no disc"?
I had a similar problem with my DVD player. Cleaning the laser eye helped fix my problem. You can clean it manually if you are not afraid to remove the cover of the unit or you can try a cleaning disc. The eye can collect dust and prevent it from reading the ID sector of the music CD.
Jul 07, 2014 | Audio Players & Recorders
I have an MC 602 and can not change the source-it constantly reads Tape; the power goes on and off, the house chimes work but I can insert a CD, it plays but there is no sound and I can not switch to the...
Had the same problem. Tried rebooting the system. Nothing worked. Saw another post about speakers. Went around the house and turned volume down and it started working by time I hit the third room. weird stuff.
Sep 14, 2010 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
My NAD cd-player has locked it self! I cannot play the cd's or even open to take the cd out. What can I do? Marit
Mine does the same. Press eject and give the front of the draw a sharp tap.. the draw should then open.
Also when loading a disk give the draw a hard shove closed just as it is almost shut - seems to make the disk read ok.
I think both problems are related to a worn / slack tray drive belt... I just haven't been able to find a replacement.
Nov 12, 2009 | NAD C521 CD Player
Drawer opens when the player is switched on
hello marc you have a dirty laser,blocked sensor or even a misaligned condition try this clean the lens put a disc and turn it off with the tray inside wait about a minute and turn it on saludos
Jan 11, 2009 | NAD C521 CD Player
NAD CD 5425 - No Spin - Sometimes
I've dealt with this type issue quite a bit.
Believe it or not the drawer belt needs to be changed.
If the drawer isnt drawn all the way into the unit...the disc motor wont spin and ....you get rejected
Dec 23, 2008 | NAD C521 CD Player
Lexus Cd-Changer
lol had this prob so many times, you will find that you have moisture in the cd exchanger and the way i found this out was on removing my cds first thing in the morning a noticed very slight misting on most of the cds. .i put the wifes hair dryer and blasted warm air into it for a good 15 minutes waited till it cooled down cleaaned carefully my cds replaced and away i went. hasten to add that this was temporary a few days later i got the odd cd not playing . i notice the prob more in cold weather and if the car has not been used for a few days. the boot maybe damp .. good luck .stu
Aug 19, 2008 | 1996 Lexus LS 400
NAD C521 CD Player Logo
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
