I need a power cord for a Sceptre Model X5G Komodo7 LCD monitor. Please email: jack@jackseibert.com THANK YOU!
    Sergeant:
    Champion:
  • 275 Answers
Power cord does it look the same as u have in the back of the computer ?
if yes .. get the same kind of power cord from a computer shop and that should work
Posted on Oct 30, 2008
My scepter e240 wont power on is it junk or what
dear,
first of all, check whether the power on/off button light (LED) turns on or not. If it goes on either orange or yellow/green, it means its not completely dead. If its not doing that then its a different matter.
Then you have to check the power cord that can be problematic and need replacement. If it is ok then you have to disassemble your monitor to check the inner fuse that is related with the power supply.
Most probably it is cause by the Capacitor, if it is dead and after checking the fuse!
best of luck!
Mar 31, 2012 | Sceptre X5g-Komodo VII 15'' LCD Monitor
I need to replace the power supply for Sceptre X5G Komodo IV any idea where I can order one for it. Is is cost effective to replace it or better to just buy a replacement? It power on fine but flashes...
15" monitor this old will not be worth to get another used board in it because more likley the caps will go out soon also since they will be about the same age as your board. Try replacing the caps? or new monitor?
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 28, 2010 | Sceptre X5G-Komodo IV 15" Flat Panel LCD...
What kind of power cord do i need for the realsync lcd monitor model #s1901d
the manufacturer would be the place to go for a replacement cord or power adapter.
You can find the contact information on the back of the monitor usually.
Here are some sites that may have the power cord:
1. http://www.12vadapters.com/adapter/power-supply/12v/for-lcd-screens/sceptre-x9g-agama-s1901d.html
2. http://www.replacementpower.com/store/main.aspx?p=itemdetail&item=POWERCORD
May 15, 2010 | Microsoft Realsync 19 8ms LCD Monitor 270...
LCD monitor not working right
This is 2004 model, it may not be worth putting money and time into repairing a 15" monitor. But you can at least look inside for any damaged, burnt components, lose connections, etc. otherwise to do a component level repair at the shop will not be worth it.
See eample of what usually goes wrong with LCD monitors: http://s807.photobucket.com/home/budm/allalbums
Apr 05, 2010 | Sceptre X5G-Komodo IV 15" Flat Panel LCD...
Screen slightly flickers
Probably the inverter board of your monitor has been exhausted. The inverter is the part that enables the monitor to glow, making a little fluorescent gas lamp insithe the LCD bright strong enough to illuminate all the panel. When this circuit has some disfunction the lamp could oscilate, ficker and finally die making the panel dark and you couldn read what's on the screen.
The inverter has a lifetime, and the lamp too, check the lamp lifetime of your monitor and the inverter too.
But this could only be performed to a qualified person, due the high probability of electric shock if you try to make yoursel the repair.
Good luck
May 23, 2009 | Sceptre X5G-Komodo IV 15" Flat Panel LCD...
No picture on my x5g-komodo7 monitor
A reddish picture is the classic symptom of worn out backlight bulbs.
Sensor circuits usually shut down the power to the bulbs in a second or so.
Monitor Mike.
Jan 03, 2009 | Sceptre X5g-Komodo VII 15'' LCD Monitor
No picture
I fixed mine. Had to replace one bulging capacitor in the power supply. Yours may need more or less but it was pretty easy if you do any electronics. The specifics can be found under some of the other problem posts, especially for one of the 19" sceptres.
May 04, 2008 | Sceptre 17" LCD Monitor
Sceptre DCLCD19+ MONITOR WHITE SCREEN
To me it sounds like the bulb is having a problem with powering up. It may be an issue with the power adaptor or the outlet it is plugged into. Have you tried to plug it in, in other outlets?
Dec 20, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
