Question about Olicom OC-3137 Network Adapter
Internet Disconnectio due to sudden attack of Virus
Please advise what would be the best actions if the internet based project company will experience long work stoppage due to sudden internet disconnection due to virus attack in the internet network system. What alternatives that we can make in order to prevent from work cessation.
Thanks,
Fars
  • cogunlowo Jan 08, 2009
    My explorer was updated or upgraded and after the update i could not browse with the explorer, i decided to restart the laptop and when i did, i was unable to login and unable to connect to the wireless network in my office, while others are using this network , my laptop is displaying limited or no connectivity. I tried to ping my ip address and got this response:
    pinging o"y" with 32 bytes of data:
    Destination host unreachable:
    I can no longer access my hidden folders.
    Please assist.
Netgear wna 3100 just all of a sudden stopped working and wont stay connected to internet or when it does connect it stops working within 5 min, whats wrong?
Hello. Have you tried uninstalling the driver on the computer, and reinstalling the most up-to-date driver for the adapter? If not, I would suggest trying this first. Otherwise, have you been using the usb drive for other things? It may also have to do with the Usb connection, or even the usb drivers. Try another usb device to see if they have the same issue. Many times, it involves the drivers.
Hope this helps and best of luck
May 22, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
I got a new modem a few days ago and when i put in the password for the internet connection it keeps telling me that the internet has limited access and doesnt even let me log into the network, please help...
Hello Adrian,
I would recommend trying to log onto the router (normally by entering 192.168.0.1 or 192.168.1.1 in your web browser address bar) and make sure you are using the right password and check if your router is compatible with wireless N technology.
If your router is set to work with b/g and does not support N you will not get a proper connection.
Thanks,
Pat
Apr 14, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
My wireless adapter is telling me that it cannot connect to the internet, also when I start internet explorer I get "cannot display webpage", however, when I start firefox i am able to get to the...
IE has alot of faults and is more vulnerable to attacks. I suggest using firefox or google chrome as your browser and keep running your antivirus and malware as you already do
Mar 04, 2011 | Linksys (WMP54GS) 802.11g/b Wireless...
Extremely slow internet connection and computer navigating
Extremely slow internet connection and computer due to registry corrupt.
The Windows registry is a database repository of information about a computer's configuration.
clean registry here
http://www.keep-pc-clean.com/
May 25, 2010 | D-Link WUA-2340 (ASKU55774) Wireless...
Internet won't come up. I talked to the cable company, and we disconnected the belkin router and internet came up. I tried to reconnect it to the router, and it still won't come up.
Sounds like ADSL setings might be incorrectly configured.
RESET your Router (Remember: All your settings on the Router will be Lost)
Login to your router.
Check the Basic Settings and recheck your User ID and Pwd.
Check whether your ISP using LLC-based or VC-Based Multiplexing method.
Check VPI and VCI range.
Run diagnostics on your router and check it recieved any public IP, hope this helps
Feb 13, 2010 | Computers & Internet
Cant See Preferred Wifi or Connect,
Having gone so far, I think the next thing you should do now is to get to the wireless properties and then assign an IP Address, Subnet mask and the Default Gateway for the Internet and you will be amazed to be connected. If you have not disabled and enabled the wireless device you may do that before proceeding to the step above. The pc should be restarted after the exercise ok. Good luck
Jun 02, 2009 | Computers & Internet
Can't get it to work
I had the wireless working with dynex card before the virus hit the computer. The virus is fixed, but the internet does not work.
Feb 28, 2009 | Dynex Enhanced Wireless-G USB 2.0 Network...
Acer Aspire T180 can't get on internet due to driver corrupt or misssing?
Hello, It sounds to me like there is a conflict between the Kaskersky and Vista. I'd un-install and use Avast but AVG is a Good Anti-virus also. Vista is sometimes a nightmare. I have problems with certain flash-drives which will not work in Vista. They freeze up the computer. It's Vista. Hope this helps. Good luck.
Mar 25, 2008 | Computers & Internet
Olicom OC-3137 Network Adapter Logo
242 people viewed this question
Top Olicom Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you an Olicom Computer and Internet Expert? Answer questions, earn points and help others
