Question about Whirlpool Dishwashers
The dishwasher fills with water and doesn't shut off at the start of the wash cycle.
I have a hotpoint dishwasher. I ran the dishwasher and it went through all the cycles but on the last drain cycle it didn't drain? Any suggestions
Posted on Oct 29, 2008
Dishwasher malfunction
follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Jul 08, 2013 | Dishwashers
Bosch dishwasher makes noise but doesn't start
When you start a wash cycle on your Bosch dishwasher and it does not work, stay calm. It could be something simple, especially if you just installed it. Make sure the power cord is connected properly and a circuit breaker did not trip. How to Troubleshoot Bosch Dishwasher That Doesn Fill With Water
Sep 25, 2017 | Bosch Dishwashers
DISHWASHER GE PDW7800J00BB DOES NOT WASH ,FILLS WITH WATER BUT NO WASH
It is unclear from your description if the wash pump starts and pushes the water around but never stops cycle or the dishwasher stops as soon as the water is filled.
If you do not hear the wash pump start then it is possible the wash motor is faulty. But if the wash pump starts and never completes the wash cycle then it is possible the heater is faulty and dishwasher is waiting for water to heat up before it can go to next cycle.
See the attached diagram for location of wash pump motor and heater.
Hope this helps you find the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | GE 24 in. Profile PDW7800 Built-in...
I have a GE GSD2230Z00WW dishwasher water will not fill on start no power on the fill valve either. Water will come on quick wash cycle and rinse.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
***If everything checks out ok with the water inlet valve, replace the timer or control board.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Power point dishwasher - not washing dishes
Jun 18, 2009 | Dishwashers
Dishwasher starts washing before float switch shuts off
That is it , it is the electronic programer circuit board timer. change it. Vitally
May 12, 2009 | Dishwashers
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
Jun 13, 2007 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Dishwashers Logo
76 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
