Epson Stylus Photo 1410 printer, 10 months old, never any problems. Yellow cartridge ran out and I replaced it. No problems, new cartridge in new unopened sealed pack, removed pull tab, everything normal, exactly as usual. Pressed Ink Button on printer to indicate 'finished replacement'. Red light in Ink Button REMAINED ON, 'replace yellow cartridge' message REMAINED on screen. Printer sat and looked at me. I removed new cartridge and checked - cartridge carrier appeared to be intact, electrical contacts all normal, electrical contacts on cartridge all looked normal, so I re-inserted same cartridge. No change. Replaced with a second brand new cartridge. No change. Tried original (empty) cartridge again. No change. Turned printer off, waited, on again (at several points in the process). No change. Checked all markings on packets. All in date and OK. Visually checked cartridges. All the same and OK. Suggestions please!
  • 787 Answers
SOURCE: canon mp600 printer
MP600 Easy fix for unrecognized ink cartridge
Posted on Jul 18, 2008
  • 18 Answers
SOURCE: I need to replace the color ink in my Epson stylus color 740
This is a hard one and you will probably end up wasting a cartridge if you force it across (like i used too) just try forcing it across (with power off) removing the cartridge, pushing it back (it must go back to the exact spot it came from) and switching it on, hopefully it'll notice its missing the cartridge and flash the lights to you. once this happens you should be able to replace the cartridge as normal by applying the 3 second button.
If the printer starts to make a clunking noise after moving the cartrige holder physicaly you may need to clean the runner bar (the metal one) do this with a clean cloth and then apply a light oil (not wd40) onto another clean cloth and run over the bar again.
Posted on Mar 01, 2009
  • 235 Answers
SOURCE: EPSON Stylus NX110 - 1st Ink Cartridge Replacement
you better have your printer check by a qualified printer tech thus avoiding any further damage to the printer the printer head is the most likely problem to
Posted on Nov 21, 2009
  • 420 Answers
SOURCE: I just replaced the yellow ink cartridge but it
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Posted on Sep 15, 2010
  • 4 Answers
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Posted on Oct 25, 2010
Out of ink?
Many printer cartridges may have ink but the printer believes otherwise. Often this problem can be solved by placing a small piece of black tape over a window in the cartridge that the printer looks into to identify ink level. If you cartridge has such a window, try a piece of electrical tape. You might be surprised.
May 08, 2010 | Epson Stylus Photo R800 InkJet Printer
Yellow ink not printing after cleaning utilities run; others ok
Your print head is bad. Try cleaning it with a tissue. You may see if you can find a replacement for that printehead.
May 04, 2009 | Office Equipment & Supplies
Epson D92 replacement cartridge problem.
you can buy an epson chip resetter. i think they 7pin chips .try ebay about a fiver.it should reset the chips.the cart that is empty use your restetter on that and put that chip on the one that doesnt work.should be ok then.resetter led nornally goes green if chip is reset.ink level goes up to full.when carts show empty reset and you should be able to keep printing a few more pages.check chip contacts are clean no dirt etc.try resetter on non working cart light should go green.hope this helps
Feb 17, 2009 | Epson Stylus D92 InkJet Photo Printer
Epson stylus photo rx580
Hi-
You are having a hardware problem with the printer, the sensor is damaged. call epson @ 5622761300 for replacement ink and printer.
Hope this helps
Nov 08, 2008 | Epson Stylus RX580 InkJet Photo Printer
57 people viewed this question
k24674
jasbo
jasbo
