Question about Canon NP 6050 Copier
Blown fuser lamp or thermofuse - "If you are handy I can walk you through it"
I am not sure whether my previous reply went through, so I am posting it again.
Thank you for your "If you are handy I can walk you through it" offer. I would like to go through it with you. How can I do it? Should I call you? My phone is 847-680-2459.
Thank you.
Kim
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Wanted to find out if you tried replacing the fuser parts ?????????????
Posted on Nov 12, 2008
What is code H or 4 which stops copying
Your problem in the fuser unit.Please check and clean the fuser lamp,fuser thermistor and thermofuses.Verify the continuity the fuser unit parts( 6-7 Ohm).
Nov 17, 2009 | Sharp AR-5320 Black and White Copier
Error code SC 542 on my Gestetner Dsm622sp
Fusing unit problem.Verify the heater lamps,thermistor and thermofuse continuity.Enter in the SP mode turn OFF the main switch,unplugged the machine wait 10 sec.,plugged and turn ON the copier.
Sep 24, 2009 | Gestetner Office Equipment & Supplies
How do u reset minolta copier im2520f CO5000
The CO 500 code is malfuction the fuser unit.Check the fuser heating lamp continuity and the fuser thermofuse and thermistor.
Sep 07, 2009 | Konica Minolta DiALTA Di200 Copier
Canon NP 7850 keeps blowing the fuser lamp in half!!
Your lamp is not turning off, could be the SSR, could be control board. Replace the lamp, thermistor and the SSR, but monitor fuser operation, make sure the lamp turns off.
If you have a digital thermometer, check the temp when the lamp finally turns off. If it is in Spec. then run a few copies this should cool the rollers and cause the lamp to relight.
If the lamp reached optimal temp but does not turn off, then the control board could be your issue.
Hope This is of some help.
Ed
May 13, 2009 | Canon NP 6085 Copier
Canon image writer 860 e000 error
E000 is a fuser error
Thermofuse (blown)
Lamp (blown)
Replace or repair them
Replacement would be a good option as its cost effective as compared to its repair and it would not create any issue in the next few years.
Thanks.
Mar 24, 2009 | Canon PC-860 Black and White Copier
Printer is hungup on self test
920.08—POST (power on self test) error service check (Sub Code .08 (Exit sensor not connected.))
Check the Exit Sensor for Damage or dust.
Check DC auto-connects on both the fuser and the printer for damage.
If connector is damaged on fuser, replace fuser. If the cable connectors is damaged, replace the JFUSER1 cable.
Check resistance of the fuser, lamp, thermofuse, thermistor
Most Cases you will need to replace the Fuser.
Mar 17, 2009 | Office Equipment & Supplies
Canon 330 image runner Error code E000
E000 is a fuser problem.
take out the fuser (this is where the paper exits and gets hot) the tow long big rollers, the lamp may have blown or the thermofuse (keeps the copier from over heating and going to meltdown) may be bad.
The newer ones (not sure about this model ) have a ceramic instead of a heat lamp and also a thin brown film instead of rollers.
if it has a film make sure it is not torn or displaced.
Nov 21, 2008 | Canon imageRUNNER 210S Copier
Copier won't fire up
your fuser unit is not working .open and see your thermofuse, thermistor or your heater lamp is out. if there is dirty between your thermostart & your fuser roller, clean . check for continiuty on your thermofuse & fuser lamp. thanks
Nov 12, 2008 | Office Equipment & Supplies
Error code E004
the error has nthing to do with the drum!!!!!!!!!!!!!!!!!
I can tell you how to change it,but it will still have the code.
You have either a blown fuser lamp or thermofuse, you should change that before the drum since you still won't be able to use it?
Oct 28, 2008 | Canon NP 6050 Copier
Eooo
Thermofuse (blown)
Lamp (blown)
replace
check repair price vs new one
Oct 16, 2008 | Office Equipment & Supplies
Canon NP 6050 Copier Logo
66 people viewed this question
old marine
old marine
